Need UX331UA Bios file
https://www.badcaps.net/donate -
Re: Need UX331UA Bios file
Hi thanks for your reply here is the serial number i don't have original bios as i can't read it it gives me error when trying to read. I try with another reader this afternoon i'll update this thread with bin file if i got it
SN: HBN0CV03C329458Comment
Attached FilesComment
by bondminer009Good Evening,
Need help, is there any possible to get the bios file? Because received from my team without any dump file / original bios file
Thank You
Salam,
Three-
Channel: BIOS Requests ONLY!
by CityminHi all,
S/N : 5RNK9FFT70...-
by joshAUHi all.
I'm looking for a BIOS file for an Asus N550JK.
I have a Asus R552J, which I believe is identical to the Asus N550JK.
I downloaded the latest BIOS (210) for the R552.
It is named N550JKAS.210.
The BIOS file is however only 6mb in size.
I've read the chip with a CH341A programmer and verified the file.
That file is actually 8mb in size.
I'm wanting to remove the BIOS password from this unit.
It prompts you to input the password when turned on, so its sort of behaving like a power on password rather than...-
by adelageHi,
I am trying to recover an ECS Z77-H2 motherboard, I dumped the original bios with a ch341a programmer, the bios from the manufacturer is a .cap file of smaller size, and it seems that I need to merge this file with other information from the dump, anyone can explain how to do that?-
by m1ch43lzmHi everyone
I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
Programmer models: XGecu TL866II Plus / T48 / T56 / T76
Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
There's also an extra OTP Secu.R...-
- Loading...
