Surface PRO X 1876
  • parhatskiy
    • Aug 2016
    • 28
    • ukraine
    surface 1876
    SN: 000241703353
    the device hangs on the logo, please help to fix the bios
      SMDFlea commented
      Editing a comment
      Thread merged.
  • Sergey Nazarenko
    • Dec 2024
    • Ukraine
    Good day. Can you help me remove the password lock BIOS SurFace 1876? Serial 000057295353
    Badcaps Electronics Repair Forum & Schematic Search
      • 21692
      Attach files directly to your post in a zip or rar
      • Sergey Nazarenko
        • Dec 2024
        • Ukraine
        Sorry, added file
        • amon76
          • Aug 2013
          • 27
          • italy
          Good morning.
          Please I'm searching help for to have a clean copy of a bios for a Surface X 1876 or to clean my readed bios because I have problems with UEFI passwords.
          Can somebody help me?
          • peste
            • Dec 2016
            • 13451
            • ROMANIA
            #26
            Originally posted by amon76
            Good morning.
            post S/N, full name and model, motherboard model, etc.
            post the original contents of the bios chip..
            • amon76
              • Aug 2013
              • 27
              • italy
              #27
              Good morning. Please I'm searching help for to have a clean copy of a bios for a Surface X 1876 or to clean my readed bios because I have problems with UEFI passwords. Can you help me? I'm waiting for a your kind reply. Best regards
              SN: 019542794453
                SMDFlea commented
                Editing a comment
                Thread merged
            • azozexd
              • Sep 2019
              • 50
              • Maroc
              #28
              try... and reply
              • amon76
                • Aug 2013
                • 27
                • italy
                #29
                Good morning Azozexd. Ty so much for your helps. Now finally my surface started with your bios but, after all installations, I have problems with some zones of touch screen. It works only on left and right side.
                Also I have problems with keyboard and touch pad that doesn't work.
                Please, do you have some solutions?
                • azozexd
                  • Sep 2019
                  • 50
                  • Maroc
                  #30
                  check the cable and clean it
                  • amon76
                    • Aug 2013
                    • 27
                    • italy
                    #31
                    Good morning Azozexd. I followed your suggests and I ordered also new flat but my surface doesnt't works correctly. Problems is in part of touch screen of display and also doesn't works internal mouse and keyboard. It works only connected to usb ports. Please can you check if the problems in in bios file? I send you again original file and S/n.. Please help me!!! thank you in advance!
                    S/n: 019542794453
                    • azozexd
                      • Sep 2019
                      • 50
                      • Maroc
                      #32
                      S/n: 019542794453
                      Hello you can reprogram by the original file to chek or just clean the cable
                      be carful you must unplag batterie when unsolder chip!!!!!
                        • 21692
                        SN: 019542794453
                        Try this bios.
                          • 21692
                          Originally posted by top6
                          Can you fix it. please.
                          Surface 1796
                          040055774853
                          Thanks.
                          Can you explain what the problem is, no boot, password etc.
                          • redbaron1007
                            • Jun 2021
                            • 116
                            Surface Pro X 1876
                            SN: 005348110553
                            Having an issue where it will take 20v from the charger, but no current. Figured the bios was the next logical step since nothing on the board is obviously liquid damaged or shorted.
                            • peste
                              • Dec 2016
                              • 13451
                              • ROMANIA
                              #36
                              Originally posted by redbaron1007
                              Surface Pro X 1876
                              SN: 005348110553
                              Have you measured voltages on the coils? Do you have voltage on pin 8 of the bios chip?
                              • redbaron1007
                                • Jun 2021
                                • 116
                                I checked just now and I have no voltage on the board at all. Nothing past the two Tusb44 IC's and nothing past the not magsafe input circuitry when it's plugged in.
                                Consequently i have nothing at the bios chip as well.
                                • peste
                                  • Dec 2016
                                  • 13451
                                  • ROMANIA
                                  #38
                                  well if you don't have anything on the bios chip how can you have problems with the bios...how does the bios chip work without voltage??...my opinion is that you don't have problems with the bios...move the discussion to the main forum here is the "bios only requests" section"...
                                  • Q1999
                                    • Oct 2023
                                    • 18
                                    • Vietnam
                                    #39
                                    my surface bios password.
                                    surface pro x sq2.16.256
                                    sn: 007090515253
                                    please help me remove the password
                                    • shiyab
                                      • Sep 2023
                                      • 1592
                                      • india
                                      #40
                                      sn: 007090515253
