Hp 13-ba1016ns - la-j475p rev 1.0
  • javben
    • May 2013
    • 11
    • spain
    Hello all,
    Need clean me region bios file for this laptop.
    Laptop powered on but there is no activity (caps lock not working )neither image
    Model. HP 13-BA1016ns // // SN cnd1086s7v / PRODUCT- 2J6K8EA#ABE
    Org. bin attached.
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: Hp 13-ba1016ns - la-j475p rev 1.0
    Originally posted by javben
    Hello all,
    Org. bin attached.
    Read the chip again.
    Become a Badcaps supporter
    Thanks to all supporters.​
    • elbostan
      EL.BOSTAN TEAM
      • Apr 2012
      • 30
      • egypt
      try this bro
      • javben
        • May 2013
        • 11
        • spain
        Hello Elbostan. sorry for coming back late on this, the laptop were donated to a ONG before i could try this. THANKS ANYWAY!!!!!
        • javben
          • May 2013
          • 11
          • spain
          Why so Vesko 365? "Read the chip again." ?
          • Destroyer-Br
            [HELP] ME Region Cleaning Request – Motherboard GK5MP5X 1.0
            by Destroyer-Br
            I’m working on a laptop in which I replaced the PCH, but I’m unable to clean or rebuild the Intel ME region using FIT.
            When I load my dump into FIT, it only shows the Intel(R) ME Kernel section. The full ME region structure does not appear.
            If I manually replace the ME region inside the decomp folder and try to build the image, FIT does generate an outimage.bin, but the file is corrupted.
            After flashing it, the board does not power on — no signs of life.
            I’ve identified that the issue happens because my original dump does not contain a complete or valid ME...
            11-23-2025, 02:48 PM
          • tom3k
            Dell Precision 5540. Need clean ME Region
            by tom3k
            Laptop: Dell Precision 5540
            MB: LA-H331P Rev: 1.0(A00)
            Hi.
            I am looking for a clean ME Region 12.0.95.2489 Corporate H CNP/CMP-H B, A
            After extracting my BIOS in FIT the ME Region size is 7565 KB.
            However the ME Region files I fouud online are 11688 KB in size.
            Can someone help me find he correct clean ME Region?
            Thanks!
            Code:
            ║ Family │ CSE ME ║
            06-28-2025, 12:34 PM
          • Adenitz
            Clean ME region - a bit of theory
            by Adenitz
            Hello laptop repair experts,
            can someone plese, help me understand the significance of cleaning ME region in a BIOS dump file?
            I know that Manegement Engine (ME) data is part of BIOS/UEFI firmware. I know that it contains some HW specific data for the particular laptop.
            What I don't know, why do I need to clean ME region if I try BIOS dump file from another laptop (of course same type and model). I'm not sure if this is only because of the serial number (not sure if that is stored in ME region at all).
            Recently, I had a two cases where laptops (one is Lenovo Idepad...
            10-21-2023, 04:44 AM
          • mkdj
            by mkdj
            Dear all,
            10-19-2025, 04:41 AM
          • EvazX
            ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
            by EvazX
            I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
            Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
            For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
            However, after some time, the replacement motherboard...
            08-25-2025, 06:09 PM
