I need bios X515EA - X415EA Rev 6.1
  • buihoanganh1998
    • Feb 2019
    • VietNam
    I need bios Asus X515EA Mainboard X415EA R6.1
    Orginal bios no display .I flashed 1 bios but not work SSD m.2 and keyboard
    Thanks forum!
    • 21048
    Re: I need bios X515EA - X415EA Rev 6.1
    Thanks forum!
    https://www.badcaps.net/forum/showth...ghlight=X415EA
    Read that whole thread. If you have X515EA on the motherboard QR code you can use the bios from post #4, add your own DMI using the script and guide at popst #13 ,and get the SSD working thanks to Vesko at post #15
    • Vusal
      Senior Tech
      • Feb 2016
      • 41
      • Azerbaycan
      X415EA Rev 6.1 BIOS need
      There is a bios file for this model on the official site. I wanted to edit, but the original bios was changed in another service. That's why I couldn't edit. I tried several bios from the forum. Unfortunately, in some cases, the SSD was not detected or the keyboard did not work. I don't understand what this nonsense is about these new generations.
      Thank you in advance
        • 21048
        Re: X415EA Rev 6.1 BIOS need
        Read post #2 and https://www.badcaps.net/forum/showthread.php?t=103570 .Post the original bios backup and laptop serial number.
        • Vusal
          Senior Tech
          • Feb 2016
          • 41
          • Azerbaycan
          unfortunately there is no original BIOS dump
          • _F.fernan
            • Dec 2014
            • 73
            • Philippines
            GOOD DAY SIR!!!
            I NEED BIOS X415EA R6.1
            laptop model code is X415E
            serial is N3N0CV054128094
            tried bios from post #4 on this thread https://www.badcaps.net/forum/showth...ghlight=X415EA and i had a display and ssd is working fine but not the keyboard .
            should i put my dmi info on the bios file or do i need another bios file
            here is my dump .
            • _F.fernan
              • Dec 2014
              • 73
              • Philippines
              update:
              i put my dmi info and still keyboard malfuntion .
              • minhdigital
                • Nov 2022
                • 758
                • Vietnam
                Originally posted by _F.fernan
                GOOD DAY SIR!!!
                here is my dump .
                Send to you, try and feedback
                • _F.fernan
                  • Dec 2014
                  • 73
                  • Philippines
                  Thanks brother !
                  It works fine .
                  where did you get the file ? can you share ? TIA ☺
                  • dhan
                    • Jun 2018
                    • 134
                    • hp
                    HELLO. I just need to remove password, or know the password.
                    I used the bin file above at post number 8,
                    it works but the SSD can't be formatted.
                    it shows in the bios menu but unable to format.
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11821
                    Serial ?
                    • dhan
                      • Jun 2018
                      • 134
                      • hp
                      Originally posted by hoaca388
                      Serial ?
                      serial: N3N0CV02K24409E
                      model: X415E
                      board model: X415EA R6.1
                      • volinakis
                        • Jan 2021
                        • 2741
                        • N/A
                        model: X415E
                        try
                        • cüneyt
                          payla?mak güzel
                          • Aug 2021
                          • Türkiye
                          m2 ssd yi windows kurarken görünmezse biostan WMD yi kapatın
                          [MOD EDIT] Translated to english - If m2 ssd is not visible while installing windows, disable WMD from bios
                            • 21048
                            Post in English ! .Please do not post boardviews here,this is only for bios requests.Post boardviews/schematics/Repair guides in the "Schemaic requests ONLY!" section --> https://www.badcaps.net/forum/troubl...-requests-only
                            • sobhan_vahed
                              • Jun 2024
                              • 8
                              • iran
                              hi. i have x515ep laptop mainboard x415ea rev6.1
                              i have m2 and keyboard issue. i have tried a lot of file and most of them m2 was ok but keyboard not working.
                              i have tried your file here and it still have keyboard issue. i have use the dmi script and moved dmi data in your bios but still keyboard not detected.
                              here my back up and serial number. can u please help me with my original file for m.2 and keyboard please? thanks a lot.
                              serial number : r4n0cv10y615168
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11821
                                Use programmer to extract bios, no software.
                                • sobhan_vahed
                                  • Jun 2024
                                  • 8
                                  • iran
                                  Thank you for your response, but I didn't fully understand what you meant. If you were referring to using a programmer to program the BIOS files, I have already programmed all the files I tested with the programmer. Now, my problem is that the keyboard is not being recognized, and it seems that the BIOS needs to be edited.
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 11821
                                    https://www.badcaps.net/forum/troubl...rces-and-tools
                                    • leva2407
                                      • Jul 2016
                                      • 89
                                      • tbilisi
                                      hi gays please help me to unlock asus X415EA-EB512
                                      SN: M8N0CV19W777354
                                      CN:ZYR
                                      MFD:2021-08
                                      • peste
                                        peste commented
                                        Editing a comment
                                        post merged..
                                    • exerion5000
                                      Bios Needed For Asus X515EA Pcb X415EA R2.0
                                      by exerion5000
                                      Asus X515EA_No Power_GD25B127D@SOIC8.rar
                                      Hi Everyone! , i need repair the original bios corruptes of this model machine (Bios Needed For Asus X515EA Pcb X415EA R2.0) , the unit no power on , i test several bios for this model with some issues maybe related to especific version (keyboard partially work or no work , SSD no detected ,Etc ) so y let more data below if help , many thanks in advance!...
                                      02-17-2025, 01:34 PM
                                    • macabook
                                      by macabook
                                      🧩 Initial Issue
                                      07-24-2025, 02:17 PM
                                    • Exclikers
                                      ASUS X515EA - X415EA Rev 6.0 Bios Bin
                                      by Exclikers
                                      Hi, Please help me with my laptop, I have this ASUS X515 that has BIOS password. I try to flash with BIOS X415EA Rev 2.0 but the keyboard wont work.
                                      Then I try to flash with X515EA , the keyboard works but SSD wont detect
                                      Is there any correct bios file for my unit? The Model is Asus X515EA on the sticker and X415EA R6.0 printed on the motherboard.. please see the attached image
                                      The attached Bios bin was the original BIOS but has a Password..
                                      Thank you...
                                      06-02-2022, 10:07 AM
                                      by Vesko356
                                      08-11-2023, 03:27 AM
                                    • jbonavita
                                      by jbonavita
                                      Some issues
                                      Things I tried
                                      04-29-2025, 09:38 PM
