I need the bios for Lenovo Yoga S940-14IWL
  • JAK76
    • Jun 2023
    • 8
    • Italy
    I need the correct bios for the Lenovo Yoga S940-14IWL. Bios to be used via eprom programmer (Xgecu TL866II plus or CH341a) . I extracted the .cap from the new bios, but I don't have a backup of the old bios. All in all, I couldn't solve it. THX in advance
    https://***********/file/f*****/AKCN42WW.cap/file
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: I need the bios for Lenovo Yoga S940-14IWL
    Read the rules before posting:
    You must attach files directly to your post instead of linking to external websites
    Become a Badcaps supporter
    Thanks to all supporters.​
    • JAK76
      • Jun 2023
      • 8
      • Italy
      ok , sorry . I understood the error. I need the bin/rom version of : AKCN42WW.cap . for Yoga S940-14IWL.
      • JAK76
        • Jun 2023
        • 8
        • Italy
        how do i directly attach a file to my post ??
        • Vesko356
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          • JAK76
            • Jun 2023
            • 8
            • Italy
            if someone wants to help me, here is the new bios.cap, and the bios backup (but I'm almost sure it's a wrong backup)
            • virginlulu
              • Feb 2019
              • 21
              • China
              your backup is not the original,post the original bin file of the board
              • JAK76
                • Jun 2023
                • 8
                • Italy
                My problem is this too. I did a forced backup with xgecu ii plus, even if it gave me an error. And then xgecu ii plus doesn't support MX25L12872 , so i selected MX25L12873 . Then i flashed the same with something wrong . In short, I made a disaster. and I don't have a healthy backup
                • JAK76
                  • Jun 2023
                  • 8
                  • Italy
                  it impossible to restore a working bios?
                  • virginlulu
                    • Feb 2019
                    • 21
                    • China
                    only need a working bak
                    • virginlulu
                      • Feb 2019
                      • 21
                      • China
                      • JAK76
                        • Jun 2023
                        • 8
                        • Italy
                        It WORKS . Now I "only" have to disassemble the monitor and check the ribbon cable. Yes , the black screen was caused by that and I had mistakenly burned the bios ................
                        Many thanks
                        • virginlulu
                          • Feb 2019
                          • 21
                          • China
                          Many thanks
                          you are welcome
                          • Wahaz
                            by Wahaz
                            10-30-2023, 08:42 PM
                          • HotSaladMan
                            Lenovo ThinkBook 14S Yoga ITL Bad Flash + Need Bios
                            by HotSaladMan
                            *##*#*#*#*#*#Cringe Warning Used Clips for Tl866ii Plus Backups#*#*#*#*#*#
                            Model : Lenovo ThinkBook 14S Yoga ITL
                            S/N : MP28JT19
                            MFG Date : 2022/02/09
                            Factory ID PRC4
                            MO : MPNXB26080FX
                            MTM : 20WE001US
                            MODULE FCC ID : PD9AX201NG
                            IC : 1000M-AX201NG
                            BOARD INFO
                            FLV34 LA-KO51P
                            REV : 1B 2020-08-24
                            Bit of Info
                            Using Tl866ii Plus, it would scan the chip but wouldn't not detect the
                            chip id, so i would always uncheck the id check, so it would bypass the error
                            i did in fact make...
                            11-07-2024, 07:46 AM
                          • beogeek
                            Lenovo Yoga Slim 7 14APU8 Bios Request
                            by beogeek
                            I've currently got a Lenovo Yoga Slim 7 14APU8 that is not posting. Its fan spins, the keyboard lights up, and the caps lock doesn't work. It was taken to some shop for cleaning, and then they updated or tried to update the bios. After that, there was no display and no post. I've removed the bios ic from the board and made a bios dump. I need some assistance going forward, as I suspect this is probably just a bad bios issue. I've tried searching for a dump, but no luck; if anyone can throw me a bone, it would be much appreciated!
                            Attached is the bios dump in the state I received it...
                            10-24-2024, 12:54 PM
                          • baaligoga
                            Help needed in unlocking BIOS Supervisor password - Lenovo X1 Yoga 5th Gen
                            by baaligoga
                            Good day, everyone!
                            I'm encountering an issue with my Lenovo X1 Yoga 5th Gen laptop related to the BIOS supervisor password. I'm seeking assistance and guidance from the knowledgeable members of this community in resolving this problem.
                            I am no expert and cannot perform soldering or unsoldering of the chip from the board. Therefore, I attempted to use an EZP 2023 programmer with a clip to extract the BIOS bin file without removing the BIOS chip from the motherboard. The BIOS chip has the following letters imprinted on it: "Winbond 25Q80DVNIG 2026". I used the...
                            05-20-2023, 09:48 AM
                          • grimacelord
                            Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                            by grimacelord
                            Hello there.
                            I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                            History:
                            1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                            I searched for this error online and discovered...
                            03-15-2023, 03:29 PM
