HP Elitebook 850 G8 Bios unlock
I noticed that after reading and comparing repeatedly, the EC BIOS is defective. I think the component is defective! Can this be saved without a dump? -
Hello, I hope someone can help me with my password on an HP Elitebook 850 G8
System T76 Ver. 1.15.02
SN:
5CG14043NY
SKU: 4L254EC#ABD
I have attached all the information and added an image file with all the system information
Thank you
ChristianAttached FilesLeave a comment:
first boot press f10 apply factory defaults and exit.
use BCU.
Hello. i need unlock bios for HP 850 g8.
SN: 5CG1351RTTAttached FilesLeave a comment:
My apologies, this is the file from the flash device on the bottom of the board. U366 this should be EC file?
Kind regards,
HesleyLeave a comment:
This is the original bin file:Attached FilesLeave a comment:
After flashing the latest dump i get this messages (ordered the pictures in sequence of pop up).
Could anybody help me?
Kind regards,
HesleyAttached FilesLeave a comment:
Can someone help me with removing bios password.
Hp elitebook 850 G8
SN: 5CG20854QQ
ProdID 50B57EC#ABB
I attached a dump of the windbond 25Q256JVE flash next to the cpu
I suppose this is the main bios, if i'm wrong please correct me.
Kind regards,
Hesley
first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
use BCU. you can permanently disable Absolute lock in BCU.
here's your dmi:
Serial Number: 5CG2260DHL
Product #/SKU: 6L8H9EC#ABD
CT Number: PKPSH00WBGS91D
Description: HP EliteBook 850 G8 Notebook
BuildID: 21WWCVET601#SABD#DABD
Feature Byte: 476J6S6b7B7H7M7R7W7m7saBaEapaqauawbUcAdpdqeMfPguhKhkjhk8mEmVmwn7nVngpDpq.3t
MAC Address : 5C:60:BA:C1:27:53Attached FilesLeave a comment:
Please try one more time
EliteBook 850G8 THX
sn 5cg2260DHLAttached FilesLeave a comment:
Channel: BIOS Requests ONLY!
by STKR123Greetings badcaps community,
I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
I learned that desoldering...10-29-2024, 06:03 AM -
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
07-24-2025, 02:17 PM -
by clrscrplease help me unlock bios password hp elitebook 835 G11
S/N: 5CG50434RD
thanks!...-
by GuestHello,
I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
I assume the BIOS update failed, so I searched for the BIOS chip.
I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
Can the corrupted...-
- Loading...
