hp chromebook 14 G7 bin FILE REQUEST Please
    Originally posted by lint4u View Post
    You're wellcome
    Thanks for feedback.....glad to hear that
    BR
    Can you help me with this one?
    HP Chromebook 14 G7
    S/N:5CD408B11C
    MB Model: DA00GLMB6I0
      HP Chromebook 14 G7
      S/N:5CD408B11C
      Try and report
        Try and report
        Tried and black screen , just blink white led and no boot, not recovery
          with same method..check if there are any components missing
          and also tried with the lock one and see the result.
            I have already flashed the original bios (backed up from the start) and it still doesn't want to turn on, I was checking the computer and apparently everything is in order, but, checking the ch341 programmer, I noticed that the clip with which I hold the bios doesn't make very good contact and I have my doubts, testing in the neoprogrammer software at the time of checking it gives me a buffer address verification error 0x90 something like that, investigating a little it seems that the ch341 device doesn't receive enough voltage and that's why it gives problems when reading/writing, I have already made the purchase for another device and an extra clip to test, I'll be back after doing my tests and reporting how everything went, I really appreciate the help.
              Hello! A few days ago I wanted to unlock this laptop to be able to activate the developer mode, they helped me here by giving me the already unlocked bios, but when I flashed the bios with the (unlocked) bios it didn't turn on anymore! The led only turns on once when I press the combination (Esc + refresh + power) but it doesn't even start in safe mode, so I tried to flash the original bios again and it still doesn't turn on and it does the same thing!! Then I realized that the clip I used to read the chip wasn't holding well and that maybe I didn't read the backup correctly which I was supposed to do right, some things I already tried:
              -I have access to another laptop that is the same as this one that is functional and I was able to extract the bios, I tried to flash it and it still doesn't turn on.
              -I changed the clip (I bought another new package) and I tried to burn it even on another PC and with the same result
              -I checked the BIOS with an HxD program to compare and I see some notable differences, which make me think that it is corrupt.
              I can unsolder the BIOS since I already have the computer, but at this point I don't know if I can change anything.
              I am attaching the backup of the BIOS that is supposed to be the original.
                SMDFlea commented
                Editing a comment
                Thread merged.
              #27
              try to change the bios chip
                Can you give me a copy of a modified BIOS that works on
                uefi gpt
                HP Chromebook 14 G7
                model: DRAWMAN-RHDN
                  I got a new Laptop can anyone help me to unlock, same case.
                  HP Chromebook 14 G7
                  S/N:5CD3329P69
                    HP Chromebook 14 G7
                    S/N:5CD3329P69
                    try this one,
                    don't forget to donate to this forum....
                      try this one,
                      thank you very much for the help! works perfect!, and yes I am very grateful for the information and help from the forum and its users.
                        Thank you for your feedback...
