THINKPAD L390 Not turning on after password remove
+ More Options
Posts
  • RAR1991
    • Apr 2017
    • 25
    • Algérie
    Hi, I've tried to unlock a ThinkPad L390 and used a patched file meant for another laptop but after putting back th e original dump the laptop refuses to power on. if there is anyone that has a solution I will be be very grateful.
  • mon2
    • Dec 2019
    • 13970
    Re: THINKPAD L390 Not turning on after password remove
    Hi.
    1) link a schematic or more details on the silk screen markings on the logic board.
    2) Is the power adapter the typical barrel / coax round connector? Check the voltage to ground at the dcin connector. Check the same at every large coil. If you see a very low voltage then the power path has to be reviewed.
    Which charger IC is on this logic board? This part should be near the 2 x DCin mosfets close to where the dcin connector is located. The charger IC is often the 'BQ' series from Texas Instruments.
    Update: it is a usb c power delivery adapter. Check the voltage to ground on each grey coil to get started.
    • RAR1991
      • Apr 2017
      • 25
      • Algérie
      Thanks for the reply the Laptop is a ThinkPad L390_TYPE 20NU-S0Y400
      MB Model : LKL-2 MB 18724-1M schematics attached. [MOD EDIT] Link to schematic - https://www.badcaps.net/forum/troubl...ga#post1562873
      want just to precise that the laptop was working before the bios password remove attempt
      • mon2
        • Dec 2019
        • 13970
        Check the voltage to ground of each large grey coil. Any low or zero voltages ?
        • RAR1991
          • Apr 2017
          • 25
          • Algérie
          Originally posted by mon2
          check the voltage to ground of each large grey coil. Any low or zero voltages ?
          all voltages are present except for v core
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3576
            • slovakia
            for unlocking there is custom bios that can edit fw in T2 ic or other where is password stored. so u probably mess this fw.
              • 20621
              Clean the ME firmware of the original bios backup,flash it back.Did you remove all batteries, is there a tamper switch on this model
