hp elitebook 840 g3 power problem
  • jacospama
    • Aug 2019
    • 240
    • Ghana
    Am working on hp elitebook 840 g3 . the problem is , it can only turn on when i put in charge battery but not on charger. if i plug in the charger all the necessary voltages come , but still cant switch on from charger. is there way through which i can solve this problem?
  • mon2
    • Dec 2019
    • 14660
    Re: hp elitebook 840 g3 power problem
    Sounds like a common DCin mosfet fault - see the above sticky by @Piernov on how charging functions on laptops.
    Post the logic board markings so we can hunt down the logic board schematic (if they are available).
    Using a multimeter; hot air tools and some patience, you should be able to repair this unit.
    First need to review which charger IC is onboard this design. Respectively, you should have 2 x DCin mosfets (likely will be N-channel style).
    Often the 2nd DCin mosfet gets damaged and needs to be replaced.
    • Stevedb
      Stevedb
      • Feb 2018
      • 624
      • Belgium
      Do you use original adapter of correct wattage.
      • jacospama
        • Aug 2019
        • 240
        • Ghana
        am using original charger
        • jacospama
          • Aug 2019
          • 240
          • Ghana
          this is the board
          • mon2
            • Dec 2019
            • 14660
            See attached. Near the battery connector should be the charger IC. We need to locate this charger IC to debug this case.
            Is the IC with a 'BQ' marking ? If not, continue to locate similar looking square ICs till you find the 'BQ' charger IC.
            • jacospama
              • Aug 2019
              • 240
              • Ghana
              ok thank you. but please how can i locate BQ charger ic?
              • mon2
                • Dec 2019
                • 14660
                Review each square (black in color) shaped IC and review the topside markings.
                Guessing that you will have one with 'BQ' in the markings = Texas Instruments / BenchmarQ brand. We need to know the full part number on this IC.
                Start the hunt from the DCin adapter connector and review to the battery connector. Has to be present somewhere.
                • jacospama
                  • Aug 2019
                  • 240
                  • Ghana
                  i have seen the ic
                  • jacospama
                    • Aug 2019
                    • 240
                    • Ghana
                    please should i replace ic ?
                    • mon2
                      • Dec 2019
                      • 14660
                      What are the full markings of this charger IC ? So far, unable to locate the schematic for this logic board ->> Use 840 G1 (similar) schematics.
                      However, with the charger IC details, we can get a very close idea of how this charger circuit works to debug the fault.
                      Update: HP 840 G1 also has a U6000 for the charger IC so use it for reference.
                      Download the schematic from here:
                      https://www.badcaps.net/forum/showth...ghlight=840+g1
                      Then search for 'U6000'.
                      Measure the voltage to ground for the following pins on U6000:
                      a) REGN
                      b) ACDRV
                      • jacospama
                        • Aug 2019
                        • 240
                        • Ghana
                        a) REGN
                        b) ACDRV
                        Ok am gonna do that thank you
                        • mon2
                          • Dec 2019
                          • 14660
                          I think you may find that the 2nd mosfet = Q6011 will be defective.
                          You can remove it and confirm that ACDRV should be ~25 volts to ENABLE the 2 x DCin mosfets. If it is not, then we need to review the conditions needed for this charger IC to spit out this boosted voltage.
                          That is, the ACDRV voltage should be (if working properly) = DCin adapter + REGN voltage (~6 volts) = ~25 volts to enable the mosfets.
                          Often, as per article above by @Piernov, the 2nd mosfet gets damaged. DO NOT bypass the mosfet but if available, replace it with a suitable N-channel device. The device can be replaced by many others.
                          Test and post your updates for future readers.
                          • classicandy
                            • Apr 2018
                            • 309
                            • Nigeria
                            a) REGN
                            b) ACDRV
                            This board uses BQ24780S...... Same as HP Elitebook 1040 g3, 1030 g2 and most 6th and 7th Generation HP Elitebooks and Probooks Series
                            • spyro99
                              • Oct 2021
                              • Portugal
                              you saved my sanity
                              Replaced bq 3 times tested mosfets they looked ok no shorts tested all the caps, checked for voltages in bq and had no voltage in ACDRV only 6v in REGN , in "desperation" replaced q6011 and everything is working now
                                HP EliteBook x360 1030 G3 + USB-C Essential Power Bank Hybrid (2-in-1) Specification for Upgrade or Repair
                                This specification for the HP EliteBook x360 1030 G3 + USB-C Essential Power Bank Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1030 G3 + USB-C Essential Power Bank boardview and 1030 G3 + USB-C Essential Power Bank schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                09-06-2024, 11:05 AM
                                HP EliteBook 1040 G4 + USB-C Notebook Power Bank Notebook 1000 Specification for Upgrade or Repair
                                This specification for the HP EliteBook 1040 G4 + USB-C Notebook Power Bank Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1040 G4 + USB-C Notebook Power Bank boardview and 1040 G4 + USB-C Notebook Power Bank schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                09-06-2024, 06:27 AM
