I need help with Elitebook 830 G7
  • sophago
    • Nov 2022
    • 22
    Please if anyone could help. I have a Elitebook 830 G7 and it has an admin password. I tried to desolder the chip and accidentally ruined the chip from trying to remove it with tweezers, the chip is dead now. I also tore off two small pads where the chip was soldered. Assuming fixing the pads can I buy a new chip and install a bios dump file in it and be good to go? I don't have any old locked dump. My chip is MX25L12872F
    Any recommendations would be appreciated, thanks.
  • mon2
    • Dec 2019
    • 14084
    Re: I need help with Elitebook 830 G7
    See attached. You may be ok here. The INSIDE pads that appear to be ripped off the PCB are for a nested and smaller flash memory device.
    That is, the PCB designer will layout the PCB so that if some component is unavailable in one physical size, then the assembly group will purchase alternate devices and still allow for the PCB to be assembled. We do this all the time and for example, on our SOT-23 components, we nest inside the smaller SC-70 package. SC-70 package is about 50% the size of the SOT-23 for the 2N7002 mosfet (as an example).
    Confirm with the meter that the outside traces (thick yellow in the attached) are still present.
    Post a pic of your flash device - it may be ok as well.
    • sophago
      • Nov 2022
      • 22
      Thanks for the reply, I checked with the meter and they are still fine, here are the pics of the flash attached.
      So you are saying that I can place a bigger chip with the same size like 8*6mm?
      • sophago
        • Nov 2022
        • 22
        The traces look fine, above you have some pics of the flash. Thanks
        • mon2
          • Dec 2019
          • 14084
          1) The original flash memory is damaged and cannot be used.
          2) See attached. It appears that the damaged flash device is the smaller WSON package. You can check the measurements by reviewing with a ruler and comparing the dimensions shown at the end of the attached datasheet.
          Fairly sure the PCB will be ok to use the larger 8 pin SOP package but again, check against the dimensions in the datasheet.
          Purchase the SAME part # but with the proper suffix to define the SOP package.
          Digikey appears to have the SOP (larger pad) size part in stock but do confirm the dimensions against your PCB and this datasheet.
          https://www.digikey.com/en/products/...I-10G/10059507
          • sophago
            • Nov 2022
            • 22
            Assuming everything fits well, then do I need to create a thread on Bios Requests and then give the serial nr of the board and hope someone will post the bios dump file of that particular board? Thanks
            • mon2
              • Dec 2019
              • 14084
              Yes.
              • sophago
                • Nov 2022
                • 22
                Yes.
                Thank you for your help.
                  HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook 800 Specification for Upgrade or Repair
                  This specification for the HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 860 16 inch G9 Notebook PC boardview and EliteBook 860 16 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                  09-07-2024, 05:50 AM
                  HP EliteBook EliteBook 650 15.6 inch G9 Notebook PC Notebook 600 Specification for Upgrade or Repair
                  This specification for the HP EliteBook EliteBook 650 15.6 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 650 15.6 inch G9 Notebook PC boardview and EliteBook 650 15.6 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                  09-07-2024, 05:20 AM
                  HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook 600 Specification for Upgrade or Repair
                  This specification for the HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 630 13 inch G9 Notebook PC boardview and EliteBook 630 13 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
