i need a help unlock 645 g9
  • farouk_1994
    • Mar 2021
    • 393
    • algeria
    hello please i need hp elitebook 645 G9 bios unlock 5CD302J1P5
    • minhdigital
      • Nov 2022
      • 758
      • Vietnam
      Send to you
      • farouk_1994
        • Mar 2021
        • 393
        • algeria
        Originally posted by minhdigital
        Send to you
        It's just blinking on charger no turn on
        can you unlock this file i extracted it from hp website and it work but the same issue bios pw
        • qayyum786
          • Aug 2018
          • 1933
          • INDIA
          try from post #13 its extracted from hp support
          • farouk_1994
            • Mar 2021
            • 393
            • algeria
            the same issue just led blinking
            • farouk_1994
              • Mar 2021
              • 393
              • algeria
              #26
              need to unlock this file
              my laptop turn on with this file
              • ymifdal
                • Jan 2022
                • 116
                • Morocco
                #27
                qayyum786 Which one to write? Main only or both MAIN and EC ??
                • rex98
                  • Feb 2023
                  • 1281
                  • Mandaue CEBU, Philippines
                  #28
                  upload the main bios.
                  • farouk_1994
                    • Mar 2021
                    • 393
                    • algeria
                    #29
                    THIS IS THE MAIN BIOS
                    • rex98
                      • Feb 2023
                      • 1281
                      #30
                      try only flash this main.
                      first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
                      use BCU
                      here's your DMI:
                      Serial Number: 5CD302J1P5
                      Product Number: 724B0EA#ABU
                      CT Number: PPVBU018JHM0TK
                      Description: HP EliteBook 645 14 inch G9
                      build_id: 22WWTPBT602#SABU#DABU
                      Feature Byte:
                      MAC Address: 7C-4D-8F-11-47-49​
                      • ymifdal
                        • Jan 2022
                        • 116
                        • Morocco
                        #31
                        Try
                        in case of MPM error use HP BCU
                        Could you specify ?? I asked twice if I should write both chips to try or only the MAIN
                        • farouk_1994
                          • Mar 2021
                          • 393
                          • algeria
                          #32
                          use BCU
                          here's your DMI:
                          Feature Byte:
                          Hello sir thank you for your replay but the pass still exist
                          • danito
                            • Jun 2016
                            • 986
                            • Romania
                            #33
                            try
                            • ymifdal
                              • Jan 2022
                              • 116
                              • Morocco
                              #34
                              Originally posted by ymifdal
                              Thanks that worked like a charm!
                              As for the DMI info I did the setconfig txt file since I had already saved it beforehand
                              If you could clear me this too I had 2 laptops I thought I could figure the trick myself.. 😵
                              I still haven't figured out a solution for this one.. When I try the MAIN patching method the laptop doesn't start and whenever I press power button the caplocks keeps blink..
                              Anybody have any thoughts to help with? (some patched bios started the laptop but lock still there)
                              • ymifdal
                                • Jan 2022
                                • 116
                                • Morocco
                                #35
                                UPDATE: faulty WSON problem solved by writing patch on a new ic
                                Thanks all who helped pals
                                • farouk_1994
                                  • Mar 2021
                                  • 393
                                  • algeria
                                  #36
                                  Hello need bios unlock for hp 645 G9
                                  SN:5CD3073292
                                  • rex98
                                    • Feb 2023
                                    • 1281
                                    #37
                                    SN:5CD3073292
                                    use BCU
                                    here's your DMI:
                                    Serial Number: 5CD3073292
                                    Product #/SKU: 715C0EC#ABF
                                    CT Number: PPVBN018JHP3A1
                                    BuildID: 22WWTPBT602#SABF#DABF
                                    Feature Byte: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbhcAdpdqfPguhKhkjhk8mEn7nWnwpDpFpqqjqz.tr
                                    MAC Address : 7C:4D:8F:9B:F0:4C​
                                    • farouk_1994
                                      • Mar 2021
                                      • 393
                                      • algeria
                                      #38
                                      use BCU
                                      here's your DMI:
                                      Thank's for replay but Always password
                                      • danito
                                        • Jun 2016
                                        • 986
                                        • Romania
                                        #39
                                        use BCU
                                        here's your DMI:
                                        try
                                        • farouk_1994
                                          • Mar 2021
                                          • 393
                                          • algeria
                                          #40
                                          Originally posted by danito
                                          try
                                          The same issue pass stil existe
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Nopslide
                                            by Nopslide
                                            04-01-2024, 04:27 PM
                                          • BlackVisor
                                            How to Decode BIOS password for RedmiBook Pro15 2022 6800H
                                            by BlackVisor
                                            RedmiBook Pro 1542022 6800H
                                            SKU: TM2113-39463
                                            Model Number: RMA2204-AB
                                            CMIIT ID: 2022AP1835
                                            SN: 39463/22WD01355
                                            BIOS version: RMARB5B0P1010 20230628
                                            1. I bought this laptop from flea market, and the seller said that he had never set a password, however here is a password required when pressing F2 to enter BIOS.
                                            2. And after entering incorrrect password 3 times, there is no any useful information like "recovery code"
                                            3. I used universal bios backup tool, and dumped 8MB bin file, but hex code after "SystemSupervisorPw" is...
                                            01-14-2024, 06:35 AM
                                          • outsider
                                            Panasonic FZ-G1 MK5 - BIOS password returning
                                            by outsider
                                            Hello
                                            I removed the BIOS password thanks to the help of one of the friends of this forum.
                                            https://www.badcaps.net/forum/troubl...61#post3637661
                                            The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                            06-17-2025, 12:51 AM
                                          • RMDUiFT
                                            Should I buy a Lenovo Thinkpad E495 with bios password?
                                            by RMDUiFT
                                            Good day. I apologize if I posted this in the wrong topic. I saw somebody selling a Thinkpad E495 with a Ryzen 3500U CPU near me. In the pictures the laptop is running windows 10. I contacted the seller and asked a few questions about upgradability and if it has a bios password on it. He confirmed it has a bios password. I searched through the forum, I found a guide regarding removing the bios password using the autopatcher, I also found a thread with the e495 where people requested help with unlocking the bios password.
                                            I have a few questions:
                                            • If I would buy this laptop and have
                                            08-25-2024, 09:00 AM
