Mecer CA14D03 EM_IG118_200B_ENE_V2.0
  • m1ch43lzm
    by m1ch43lzm
    Hi everyone
    09-06-2025, 05:47 PM
  • iZakre
    HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
    by iZakre
    Hello everybody!
    To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
    The thing is that I had installed TeamViewer and could log into the computer...
    02-19-2023, 02:27 PM
  • joshAU
    BIOS file for N550JK (original dump attached)
    by joshAU
    Hi all.
    I'm looking for a BIOS file for an Asus N550JK.
    I have a Asus R552J, which I believe is identical to the Asus N550JK.
    I downloaded the latest BIOS (210) for the R552.
    It is named N550JKAS.210.
    The BIOS file is however only 6mb in size.
    I've read the chip with a CH341A programmer and verified the file.
    That file is actually 8mb in size.
    I'm wanting to remove the BIOS password from this unit.
    It prompts you to input the password when turned on, so its sort of behaving like a power on password rather than...
    08-09-2022, 08:06 PM
  • Abrith
    dell 5391 blank and topspeed fan, anyone have bios bin file
    by Abrith
    dell 5391 servis tag GJJBJW2. ic type MX25L8006E
    12-07-2024, 07:00 AM
  • Citymin
    by Citymin
    S/N : 5RNK9FFT70...
    08-05-2025, 05:12 AM
