Need bios for hp 15s-eq1005nx
  • napilsas
    • Mar 2016
    • 10
    • saudia arabia
    please I need a working BIOS bin file for HP 15s-eq1005nx motherboard da0p5gmb6h1 REV. H
    Thank you.
  • hardware1
    • Sep 2021
    • 2946
    • N/A
    Re: Need bios for hp 15s-eq1005nx
    Thank you.
    Upload your Original BIOS here and write your Device Serial Number.
    all donations are welcome,
    • napilsas
      • Mar 2016
      • 10
      • saudia arabia
      thank you
      sorry I think that is problem with bios chip so I can't read it
      I use new chip
      serial number : 5CD14434ZQ
      • hardware1
        • Sep 2021
        • 2946
        • N/A
        thank you
        I use new chip
        Try those files one by one, it's Virgin files from HP.
        I bet on (08707) file, If your CPU is "AMD Ryzen 5 4500U".
        • napilsas
          • Mar 2016
          • 10
          • saudia arabia
          try those files one by one, it's virgin files from hp.
          I bet on (08707) file, if your cpu is "amd ryzen 5 4500u".
          thank you
          • Friend33
            Changing BIOS Serial Number After Motherboard Replacement on EliteBook x360 G3
            by Friend33
            I have an EliteBook x360 G3 where I had to replace the motherboard. Everything is working fine and there are no errors during boot. However, I have the issue that the serial number in the BIOS is incorrect. When I run the DMI tool under Windows, I get an error stating that I am not in Unlocked Mode and therefore cannot make any changes. I was able to change the Asset Tag directly in the BIOS. Now I am wondering, can I simply read the BIOS chip, change the serial number with a hex editor, and write it back, or what other options do I have? The old motherboard did not work at...
            06-16-2024, 03:13 PM
          • iZakre
            HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
            by iZakre
            Hello everybody!
            To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
            The thing is that I had installed TeamViewer and could log into the computer...
            02-19-2023, 02:27 PM
          • baletak
            Lenovo T490 - motherboard serial - windows licence lost - after corrupt bios chip replacement
            by baletak
            had T490 with faulty bios chip. Bought chip out of ebay and soldered on. Laptop starts and works however serial numbers of laptop and motherboard do not match.
            I have updated laptop model number.
            1) I did not find the way to update laptop serial number - I have this one.
            2) I dont know where to get my motherboard serial number and how to update it. Is it somewhere physically on the mainboard? How do I update it?
            Hope to find someone to help me with this as I am hitting dead end at the moment.
            Many thanks
            Miro
            05-23-2025, 01:21 AM
          • Citymin
            by Citymin
            S/N : 5RNK9FFT70...
            08-05-2025, 05:12 AM
          • m1ch43lzm
            by m1ch43lzm
            Hi everyone
            09-06-2025, 05:47 PM
