Asus FX553VD Keyboard Problem
  • yucel-yucel
    • Dec 2017
    • 148
    • türkey
    The keyboard of our Asus FX553VD model device does not work. We replaced the IT8587E FXA chip, but the result did not change. There is no liquid contact path rupture on the motherboard. 3-4 keys are pressed but different characters appear. For example, the F6 key works like the F9 key. Of course, 99% of the keys don't work in general. We wrote main bios and Ec bios but the result did not change. Is there anyone who can help with this? I installed bios backups.
    Mainboard ; GL553VD Rev:2.0
  • peste
    • 13924
    • ROMANIA
    Re: Asus FX553VD Keyboard Problem
    did you check the keyboard??
    • yucel-yucel
      • Dec 2017
      • 148
      • türkey
      The problem persists on the new keyboard as well as on its own keyboard.
      • djserhatcom
        • Jun 2015
        • 14
        • avcılar
        I have the same problem. Did you solve it?
        • Dobrowol
          Asus GA402RK keyboard and kb backlight problem
          by Dobrowol
          Hi. I have a problem with Asus ROG GA402RK. The keyboard suddenly stopped working along with the kb backlight. I replaced the keyboard and the ITE KBC chip and the problem is still the same. I don't see any passive elements that look damaged. Does anyone have an idea?
          04-28-2025, 04:30 PM
          ASUS 14.0 FHD 1920X1080 16:9 non-Touch Wide View / 7505 / Intel UMA / 4GB / 128GB PCIE G3 SSD / WIN10 HOME S / N/A /Chiclet Keyboard / To Notebook Specification for Upgrade or Repair
          This specification for the ASUS 14.0 FHD 1920X1080 16:9 non-Touch Wide View / 7505 / Intel UMA / 4GB / 128GB PCIE G3 SSD / WIN10 HOME S / N/A /Chiclet Keyboard / To Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14.0 FHD 1920X1080 16:9 non-Touch Wide View / 7505 / Intel UMA / 4GB / 128GB PCIE G3 SSD / WIN10 HOME S / N/A /Chiclet Keyboard / To boardview and 14.0 FHD 1920X1080 16:9 non-Touch Wide View / 7505 / Intel UMA / 4GB / 128GB PCIE G3 SSD / WIN10 HOME S / N/A /Chiclet Keyboard...
          09-07-2024, 02:50 AM
        • SDNarcia
          Dell 15R-5521 keyboard problem (KBC?)
          by SDNarcia
          Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
          As additional information,...
          07-20-2024, 10:47 PM
        • eastcoastcomputing
          Asus Tuff FX506HCB-HN216W (Mobo: DA0NJJMBAG0 Rev G) Keyboard issues.
          by eastcoastcomputing
          Hi there, bit of a weird one here.
          Got this laptop that has "ghosting" issues with the keyboard... Although it's actually an issue with the board. Basically most of the kb keys won't work even in Bios but in windows i keep having the PrtScr activated or the toggle between cooling modes activated or random keys filling up text fields.
          What I have done so far:
          - Inspected for liquid damage under the microscope and cannot see any indication any liquid came anywhere near this machine. I cannot see any damaged components either.
          - Replaced the SSD and...
          11-06-2024, 08:23 AM
        • MrDadosz
          Lenovo Legion 15IMH05 keyboard problem
          by MrDadosz
          Hello, I have lenovo legion 5 15imh05 (board: nm-c911) and I have a problem with a keyboard.
          When I hold power button for ~30 seconds or unplug RTC battery keyboard will work only one time. After laptop reset or shutdown, keyboard won't work.
          In 90% cases when I unplug power supply and turn on laptop on a battery, keyboard works even after plugging power supply - I can't turn on laptop with a power supply and get keyboard working.
          Shortcuts Fn + F1-F12 are working. Keyboard is fine.
          I replaced IT8176FN-56A and reprogram it with a dump from previous chip and it worked for...
          08-15-2024, 05:07 AM
