Hello friends, I have a gk7mr0r v1.2 10L motherboard, monster tulpar t7 v20.2, but it looks the same as the tongfang gk7mr0r v1.2 10L motherboard. Does anyone have a bios?
Gk7mr0r v1.2 10l bİos need
Tags: None
Re: Gk7mr0r v1.2 10l bİos need
Post the serial number,and your backup(s) -> https://www.badcaps.net/forum/showthread.php?t=103570
hello
serial number
GK7MR0R2204402539Attached Filesif you find these attachements useful please consider making a small donation to the site
try thisAttached Filesif you find these attachements useful please consider making a small donation to the site
HI This worked for me, I just want to know if you know the address of the DMI to edit it so I have my serial number and everything else I made a post about my problem but no one contributed
https://www.badcaps.net/forum/troubl...-avell-a62-livComment
try..97F000 - 97FFFF
https://www.badcaps.net/forum/troubl...-avell-a62-livDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
TULPAR T5 V19.1 bios dumpAttached Filesif you find these attachements useful please consider making a small donation to the site
by s_specialistMonster Tulpar T7 V25.1 (same MSI GE76 RAIDER 11UG) isn't working. The motherboard outputs 19V, the supply voltages are 3.3V and 5V, the chipset voltage is 1.05V, and the BIOS voltages are all there, but it still isn't working. I replaced the FH82HM570 (SRKMA) and it still isn't working. Has anyone else encountered this issue? What can I do? I'm looking forward to your help. I'm sending you the original BIOS file.
Motherboard Name : MS-17K31 Ver 2.0
Serial No : K2201N0154214...-
Channel: BIOS Requests ONLY!
by dotKayHi, All
I'm currently in the process of attempting a repair on a Laptop for a family friend of mine and after many hours of searching, the brand it's labelled as being 'Firebat' turns out to be a 'Tongfang GM6AR0Q'
If anyone is in possession of or is able to obtain schematic and boardview files for this product, it would be greatly appreciated. Here's more information about the device:
Real Name: Tongfang GM6AR0Q
Platform: Intel Alder Lake-P (i7-12650H) + RTX 4060
Attached is further serial numbers and details surrounding model which could...3 Photos-
11-19-2025, 01:29 PM -
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
by master3112Hello everyone.
I have a GK7MR0R (XMG Core 17) The device does not start. When I press the power button, the device tries to start and draws 0.8A for a second. According to the schematic, the following voltages should be present in the connected power supply unit and these are also present:
+5VALW
+3VALW
+3VALW_PCH
+1.8V_PRIM
+1.05VO_OUT_FET
The battery is being charged.
First I tried to rewrite the BIOS, same behavior.
Another user had the same behavior and his chipset was defective. I also changed the chipset, same behavior.
by TimmyTurnerHello, would anyone have the schematics and/or board view for the Tongfang GM5TG0O (aka XMG Core 15 M21, Avell A70 MOB, Mechrevo Z3 Pro, among others) or a similar model?
I'm trying to debug an issue with the webcam module. Actual camera module and eDP cable both replaced already, but issue persists (glitched image, faint LED indicator, perhaps a power issue?). Having the schematics and/or board view would help a lot...-
- Loading...
