Asus GX502LXS 2.1 Bios Need.
  • nesijnet
    • Oct 2015
    • 55
    • Turkey
    Hello.
    Model : GX502LXS R2.1
    I need bios file.
    Old bios
  • nesijnet
    • Oct 2015
    • 55
    • Turkey
    Re: Asus GX502LXS 2.1 Bios Need.
    I found it. Pls remove post.
      • 22266
      Why not post it to help others ?
      • Hamada Ahmed
        • Nov 2017
        • Cairo
        Hello.
        I need bios file.
        Old bios
        [Mod. Edit - Vesko356] Posting password protected archives is against the rules.
        Last edited by Vesko356; 04-18-2023, 02:29 AM. Reason: Password protected archive removed
        • peste
          • Dec 2016
          • 13912
          • ROMANIA
          you also put the password...so we don't "steal" something from your bios..
          • biber
            • Feb 2015
            • 104
            • macedonia
            Can anyone share a backup firmware for Asus Zephyrus S15 GX502LXS R2.1, or try to fix this dump? tnx
          • notrespond
            • Apr 2024
            • 70
            • ID
            hello,can help me build my old dump bios
            mobo : GX502LXS REV2.1
            tipe : Asus Zephyrus-S15-GX502LWS-49T
            SN : LR8NRKD027166339
            old bios no display
            thanks you
              SMDFlea commented
              Editing a comment
              Post moved to Asus GX502LXS 2.1 topic.
          • hoaca388
            Badcaps
            • Jan 2022
            • 12438
            old bios no display
            thanks you
            GX532LWS
            • aladin2l
              • Sep 2020
              • 28
              • phillipines
              Asking for help no display bios needed
              GX250LXS-HF053TS
              SN : L9NRKD01655339E
              • hoaca388
                Badcaps
                • Jan 2022
                • 12438
                GX250LXS-HF053TS
                GX502LXS
                • aladin2l
                  • Sep 2020
                  • 28
                  • phillipines
                  Originally posted by hoaca338
                  GX502LXS
                  @hoaca338
                  not working i tried it and also i try another bios it works but if shotdown it freezs then off but power red lights stays lit
                    • 22266
                    @hoaca338
                    Post a picture of the QR code near the CPU
                    • aquif
                      • Sep 2014
                      • 59
                      • India
                      Asus Model g502LU-AZ108TS(GU502L)
                      SN-LCNRKD020092520
                      BOARD PART NO- GX502LXS-2.0
                      PROBLEM-NOT TURNING ON AMP CONSUMING 0.067
                      PLZ FIX THIS BIOS
                      THANKS
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12438
                        SN-LCNRKD020092520
                        PLZ FIX THIS BIOS
                        THANKS
                        You scan the code and post what you read here.
                        • aquif
                          • Sep 2014
                          • 59
                          • India
                          the code is not readable via QR scanner . what should i do , please help
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12438
                            GU502LU
                            • xedry@yahoo.com
                              • May 2016
                              • 8
                              • philiphines
                              pls clear me, sometime display and take time to display
                            • alihuseyn1905
                              • May 2021
                              • 3
                              • Азербайджан
                              tested, 100% working
                              • to5it0
                                Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                                by to5it0
                                Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                                I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                                This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                                I have opened the laptop and identified the main BIOS chip...
                                10-24-2025, 01:35 AM
                              • Sebastian Codrean
                                BIOS file for ASUS F542UN laptop
                                by Sebastian Codrean
                                Hello to all of you! I need help with a BIOS file.
                                The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                                So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                                02-20-2025, 10:25 AM
                              • jbonavita
                                by jbonavita
                                Some issues
                                Things I tried
                                04-29-2025, 09:38 PM
                              • caglarec2268
                                Asus X515EA Bios File Please
                                by caglarec2268
                                merhaba dizüstü bilgisayarım windows ile bios update yaparken kapandı.
                                Now "please follow the steps below to recover your bios" text remains on the screen
                                I tried backup bios files from the site but the keyboard did not work properly or the ssd did not read the disk. Can my bios be repaired? Or is there a correct active bios? please help thank you.
                                laptop model x515ea-bq945w
                                s/n: R4N0CV02K527148
                                CN:HWFB
                                Board model; ASUS X415EA R7.0
                                bios chip: GD25Q128...
                                11-27-2024, 03:51 AM
                              • Citymin
                                by Citymin
                                S/N : 5RNK9FFT70...
                                08-05-2025, 05:12 AM
