ACER NITRO AN517-51 BIOS and EC
  • sect-sin
    • May 2022
    • 101
    • Hungary
    I have an Acer Nitro AN517-51 (EH5VF LA-H501P Rev:1A) with a faulty SIO. I want to replace and rewrite it, and also reflash the BIOS for safety's sake. I have attached dumps for both the BIOS as well as the SIO. Can somebody provide me with a clean, up-to-date BIOS with DMI info transferred as well as a separate, programmable EC extraction?
    I thank you very much in advance for your help.
    Cheers,
    sect-sin
  • hardware1
    • Sep 2021
    • 2887
    • N/A
    Re: ACER NITRO AN517-51 BIOS and EC
    Cheers,
    sect-sin
    Here's your New BIOS, it's a Virgin BIOS from Acer with your DMI and Windows Key.
    Also New EC file is attached.
    Serial Number: NHQ5CEV010936013643400.
    all donations are welcome,
    • sect-sin
      • May 2022
      • 101
      • Hungary
      Thank you very much for the files. After successful programming, the notebook still does not work. It is powering on for a split second with keyboard backlight and fan spin, but shuts down immediately. There are no obvious shorts anywhere, and in pressing the power button, the power sequence goes all the way through VCC_SA, but there is no voltage on the Vcore rails, not even for a millisecond. I need to diagnose this further, and will give feedback if I find out what the problem is.
      Cheers,
      sect-sin
      • mauda
        • Mar 2016
        • 24
        • Czech republic
        ... the power sequence goes all the way through VCC_SA, but there is no voltage on the Vcore rails, not even for a millisecond.
        I am having the same problem now = no Vcore rail, only VCC_SA. Did you find the solution?
        • sect-sin
          • May 2022
          • 101
          • Hungary
          Unfortunately no. In my case everything points to a damaged PCH. I tried everything to no avail.
          Cheers,
          sect-sin
          • Jhay_09
            • Jul 2018
            • 11
            • Philippines
            Hi friends need help,
            Device: Laptop
            Brand: Acer Nitro
            Requesting: Repair/Clean Me Region
            History of Repair: shorted PCH, it is already change to a new PCH and now it is turning on but no display on screen.
            Motherboard EH5VF LA-H501P Rev: 1a
            Acer model: AN517-51 56YW
            S/N: NHQ5WAA001927057263400
            SNID: 92702231034
            Thank you in advance..
            • hoaca388
              • Jan 2022
              • 11131
              • Viet Nam
              Device: Laptop
              Brand: Acer Nitro
              SNID: 92702231034
              Nitro AN517-51
              Become a Badcaps supporter
              Thanks to all supporters.
              • Jhay_09
                • Jul 2018
                • 11
                • Philippines
                Originally posted by hoaca388
                Nitro AN517-51
                Thank you for your response "hoaca388"
                after trying still not having a display, upon observing the PM_SLP_S4# PM_SLP_S3# enabling signal coming from PCH, I have 5v rail stable out 3v rail power after pressing power button after 10 seconds the 3v rail will turn off.​
                • fiala985
                  fiala985
                  • Jul 2024
                  • 19
                  • Slovakia
                  Acer nitro AN517-51-553L MFG Date : 2023/04/14
                  SN : NHQ9BEC001016049BC3400
                  SN : 01601887634
                  model : n18c4
                  motherboard : EH50F LA-H431P rev.A 2019-09-16
                  good day, after replacing the processor, which was faulty on the core, it showed a short circuit, I need to clear the bios, but I don't know if the bios chip is damaged, it cannot be deleted, the chip should be fine
                  • hoaca388
                    • Jan 2022
                    • 11131
                    • Viet Nam
                    SN : 01601887634
                    model : n18c4
                    File you need at # 7.
                    • Jhay_09
                      • Jul 2018
                      • 11
                      • Philippines
                      Nitro AN517-51
                      Hello friends,
                      Update to my unit: After deeply trying fixing finally my laptop now are displaying using this bios but my problem the (Serial number, Product name, UUID) is not properly indicated in my bios Information is this possible to fix? Please kindly help.. Thank you in advance
                      SNID: 92702231034
                      • hoaca388
                        • Jan 2022
                        • 11131
                        • Viet Nam
                        Hello friends,
                        SNID: 92702231034
                        This DMI is from another machine, where is original backup bios file ?
                        • Jhay_09
                          • Jul 2018
                          • 11
                          • Philippines
                          Attach was the original bios it has no display.
                          • hoaca388
                            • Jan 2022
                            • 11131
                            • Viet Nam
                            Nitro AN517-51
                            • Jhay_09
                              • Jul 2018
                              • 11
                              • Philippines
                              Nitro AN517-51
                              Thank you sir for you response.. I let you know if everything is done well
                              • Jhay_09
                                • Jul 2018
                                • 11
                                • Philippines
                                Nitro AN517-51
                                after testing laptop has now display but Im getting same result about DMI it has no information. Can you manually input DMI information list below?
                                SNID: 92702231034​
