Gk7mr0r v1.2 10l bİos need
  • bedirhansozbilen
    • Sep 2023
    • ankara
    Hello friends, I have a gk7mr0r v1.2 10L motherboard, monster tulpar t7 v20.2, but it looks the same as the tongfang gk7mr0r v1.2 10L motherboard. Does anyone have a bios?
    • 22286
    Re: Gk7mr0r v1.2 10l bİos need
    Post the serial number,and your backup(s) -> https://www.badcaps.net/forum/showthread.php?t=103570
    • bedirhansozbilen
      • Sep 2023
      • ankara
      hello
      serial number
      GK7MR0R2204402539
      • Duvelhedz
        • Oct 2015
        • 20
        • United Kingdom
        hello
        serial number
        GK7MR0R2204402539
        I am looking for this BIOS also. Did you manage to find a copy of it?
          SMDFlea commented
          Editing a comment
          Read post #2
      • startrek
        • Jun 2017
        • 32
        • turkey
        try this
        • the Benninger
          • Nov 2022
          • 189
          • venezulan
          Originally posted by startrek
          try this
          HI This worked for me, I just want to know if you know the address of the DMI to edit it so I have my serial number and everything else I made a post about my problem but no one contributed
          https://www.badcaps.net/forum/troubl...-avell-a62-liv
          • peste
            • Dec 2016
            • 13924
            • ROMANIA
            try..97F000 - 97FFFF
            • the Benninger
              • Nov 2022
              • 189
              • venezulan
              WoW I have no doubt you are masters of hexadecimal art, my respects I got the demi with your help Mr. peste replied in the address (97f000-97f198) edit and reload the tsop with this I'm testing now a million thanks
              • baki60
                • May 2020
                • 78
                • Türkiye
                merhaba
                Monster tulpar t5 v19.2
                seri no:GK5MR0V2202904029
                gk7mr0r v1 .1
                I need bios masters
                • danito
                  • Jun 2016
                  • 1259
                  • Romania
                  Originally posted by baki60
                  merhaba
                  gk7mr0r v1 .1
                  I need bios masters
                  post the original bios of the laptop even if it is corrupted,the motherboard model, etc.
                  • baki60
                    • May 2020
                    • 78
                    • Türkiye
                    motherboard model:gk7mr0r v1 .1
                    bios chip faulty​
                    • digina
                      • 6
                      • Türkiye
                      TULPAR T5 V19.1 bios dump
                      • s_specialist
                        Monster Tulpar T7 V25.1 bios
                        by s_specialist
                        Monster Tulpar T7 V25.1 (same MSI GE76 RAIDER 11UG) isn't working. The motherboard outputs 19V, the supply voltages are 3.3V and 5V, the chipset voltage is 1.05V, and the BIOS voltages are all there, but it still isn't working. I replaced the FH82HM570 (SRKMA) and it still isn't working. Has anyone else encountered this issue? What can I do? I'm looking forward to your help. I'm sending you the original BIOS file.
                        Motherboard Name : MS-17K31 Ver 2.0
                        Serial No : K2201N0154214...
                        10-30-2025, 04:53 AM
                      • dotKay
                        Tongfang GM6AR0Q Schematic & Boardview Request
                        by dotKay
                        Hi, All
                        I'm currently in the process of attempting a repair on a Laptop for a family friend of mine and after many hours of searching, the brand it's labelled as being 'Firebat' turns out to be a 'Tongfang GM6AR0Q'
                        If anyone is in possession of or is able to obtain schematic and boardview files for this product, it would be greatly appreciated. Here's more information about the device:
                        Real Name: Tongfang GM6AR0Q
                        Platform: Intel Alder Lake-P (i7-12650H) + RTX 4060
                        Attached is further serial numbers and details surrounding model which could...
                        11-19-2025, 01:29 PM
                      • cr4zychriss
                        by cr4zychriss
                        • Rebrand: PC Specialist
                        11-14-2025, 04:04 PM
                      • master3112
                        GK7MR0R Does not start
                        by master3112
                        Hello everyone.
                        I have a GK7MR0R (XMG Core 17) The device does not start. When I press the power button, the device tries to start and draws 0.8A for a second. According to the schematic, the following voltages should be present in the connected power supply unit and these are also present:
                        +5VALW
                        +3VALW
                        +3VALW_PCH
                        +1.8V_PRIM
                        +1.05VO_OUT_FET
                        The battery is being charged.
                        First I tried to rewrite the BIOS, same behavior.
                        Another user had the same behavior and his chipset was defective. I also changed the chipset, same behavior.
                        05-03-2025, 06:30 PM
                      • TimmyTurner
                        Looking for Tongfang GM5TG0O schematics
                        by TimmyTurner
                        Hello, would anyone have the schematics and/or board view for the Tongfang GM5TG0O (aka XMG Core 15 M21, Avell A70 MOB, Mechrevo Z3 Pro, among others) or a similar model?
                        I'm trying to debug an issue with the webcam module. Actual camera module and eDP cable both replaced already, but issue persists (glitched image, faint LED indicator, perhaps a power issue?). Having the schematics and/or board view would help a lot...
                        05-18-2025, 09:51 PM
