hp envy x360 2-in-1 15-ey******
  • jacospama
    • Aug 2019
    • 240
    • Ghana
    IPB51 LA-M023P BIOS needed .
    model: 15-ey0013dx
    ProdID: 66B44UA#ABA
    SN#: CND24406T9
    i have attached the old dump
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: hp envy x360 2-in-1 15-ey0023dx
    model: 15-ey0013dx
    ProdID: 66B44UA#ABA
    SN#: CND24406T9
    HP ENVY x360 2-in-1 Laptop 15-ey0xxx bios rev. F.11
    DMI + Windows key offsets: B1000 - B2FFF
    Your Board ID is 08A31 (use file "08A31+Dmi+WinKey.bin")
    Become a Badcaps supporter
    Thanks to all supporters.​
    • jacospama
      • Aug 2019
      • 240
      • Ghana
      Thank You Vesko356. it did not work for me . when i switch no signal and shuts down within 10 seconds. i have tried both files. am gonna edit the dump. the label is incorrect.
      • Vesko356
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        If it's no go, then for sure your problem is not bios related but some hardware fault, it's a virgin bios and I even especially choose the same F.11 version as in your backup in order to exclude possible incompatibility between the bios versions, so grab a multimeter and start troubleshooting the motherboard.
        • jacospama
          • Aug 2019
          • 240
          • Ghana
          the problem was this. black screen,keyboard blinking caps 5 long 3 short. but after flashing, when i switch no signal and shuts down within 10 seconds.
            • 21109
            Check every single ram pin and resolder if neccessary.
            • jacospama
              • Aug 2019
              • 240
              • Ghana
              Thank You SMDFlea. am doing what you ve just said. i will give you the results after
              • jacospama
                • Aug 2019
                • 240
                • Ghana
                it still didnt work
                • saman mawlod
                  • Apr 2022
                  • 56
                  • iraq
                  [QUOTE=Vesko356;n1816630]Re: hp envy x360 2-in-1 15-ey0023dx
                  hp pavilon 15
                  sn/ CND23620M8
                  motherboard code : la-m023p
                  after bios update some driver not installed
                    • 21109
                    [QUOTE=saman mawlod;n3238996]
                    hp pavilon 15
                    sn/ CND23620M8
                    Your model number is 15-ey0502sa (6L7L3EA) . The current thread title " hp envy x360 2-in-1 15-ey0023dx" will be changed to "hp envy x360 2-in-1 15-ey****** "
                    Your BID is 08A31 .Read post 2 ,the DMI is at the same offsets.
                    [Guide] How to find the right HP bios version to flash - https://www.badcaps.net/forum/troubl...flash?t=122195
                    [Guide] How to extract ready for programming dump from HP update executable file - https://www.badcaps.net/forum/troubl...-file?t=121948
                    • saman mawlod
                      • Apr 2022
                      • 56
                      • iraq
                      [QUOTE=SMDFlea;n3239018]
                      model is hp 15-ey0502sa
                      post 2 bios is unlock mode msg
                      original bios in website is 013a8
                    • saman mawlod
                      • Apr 2022
                      • 56
                      • iraq
                      [QUOTE=saman mawlod;n3239038]
                      full working but have message on start up program file is unlock mode
                    • reeza_plus
                      • Aug 2015
                      • 56
                      • canada
                      Model: hp envy x360 2-in-1 15-ey0008ca
                      SN: CND306105M
                      PRODUCT ID: 6R512UA#ABL
                      MOTHER BOARD MODEL: IPB55 LA-M025P REV:1.0
                      ISSUE: NO DISPLAY
                      PLEASE FIX THANK YOU.
                        • 21109
                        SN: CND306105M
                        ISSUE: NO DISPLAY
                        Read the guide at post 10 [Guide] How to find the right HP bios version to flash ,that will help you find the BID .When you find your BID you can use the virgin bios at post 2 . The DMI in your bios is at the same offsets given at post 2 . Copy it from your backup using a hex editor and paste it into the new bios, and your bios is ready to program.
                        • volinakis
                          • Jan 2021
                          • 2743
                          • N/A
                          SN: CND306105M
                          ISSUE: NO DISPLAY
                          try
                          • reeza_plus
                            • Aug 2015
                            • 56
                            • canada
                            Originally posted by volinakis
                            try
                            tried programming still same i think hardware issue caps lock blinks 5 long and 3 short
                              SMDFlea commented
                              Editing a comment
                              Common problem is loose ram slot pins or cracked solder balls under the CPU.
                          • volinakis
                            • Jan 2021
                            • 2743
                            • N/A
                            remove main battery, CMOS battery and hold power button 30s. then plug ac adapter only, see what happens. And also check soldering.
                            • Kiki Cares
                              • Feb 2022
                              • 29
                              • Nigeria
                              I need CleanMe file for
                              Hp Envy x360 2-in-1 Laptop 14-es0xxx
                              SN:::8CG31101WY
                              BOARD-NUM------Nittyany RPL 8L 448.OT40.001Q 213224-1Q
                                • 21109
                                SN:::8CG31101WY
                                Off topic, this thread is for 15-ey****** models, not 14-es
                                • prudence
                                  • Oct 2019
                                  • 10
                                  • Zimbabwe
                                  Model: Hp ENVY x360 2-in-1 15-ey1045c1
                                  SN: CND327068V
                                  Motherboard #: IPB55 LA-M025P ReV :1
                                  Problem: BIOS CORRUPTED
                                  Please help fix this file
                                    HP ENVY x360 ENVY x360 - 15-dr1011na Hybrid (2-in-1) 15 Specification for Upgrade or Repair
                                    This specification for the HP ENVY x360 ENVY x360 - 15-dr1011na Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 - 15-dr1011na boardview and ENVY x360 - 15-dr1011na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                    09-06-2024, 12:18 PM
                                    HP ENVY x360 ENVY x360 Convert15-dr1013na 7PW22EA Hybrid (2-in-1) Specification for Upgrade or Repair
                                    This specification for the HP ENVY x360 ENVY x360 Convert15-dr1013na 7PW22EA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 Convert15-dr1013na 7PW22EA boardview and ENVY x360 Convert15-dr1013na 7PW22EA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                    09-06-2024, 11:17 AM
                                    HP ENVY x360 ENVY x360 Convert 15-ds0502saBundle 6TD07EA Hybrid (2-in-1) Specification for Upgrade or Repair
                                    This specification for the HP ENVY x360 ENVY x360 Convert 15-ds0502saBundle 6TD07EA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 Convert 15-ds0502saBundle 6TD07EA boardview and ENVY x360 Convert 15-ds0502saBundle 6TD07EA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                    HP ENVY x360 ENVY x360 15-cn0755nd Notebook Specification for Upgrade or Repair
                                    This specification for the HP ENVY x360 ENVY x360 15-cn0755nd Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 15-cn0755nd boardview and ENVY x360 15-cn0755nd schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                    09-06-2024, 06:51 AM
                                    HP ENVY x360 ENVY x360 - 15-cn0008ng Hybrid (2-in-1) Specification for Upgrade or Repair
                                    This specification for the HP ENVY x360 ENVY x360 - 15-cn0008ng Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 - 15-cn0008ng boardview and ENVY x360 - 15-cn0008ng schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                    09-06-2024, 06:50 AM
