alienware la-k741p
  • brandonhdz9200
    • Jan 2023
    • Mexico
    alienware la-k741p
    Hi i need help, im looking for bios of alienware GDR51 LA-K741P plss :c
  • aboumohamed
    • Dec 2018
    • 258
    • algeria
    Re: alienware la-k741p
    dump ok
      • 20888
      You MUST:
      • ingenieroedu
        • May 2023
        • 69
        • Colombia
        I need help, this computer failed in the update, it froze, it already has no image on the screen
        main model: GDR51 LA K741P Rev 1.0 (A00)
        reg model: P87F
        • hoaca388
          Badcaps
          • Jan 2022
          • 11733
          reg model: P87F
          Service tag ? Service tag ? Service tag ? Service tag ? Service tag ? Service tag ?
          • ingenieroedu
            • May 2023
            • 69
            • Colombia
            Thanks, if I couldn't get it, I have this one:
            Service Tag: 146C8D3​
            • hoaca388
              Badcaps
              • Jan 2022
              • 11733
              Try
              • ingenieroedu
                • May 2023
                • 69
                • Colombia
                Try
                still no image on screen
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11733
                  If this file does not work, you should look for hardware problems.
                  • ingenieroedu
                    • May 2023
                    • 69
                    • Colombia
                    The same thing happens with the file. The strange thing is that the computer did not complete the bios update correctly and now the image does not appear. I still leave a copy of all the chips that the computer has and can someone help me?
                    The device now turns on, it restarts like this several times, then it stays on and the power LED flashes.​
                    • Arshadplasto
                      • Feb 2023
                      • 32
                      • India
                      this one worcking 100% thanks
                      • lolohacko
                        • Apr 2018
                        • 36
                        • Iran
                        i need bios :
                        service tag : GTDK0F3
                        EX : 36604805151
                        main model : GDR51 LA-K741P
                        • peste
                          • 12792
                          • ROMANIA
                          Originally posted by lolohacko
                          i need bios :
                          EX : 36604805151
                          post the contents of the bios chip even if it is corrupted..
                          • drux
                            Alienware Aurora R15 accidentally flashed with XPS 8960 BIOS
                            by drux
                            I've had an ssd that was previously used on dell xps 8960 and then it was installed in Alienware Aurora R15(intel version). On first windows boot in R15 windows started bios update and loaded bios for xps 8960(r15 and xps8960 essentially have same motherboards).
                            Now it has xps 8960 bios that looks different from alienware bios and when I'm trying to run bios update files for R15, I get unsupported platform error.
                            These models have AMI/Aptio BIOS.
                            Tried to edit product info with DMI Edit to change values back to Alienware R15, but it does not want...
                            11-03-2024, 01:18 AM
                          • macabook
                            by macabook
                            🧩 Initial Issue
                            07-24-2025, 02:17 PM
                          • Ian Blanco
                            Alienware 13 R2 Bios Request
                            by Ian Blanco
                            Motherboard: Alienware 13 R2 LA_C901P
                            I have 2 Alienware 13 R2 Bios here and both have password can anyone help me unlock this?...
                            Yesterday, 02:13 PM
                          • Mr.Ultimate
                            Alienware 13R3 bios mod request - to disable dedicated graphics (dgpu failure)
                            by Mr.Ultimate
                            Hi everyone, hope to get someone to help and modify bios rom for me.
                            I need to disable dedicated nvidia graphics chip permanently.
                            GPU chip had failed(cracked silicon DIE) and I can only use laptop without failing if I disable nvidia graphics in dev manager (but it still draws power from battery and generates thermal signature.
                            Ideally if it was disabled from bios at preboot.
                            I believe it is possible, because if I attatch external alienware graphics amplifier , laptop at boot will disable dedicated graphics #1 (failed one) and will only boot with AGA...
                            08-06-2024, 05:15 AM
                          • Arc717
                            How do I flash bios to an Alienware M16 R1 AMD edition?
                            by Arc717
                            I am trying to downgrade my bios on my Alienware so I can undervolt & overclock my CPU, and overclock my ram. I need to get to bios 1.2.2 for this. Dell doesn't allow downgrades, and their bios file is an exe compiled in c++, so I can't decompile it easily. I am wondering if I can flash the bios manually using a usb flasher. I would like to know if this is possible, and if so, where the bios chip would be. I know flashers are pretty cheap and the bios chip is 8-pin. There are two of these chips only when I open the back panel of the laptop. I'm not sure if there are any on the other side of...
                            05-17-2024, 03:34 PM
