i need a help unlock 645 g9
https://www.badcaps.net/donate -
طلب إلغاء قفل HP 645 G9
SN 5CD3178WDX
PRODIT 5UOU2AV
HP ELITEBOOK 645 G9
MAC ADDRESS 54 EE 75 AC EF FD
مرحبًا ، لقد قمت بقفل جهاز hp g645 g9 الخاص بي بكلمة مرور مطلقة وكلمة مرور المسؤول ولا يمكنني إزالتها، وسأكون ممتنًا للغاية لأي مساعدة. فيما يلي ملفات التفريغ الخاصة بالملفات الرئيسية وEC، شكرًا مقدمًا pain
Attached Filesif you find these attachements useful please consider making a small donation to the site
This is an English-speaking forum. If you don't know English, use google translator.طلب إلغاء قفل HP 645 G9
SN 5CD3178WDX
PRODIT 5UOU2AV
HP ELITEBOOK 645 G9
https://translate.google.com↵
https://www.badcaps.net/donateComment
SN 5CD3178WDX
هذا منتدى يتحدث باللغة الإنجليزية. إذا كنت لا تعرف الإنجليزية، استخدم مترجم جوجل.
brudt 5UOU2AV
ADRESS MAC 54 EE 75 AC EF FD
hp g645Comment
hi try and feedbackAttached Filesif you find these attachements useful please consider making a small donation to the site
Please help me I reprogrammed the two SIM cards with the original ec & spi files and it no longer boots
Unfortunately the device is dead
If it no longer boots with the original ones then youve dislodged a resistor, damaged the bios chips from excessive heat or broken the traces.Comment
Unfortunately, I did not take pictures beforehand until it was too lateAttached Filesif you find these attachements useful please consider making a small donation to the site
Hp EliteBook 645 g9 unlock request!
Thanks in advance
SN:5CD309D9RNAttached Filesif you find these attachements useful please consider making a small donation to the site
try
first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
use BCU.
Serial Number: 5CD309D9RN
Product #/SKU: 5Y3J2EA#ABZ
CT Number: PQGUV018JHS01N
Description: HP EliteBook 645 14 inch G9
BuildID: 22WWTPBT602#SABZ#DABZ
Feature Byte: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbhcAdpdqfPguhKhkjhk8mEn7nWnwpDpqqjqz.gY
MAC Address : 7C:4D:8F:A7:E5:A2Attached Filesif you find these attachements useful please consider making a small donation to the site
Please unlock HP ELITEBOOK 645 G9 S/N : 5CD2399NYP
this is Bios and Ec file
Thanks in advanceAttached Filesif you find these attachements useful please consider making a small donation to the site
try
use BCU.
Serial Number: 5CD2399NYP
Product #/SKU: 715C0EC#ABF
CT Number: PPVBN038JH51VR
BuildID: 22WWTPBT602#SABF#DABF
Feature Byte: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbhcAdpdqfPguhKhkjhk8mEn7nWnwpDpFpqqjqz.tr
MAC Address : 38:CA:84:AB:EB:C7
help me unlock hp elitebook 645 g9
PROD ID 6J5H9AV
SN: 5CD3291QTK
Tried myself but didn't work.
Hello, I have been lurking the forums for a few hours and just wanted to make sure my understanding of the process is correct. From what I can tell, none of the HP flash tools will work for this laptop (645 G9), and the BIOS must be manually edited by someone. From my understanding you cannot just remove the password from the BIOS and reflash it, the entire DMI must be erased. I believe only the SPI ROM chip is flashed, and the EC ROM chip is not touched. I have read Rex98's process for the first two boots after flashing a new BIOS. Then the HP BCU is used to edit the BIOS DMI values back to their factory values. Are there any resources for learning how to manually edit the BIOS dump myself? I am waiting on a CH341A flash tool to arrive so it would be cool to learn how the BIOS files are being edited. If it's just easier for me to post the dump here and have someone do it for me I understand.
I have tried searching on the forums for more info, but the few threads I have seen asking a similar question were just hijacked by people asking "please fix BIOS".Comment
Slightly off topic, I have a 645 G9 here with Ryzen 5 PRO 5675U.
Could anyone please measure the resistance to ground on the leftmost coil/inductor to the CPU.
Mine is 2.2 Ohms, which doesn't look good to me 😢
I have one which has a blown inductor component above the driver chip to this coil, and I am wondering whether the CPU is shorted/dead.
Thanks to everyone willing to give a value.Comment
hello guyz i have an hp elitebook 645 G9
i got it when both chips are missing
kindly provide me with new files because i have the flat chips with me
i will re-program afresh
thanks
HP ELITEBOOK 645 G9
S:N_5CD3029XJJ
PRD ID: 724B0EA#ABU
Board No_ DA0X9SMB8D0 REV
Channel: BIOS Requests ONLY!
by Godfather79Hello everyone in the community
Dear Sir,
I need help removing/unlocking the BIOS Service Tag password on my Dell Latitude 5520 laptop.
Problem details:
* Model: Dell Latitude 5520.
* Board ID (from BIOS file): TGL MB 8L 19819-1 (Southpeak15).
* Required Password Code: 3FE2 (BIOS Service Tag Lockout Code).
* Service Tag: (HMHJQ93)
* BIOS Status: I successfully modded the BIOS file and created FINAL_CLEANED_ME.bin (32MB) with a clean ME region (CSME 15.0), because the original dump was corrupt.
What I need:
Please help me generate...-
Dear Sir,
Problem details:
* Service Tag: (Enter your actual Service Tag from the laptop here)
* BIOS Status: I successfully modded the BIOS file and created FINAL_CLEANED_ME.bin (32MB) with a clean ME region (CSME 15.0), because the original dump was corrupt....-
by NopslideHello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....-
by outsiderHello
I removed the BIOS password thanks to the help of one of the friends of this forum.
https://www.badcaps.net/forum/troubl...61#post3637661
The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...-
- Loading...
