Read out HP 650 G5 16MB Chip
  • 530v8
    • May 2019
    • 39
    Hi
    i have some problems reading out the 16mb chip on Keyboard Side.
    The 32MB Chip memory side i can read out but for unlocking i need the 16mb chip for the G5 series right?
    I use the Revelprog IS and WSON 8 6x8 Pins.
    Photo attached.
    Any idea?
    tried with ac adapter and without also with VPP 3V and disabled
  • hoaca388
    Badcaps
    • Jan 2022
    • 12278
    Re: Read out HP 650 G5 16MB Chip
    Originally posted by 530v8
    Hi
    Photo attached.
    Any idea?
    Any file will do
    • 530v8
      • May 2019
      • 39
      Originally posted by hoaca388
      Any file will do
      What do you mean any file will do? i can use the 32MB Dump for unlocking?
      • hoaca388
        Badcaps
        • Jan 2022
        • 12278
        Yes .
        • 530v8
          • May 2019
          • 39
          Yes .
          Yes tried with RC Unlock but says find 16MB Dump
          tried old unocker V1 from here, i get bin file unlocked back but password still remain, lil bit confused
          • 530v8
            • May 2019
            • 39
            i find out the failure the programmers protection buffers are blown
            thanks to all will try with ch341
            • acedogblast
              by acedogblast
              11-02-2024, 05:13 PM
            • DynaxSC
              ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
              by DynaxSC
              Hi
              I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
              08-04-2025, 12:20 PM
              by SMDFlea
              Bad...
              09-02-2021, 04:40 PM
            • BMCappelletti
              Asus Chromebox CN62 - wrong chip put on BIOS reader
              by BMCappelletti
              Long story short:
              - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
              - gave the computer to his son a couple years later
              - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
              - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
              (seems like the story was not that short)
              He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
              01-08-2025, 07:27 PM
            • inck243
              Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
              by inck243
              Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
              The BIOS...
              07-25-2024, 09:17 AM
