Hello every one, i need a help unlock 645 g9
645 14 G9 unlock password
please unlock my bios dumpAttached Files -
Become a Badcaps supporter
Thanks to all supporters.​
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
Re: 645 14 G9 unlock password
Modify only this file, leave the other one as is.
At 1st boot press F10 and RESET BIOS to factory defaults, save, restart and password will go on. After that enter in bios setup and in Main tab you have "set machine unique data" and write there what it's written on the label inside the cover. Or extract DMI from your bios dump:
Feature Byte: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbhcAfPgSguhKjhk8mEn7nWpDpnpqprqjqz.N2 (no spaces)
Serial: 5CD3031X3G
SKU: 6U8L5LC#ABM
Build ID: 22WWTPCZ601#SABM#DABM
Board CT: PPVBR018JHM00X
Name: HP EliteBook 645 G9
Save and use BCU to exit MPM mode or restart laptop/desktop how many times counter shows.
REMOVE CMOS BATTERY BEFORE WRITING BIOS!Attached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
please help to unlock this g645, i was editing other dumps from other hp models with success but i give up with this one
thanks in advanceAttached FilesComment
Re: i need a help unlock 645 g9
hp 645 g9 unlock request
hi i have hp g645 g9 locked with absolute and admin password and i cant remove it ,any help will be greatly aprecciated
here are my 2 dumps from main and EC
Re: hp 645 g9 unlock request
Read the rules before posting:
RULES UPDATE for BIOS requests/offers *AVOID BANNING, READ BEFORE POSTING*.
You MUST:- Read BIOS guides, methods, resources and tools
- Try the method at BIOS guides, methods, resources and tools before requesting help
- Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
- Use search function in case someone already answered your request
- Post under a related thread if it exists
- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
- Name your thread with model numbers and request
- Provide a BIOS/EC dump if possible
- Attach files directly to your post instead of linking to external websites
- Post what the problem is, be specific - black screen, no boot, running slow, password.
Do NOT post "clean me", "clear bios", "clean bios", "bios need" or other such terms
Requests for password removal or BIOS repair for which the method is available at BIOS guides, methods, resources and tools will not be tolerated anymore if you do not explain why you did not succeed.
.Comment
hi SMDFlea
sorry if a break some rules, is not my intention , am asking for help ,because i used to clean my hp dumps using a guide from this forum https://www.badcaps.net/forum/showpo...1&postcount=65
i tried to re edit my ec dump but i failed to make it work ,but i always got f8 key blinking in yellow and the caps lock blinking in white
due to english is not my native language i do my best to read the forum rules to not be taken as one hit and run user
i leave machine model number and board number also both dumps main and ec
hp elitebook 645 g9
DAX9SFMB8A1 REV A
thanks and i appologize if i did something wrong
i did a donation and i will be doing more today
Hi guys I've tried on this password previous HP unlock methods but nothing seem to work
Here are both chips, any help would be appreciated
HP EliteBook 645 g9, SN#5CD3291TDG
DAX9SFMB8A1 REV:A​Attached FilesComment
Try
in case of MPM error use HP BCUComment
first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
use BCU
here's your DMI:
Serial Number: 5CD3291TDG
Product Number: 6J5H9AV
CT Number: PREBK068JIB12R
Description: HP EliteBook 645 14 inch G9
build_id: 22WWTPCZ601#SABF#DABF
Feature Byte: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbhcAfPguhKhkjhk8mEn7nWpDpFpnpqprqjqz.Hg
MAC Address: BC-0F-F3-8A-33-43Comment
Thanks that worked like a charm!
As for the DMI info I did the setconfig txt file since I had already saved it beforehand
If you could clear me this too I had 2 laptops I thought I could figure the trick myself.. 😵Attached FilesComment
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
use BCU
here's your DMI:
Serial Number: 5CD3291R3D
CT Number: PREBK068JIB04V
MAC Address: BC-0F-F3-8A-2E-7FComment
