i need a help unlock 645 g9
  • farouk_1994
    • Mar 2021
    • 402
    • algeria
    hello please i need hp elitebook 645 G9 bios unlock 5CD302J1P5
    • minhdigital
      • Nov 2022
      • 766
      • Vietnam
      Send to you
      • farouk_1994
        • Mar 2021
        • 402
        • algeria
        Originally posted by minhdigital
        Send to you
        It's just blinking on charger no turn on
        can you unlock this file i extracted it from hp website and it work but the same issue bios pw
        • qayyum786
          • Aug 2018
          • 1959
          • INDIA
          try from post #13 its extracted from hp support
          • farouk_1994
            • Mar 2021
            • 402
            • algeria
            the same issue just led blinking
            • farouk_1994
              • Mar 2021
              • 402
              • algeria
              #26
              need to unlock this file
              my laptop turn on with this file
              • ymifdal
                • Jan 2022
                • 120
                • Morocco
                #27
                qayyum786 Which one to write? Main only or both MAIN and EC ??
                • rex98
                  • Feb 2023
                  • 1297
                  • Mandaue CEBU, Philippines
                  #28
                  upload the main bios.
                  • farouk_1994
                    • Mar 2021
                    • 402
                    • algeria
                    #29
                    THIS IS THE MAIN BIOS
                    • rex98
                      • Feb 2023
                      • 1297
                      #30
                      try only flash this main.
                      first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
                      use BCU
                      here's your DMI:
                      Serial Number: 5CD302J1P5
                      Product Number: 724B0EA#ABU
                      CT Number: PPVBU018JHM0TK
                      Description: HP EliteBook 645 14 inch G9
                      build_id: 22WWTPBT602#SABU#DABU
                      Feature Byte:
                      MAC Address: 7C-4D-8F-11-47-49​
                      • ymifdal
                        • Jan 2022
                        • 120
                        • Morocco
                        #31
                        Try
                        in case of MPM error use HP BCU
                        Could you specify ?? I asked twice if I should write both chips to try or only the MAIN
                        • farouk_1994
                          • Mar 2021
                          • 402
                          • algeria
                          #32
                          use BCU
                          here's your DMI:
                          Feature Byte:
                          Hello sir thank you for your replay but the pass still exist
                          • danito
                            • Jun 2016
                            • 1260
                            • Romania
                            #33
                            try
                            • ymifdal
                              • Jan 2022
                              • 120
                              • Morocco
                              #34
                              Originally posted by ymifdal
                              Thanks that worked like a charm!
                              As for the DMI info I did the setconfig txt file since I had already saved it beforehand
                              If you could clear me this too I had 2 laptops I thought I could figure the trick myself.. 😵
                              I still haven't figured out a solution for this one.. When I try the MAIN patching method the laptop doesn't start and whenever I press power button the caplocks keeps blink..
                              Anybody have any thoughts to help with? (some patched bios started the laptop but lock still there)
                              • ymifdal
                                • Jan 2022
                                • 120
                                • Morocco
                                #35
                                UPDATE: faulty WSON problem solved by writing patch on a new ic
                                Thanks all who helped pals
                                • farouk_1994
                                  • Mar 2021
                                  • 402
                                  • algeria
                                  #36
                                  Hello need bios unlock for hp 645 G9
                                  SN:5CD3073292
                                  • rex98
                                    • Feb 2023
                                    • 1297
                                    #37
                                    SN:5CD3073292
                                    use BCU
                                    here's your DMI:
                                    Serial Number: 5CD3073292
                                    Product #/SKU: 715C0EC#ABF
                                    CT Number: PPVBN018JHP3A1
                                    BuildID: 22WWTPBT602#SABF#DABF
                                    Feature Byte: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbhcAdpdqfPguhKhkjhk8mEn7nWnwpDpFpqqjqz.tr
                                    MAC Address : 7C:4D:8F:9B:F0:4C​
                                    • farouk_1994
                                      • Mar 2021
                                      • 402
                                      • algeria
                                      #38
                                      use BCU
                                      here's your DMI:
                                      Thank's for replay but Always password
                                      • danito
                                        • Jun 2016
                                        • 1260
                                        • Romania
                                        #39
                                        use BCU
                                        here's your DMI:
                                        try
                                        • farouk_1994
                                          • Mar 2021
                                          • 402
                                          • algeria
                                          #40
                                          Originally posted by danito
                                          try
                                          The same issue pass stil existe
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Godfather79
                                            Dell Latitude 5520 3FE2 Bios password Unlock Request (TGL SuothPeak15)
                                            by Godfather79
                                            Hello everyone in the community
                                            Dear Sir,
                                            I need help removing/unlocking the BIOS Service Tag password on my Dell Latitude 5520 laptop.
                                            Problem details:
                                            * Model: Dell Latitude 5520.
                                            * Board ID (from BIOS file): TGL MB 8L 19819-1 (Southpeak15).
                                            * Required Password Code: 3FE2 (BIOS Service Tag Lockout Code).
                                            * Service Tag: (HMHJQ93)
                                            * BIOS Status: I successfully modded the BIOS file and created FINAL_CLEANED_ME.bin (32MB) with a clean ME region (CSME 15.0), because the original dump was corrupt.
                                            What I need:
                                            Please help me generate...
                                            Today, 07:13 AM
                                          • Godfather79
                                            Dell Latitude 5520 3FE2 Bios password Unlock Request (TGL SuothPeak15) bios
                                            by Godfather79
                                            Dear Sir,
                                            Problem details:
                                            * Service Tag: (Enter your actual Service Tag from the laptop here)
                                            * ​BIOS Status: I successfully modded the BIOS file and created FINAL_CLEANED_ME.bin (32MB) with a clean ME region (CSME 15.0), because the original dump was corrupt....
                                            11-08-2025, 10:04 AM
                                          • Nopslide
                                            by Nopslide
                                            04-01-2024, 04:27 PM
                                          • outsider
                                            Panasonic FZ-G1 MK5 - BIOS password returning
                                            by outsider
                                            Hello
                                            I removed the BIOS password thanks to the help of one of the friends of this forum.
                                            https://www.badcaps.net/forum/troubl...61#post3637661
                                            The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                            06-17-2025, 12:51 AM
