Hp -15bs199nl not charching
  • mon2
    • Dec 2019
    • 14664
    Re: Hp -15bs199nl not charching
    Remove PQB12 off the logic board.
    Measure the resistance across the mosfet pins as noted earlier in this thread.
    Source and gate should not be shorted.
    • arber1232
      • Dec 2019
      • 379
      • Albania
      gate and source in mosfet is ol nothing . sorce with drain 3,3 mega ohm....gate with source nothing ol
      • dclass-pro
        • Dec 2022
        • 157
        • Italy
        hello, but did you say that without the 4k resistance, the pc charges the battery? it is not possible because the 2 mosfets should be open, otherwise they are either shorted or it is the right scheme
        • mon2
          • Dec 2019
          • 14664
          Measure the same resistance checks on the PCB pads (with this mosfet still removed).
          Also, post or share the silk screen markings on the logic board. Is your logic board marked with the same as the shared schematic in the first post ?
          If not, what is the charger IC on board ? What are the top side markings for the original 2 x DCin mosfets ?
          • arber1232
            • Dec 2019
            • 379
            • Albania
            gate and souce in board is 2,2 ohm .. source and drain 6 mega ohm.. gate and drain 1.7 mega ohm ... the charger ic is same with i shared in first post... i have hp 250 g6 and is same with hp 15 bs199nl
            • mon2
              • Dec 2019
              • 14664
              Remove the first DCin mosfet and check the gate & source PCB pads that are @ 2R2 ohms.
              • arber1232
                • Dec 2019
                • 379
                • Albania
                #27
                the first mosfet is shorts souce and gate .no i not have 2,2 ohm in board... can i change this mosfet with 6426 mosfet ?
                • mon2
                  • Dec 2019
                  • 14664
                  Yes, you can.
                  After this replacement, measure the pads again to be sure there is no short.
                  Then place back the 2nd dcin mosfet.
                  Power up if no short. You should NOT have power passing through if the gate is disconnected from ACDRV.
                  Confirm it.
                  • mon2
                    • Dec 2019
                    • 14664
                    After the above, with the 4k resistor off the board, check the ACDRV voltage to ground again. It should be ~25v. If yes, solder back the 4k resistor. Test again.
                    Laptop with charging should be working.
                    • arber1232
                      • Dec 2019
                      • 379
                      • Albania
                      #30
                      now laptop is ok charching normal . Thank you very much for helping me. This was a good lesson for me, thank you
                      • mon2
                        • Dec 2019
                        • 14664
                        Good job! Just a lesson from the article from the (charging circuits) sticky above by @Piernov. Usually the 2nd DCin mosfet blows but once in a while so does the 1st DCin mosfet.
                        The hint was that the GATE pin is shared by BOTH DCin mosfets so someone was pulling this line down.
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          #32
                          Nice the case was solved but@arber1232, it shouldnt take this long and so much effort to find out this common fault. Look for basics first instead of changing components cluelessly. Sometimes, the mb symptoms changes completely after such random change of components and heat. So perhaps,try to understand the basics well.Your success ratio will gradually improve when basics are clear.
                          • Damex 29
                            Dynabook l50-g 11j scheme
                            by Damex 29
                            looking for scheme robusta 6050a3128301 a01
                            Dynabook l50-g 11j
                            04-02-2025, 03:51 PM
                          • dclass-pro
                            HP Notebook With Strange Defect Does Not Turn On
                            by dclass-pro
                            Hi Guys, I have a HP DAX12AMB6D0 REV.D with a strange defect, that is on the 2nd mosfet on the power supply, the gate voltage does not reach 25V but pulses... if I try to touch some capacitors with my fingers, the voltage on the gate reaches 25V and the notebook turns on.
                            I have already tried to change the charging connector, PU1 and PQ20 but I have not obtained any result, the problem still persists.
                            Here are the voltages that I find ON PU1:
                            Pin 1 - Pulses between 2 and 3v
                            Pin 2 - Pulses between 2 and 3v
                            Pin 3 - Pulses between 2 and 3v
                            Pin 4 - Pulses between...
                            01-31-2025, 08:27 AM
                          • Art Em
                            Need electric scheme for HP ENVY 13 with Moorea 13CS ICL 19728-1
                            by Art Em
                            Would be grateful if you send me the electro scheme for this motherboard, mentioned in title. If anyone is interested why:
                            -first keyboard backlight stopped working
                            - a couple months later the keyboard itself stopped working.
                            - then, in two days, the laptop itself stopped booting.
                            Thanks everyone in advance
                            04-13-2024, 01:13 AM
                          • arber1232
                            Dell E7450 not charching La-A961P
                            by arber1232
                            HI, how are you. I have a dell laptop which does not turn on with charger and not charching
                            the light of the power button for a while and turns off, with battery the laptop turns on and works fine. I have done some measurements and I doubt Pq705 but I want your help to be sure....
                            Some measurements of pq 705 with charger without battery
                            D1-19,13y
                            S1/D2- voltage change 12v to 10v 13v
                            G1- voltage change 13v, 14v, 16v
                            G2-ov
                            S2-gnd
                            03-27-2023, 05:07 AM
                          • maces
                            SAMSUNG PS60E6500 Power Supply BN44-00513A defect and burned
                            by maces
                            I have a problem with the power supply of my Samsung PS60E6500.
                            The LED of the TV is blinking and it doesn't turn on.
                            After checking the power supply I noticed that the PCB board is burned at QP804 (K13A60D), the MOSFET is shorted.
                            RP812 is also defect. Unfortunately the resistor is burned so I cannot read the value. Also QP805 and QP806 are shorted. Does anybody have a schematic diagram or does anybody know the type of the parts?...
                            03-13-2023, 03:50 PM
