Casper H410H6-TI2 Bios
  • yucel-yucel
    • Dec 2017
    • 145
    • türkey
    The south chipset of the device has been changed . The original bios needs to be cleared. First image comes with a delay of 15 seconds.When we try to turn off the computer, the image is cut off, the fans are running and the computer does not turn off.I'd be grateful if someone could help.
    Mode;Casper Nirvana A500
    Motherboard ; H410H6-TI2
  • yucel-yucel
    • Dec 2017
    • 145
    • türkey
    Re: Casper H410H6-TI2 Bios
    According to the motherboard code, the manufacturer ECS comes out.
    The rom file I downloaded from the site is 12mb, but the original rom is 16mb. Can we convert this file size to the original one? Does anyone have any information?
    • beyin
      Casper Nirvana NB X600 Bios password problem!
      by beyin
      Casper Nirvana NB X600 Bios password problem. Help me!.
      Serial : SR003779454
      bios passwords file....
      x600 anakart resmi indir - Resim Yükle - Hızlı Resim
      01-27-2025, 03:57 AM
    • Focus2005
      HP OMEN 16-C0114NW – no image after replacing CPU Ryzen 7 5800H with 5 5600H and flashing BIOS
      by Focus2005
      Hello everyone.
      I have another HP OMEN 16-C0114NW laptop with serial number 5CD1501LJX. The original problem was as follows. The laptop could not load Windows and every time it threw a bluescreen - y - most often WHEA_UNCORRECTABLE_ERROR. The processor that was originally in it was AMD RYZEN 7 5800H MOBILE PROCESSOR - 100-000000295. I decided to replace it with a fully functional, used AMD RYZEN 5 5600H MOBILE PROCESSOR - 100-000000296, which I got from a donor board, on which it worked 100%. After soldering the processor, I also uploaded a new, fresh BIOS to it with the UBT2 program...
      05-01-2025, 05:41 AM
    • DynaxSC
      by DynaxSC
      06-14-2024, 03:49 PM
      by Vesko356
      08-11-2023, 03:27 AM
    • grimacelord
      Latitude E6530 - Trouble Extracting BIOS Image From EXE
      by grimacelord
      Hi folks,
      I'm having a hard time extracting this Dell BIOS. I have a Dell Latitude E6530 that has BIOS corruption and I need to reflash with CH341A programmer. I have already taken dumps of both the 4MB and 8MB chips on the motherboard.
      Service tag number for this model is: "JYDWYW1".
      Link to latest BIOS for this Service Tag: https://dl.dell.com/FOLDER05371360M/1/E6530A22.exe
      I have tried:
      • Simply extracting with 7zip
      • PFSExtractor
      • Using "/writeromfile, /writehdrfile, and /writehexfile" commands
      • Check Temp folder
      10-26-2023, 08:15 AM
