Msi pro 660m-a ddr4
  • rmontroni
    • Jun 2023
    • Brazil
    Msi pro 660m-a ddr4
    Greetings.
    I bought this motherboard and a 13600k. I need to flash the BIOS to the version compatible with this processor. Where is the BIOS chip located on this motherboard?
    Is flash possible with the Ch341a Pro?
    This is the BIOS link for that motherboard:
    https://download.msi.com/bos_exe/mb/7D43v1D.zip
    Or I uploaded the attached BIOS
    Can someone send me the BIOS already ready for FLASH?
  • Bonzas
    • 474
    • Indonesia
    Re: Msi pro 660m-a ddr4
    Just extract your file and rename E7D43IMS.1D0 to E7D43IMS.bin fi you want flash with ch341a, it's depending what chip on your motherboard. Pictures from MSI site are too small and i can't see where is the bios chip. Could you send pictures with HD resolutiion ?
    • AkaBukai
      Is it okay to flash stock bios onto the motherboard's BIOS?
      by AkaBukai
      Hi there,
      I have a 14" Lenovo Laptop (Flex 5 14ALC05) which has a boot issue.
      The little LED on the power button is flashing slowly and nothing happen.
      This unit do not have any BIOS button cell battery so I tried many times draining the power but it is still not powering on.
      So I decided to flash the BIOS using a cheap programmer.
      And I was successfully able to read the content (exactly 16MB file) which BTW is a WINBOND 74m12jwsiq (according to the package inscription - but detected as W25Q128FW in the software - IMSProg on Linux)
      I also...
      12-19-2024, 12:15 PM
    • cr4zychriss
      by cr4zychriss
      • Rebrand: PC Specialist
      11-14-2025, 04:04 PM
    • what_1282105
      Thinkpad t480s, completely dead after BIOS flash using CH341A programmer
      by what_1282105
      Following this guide (https://www.reddit.com/r/thinkpad/co...g_and_flashing) i re-flashed my t480s BIOS using an external (CH341A) programmer. The flash didnt work, so i reverted back to my BIOS backup successfully. The BIOS in the chip and the BIOS backup file are identical according to windows' file compare. The revert, however, didnt work: the only thing the computer does is flash the power button 3 times when AC power is connected. I've tried unplugging the CMOS battery, holding the reset button and holding down the power button- no signs of life....
      02-14-2025, 07:27 PM
    • glovecaps
      by glovecaps
      11-25-2024, 04:23 PM
    • GardevoirForEver
      Embedded Controller issues, living an absolute H*LL with my ASUS Vivobook Pro 16X OLED
      by GardevoirForEver
      I've been dealing with so many complications for months, trying to find and then fix the root cause of the issue I really need help and I have to solve this on my own (Going to Asus headquarters isn't an option for me. First, because I'm very stubborn and want to insist that I can fix this sort-of-myself somehow, and second, the location is too far away for me anyway).
      Right now I'm desperate trying to put an end to this nightmare, but OK, I'll do my best to be somewhat brief in explaining and relating the entire situation and context.
      The motherboard of my ASUS...
      11-15-2025, 04:30 PM
