Macbook pro A11989 820-00850 SSD not detected after issue with power 5V instead of 20
  • Dcaub
    • May 2022
    • 6
    • BE
    Hello
    I have a issue with a 820-00850 the mainboard was not going to 20V it stays on 5V - 0.06A . I have checked different voltages and they seems to be ok.
    So i have used Apple Configurator 2.6 from another Macbook to program the T2 Firmware. (Seen on a Louis Rossman Youtube)
    After this has been done the macbook is starting again so this was causing the problem but it is not starting there is the Question Mark folder on the display.
    I have tried to start with Command + R and there reinstall the operating system from Internet but when the download was complete and de install started there where no drives to install. So i think the SSD is not working ?
    Checked the voltages around the ssd SSD PP2V7NAND_SSD = 2,5V -PP1V8_SSD0=1.8V - PP0V9_SSD0=0,9V - PP3V3_S5= 3.3V
    What i dont understand is when the firmware got corrupted can this lead to hardware issue ? Maybe i am complelty wrong and is it now a software issue so that the disk is working but not showing.
    What i also noticed also that the power on/off button was not working when i pressed on it (maybe that there was a bad connection when i temperarly mounted the board in the case).
    I had the idea to go again in the DFU mode (before i done the firmware flash it was automatic in this mode) and try again and see what there is maybe wrong.
    I dont know where to search anymore i am not familiar with apple more Pc..
    Anyone with a suggestion ?
    Thx
  • mon2
    • 14334
    Re: Macbook pro A11989 820-00850 SSD not detected after issue with power 5V instead o
    Remove all power. Meter in DIODE mode.
    Red meter probe, yes RED to ground.
    Black meter probe to point to test.
    Check diode mode to ground on the LDO rails of all CD3215 chips.
    Post each measurement.
    • pcbmaniac
      MacBook A1278 (3115) No PPBUS_G3H Issue
      by pcbmaniac
      Subject: Help Needed: MacBook A1278 (3115) No PPBUS_G3H Issue
      I'm working on a MacBook A1278 with the 3115 logic board and facing an issue with no PPBUS_G3H voltage. Here's what I've checked so far:
      1. U7000 Measurements:
        • Pin 3 has 0V, even though R7012 shows 16.5V from PPDCIN_S5_CHGR.
      2. Resistors:
        • I measured R7010 and R7011 with one leg disconnected, and both tested OK.
      Based on these findings, I believe U7000 needs to be replaced. However, I have a related question:
      • If I also decide to replace the SMC, do I need to order it pre-programmed,
      12-02-2024, 04:12 PM
    • sofles
      Macbook a1707 2017 model 820-00928 GPU issue
      by sofles
      Hello there
      I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
      I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
      11-21-2024, 05:25 AM
    • Stephen
      A2141 MacBook Pro 16" lid sensor issue.
      by Stephen
      Just like the title states. I have been confused at this point. Computer won't turn on when lid angle sensor is plugged in, when unplugged it turns on immediately, however I have tried 4 different lid angle sensors all OEM and calibrated without issue. I even pulled one from a donor computer and still nothing. I know the M1 Pro sensors are married to the board however I do know the 2019 intel are not as long as they came from a donor LCD etc. What I do not get is why is the lid angle sensor forcing the computer to not turn on, another issue I see when the lid angle sensor is disconnected...
      11-01-2024, 03:45 PM
    • Gueric
      MacBook Pro 2019 820-01700 Speaker amp issue.
      by Gueric
      I have this MacBook Pro on my bench that I have already fixed, hard short on a SSD rail, but it also has another issue. the right speaker sound is either earrape, muffled or absent. Left one works perfect. I have tried replacing it, nothing changed so I'm pretty sure the issue is either motherboard related or maybe software but I doubt that.
      I don't how to troubleshoot speakers. Any help would be very much appreciated.
      A refurbisher and a repair shop have already been inside the laptop but I'm pretty sure none of them tried to do any soldering on the board.
      05-19-2025, 03:08 AM
    • saisoni20
      MacBook Air A2337 820-02016-07 No sound ISSUE
      by saisoni20
      I have A2337 MacBook Air no sound issue.
      I have replaced new Audio Board but still same issue. I went through repair wiki and checked critical voltages.
      In terms of voltages, I have following voltages,
      1 PP1V25_AWAKE_IO - 1.2V
      2 PP1V25_AWAKE_IO - 1.8V
      3 SPKRAMP_A_OUTP_R - 0V
      ​4 SPKRAMP_A_OUTN_R - 0V
      Am I missing any other critical voltages?
      07-28-2024, 05:53 PM
