current consumption of the laptop startup sequence ?
+ More Options
Posts
  • corrize
    • Apr 2021
    • 294
    • France
    Hello, what is this sequence pls ? I just repaired pc laptop, and I want to test with minimal current (from PSU). And I would like to check on PSU if there is a good start.
    It's a little 14' asus.
    What is the difference between small laptop and gamer laptop ?
    • 22035
    Re: current consumption of the laptop startup sequence ?
    Originally posted by corrize
    It’s a little 14’ asus.
    Do you have the model number for this little Asus,and what is the motherboard part number. With the motherboard part number we can check if there`s an available schematic,boardview or Repair Guide.
    • corrize
      • Apr 2021
      • 294
      • France
      It’s a general question, from your experienec, I have no idea at all of consumption at start sequence of any laptop.
      I don’t need a precise curve, just an idea.
      If after pressing start button, I see 0.2, 0.5, 1amp or 2amp, it is normal or not ? And after x sec, drop ou up to x… ? Do you see ?
      If realy needed, it’s a ux433F Zenbook (i5 and no graphic card). But it is a general question.
      • reformatt
        • Feb 2020
        • 1528
        Basic things are seeing if the current goes over 1A if battery is connected (so we know at the very least the charging circuit/battery are working). Look at the adaptor or on bottom lid to see what the machine is rated for peak current usage as a guide.
        Disconnect the battery, you see what current is consumed at rest and when power button is pressed. The actual value per se isn't important (as this will be very much hardware specific). What we are really looking at from a diagnosis point of view is how it reacts to being plugged and when power button is pressed.
        A static value indicates that the CPU isn't executing code for example. We can also see if the current goes up/down with RAM installed or removed. If we have varying current, this usually means the CPU is booting, and it might be a video issue if there is no display. Just rule of thumb.
          Diodes AP21X2SG-13 AP21X2MPG-13 Current Limited Power Switch for Laptop Computer Datasheet
          The AP2182 and AP2192 (AP21X2SG-13 AP21X2MPG-13) are integrated high-side power switches optimized for Universal Serial Bus (USB) and other hot-swap applications. The family of devices complies with USB 2.0 and available with both polarities of Enable input. They offer current and thermal limiting and short circuit protection as well as controlled rise time and under-voltage lockout functionality. A 7ms deglitch capability on the open-drain Flag output prevents false over-current reporting and does not require any external components.
          All AP21X2SG-13 AP21X2MPG-13 devices are available...
          10-23-2024, 03:33 AM
          Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
          This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
          09-06-2024, 09:30 PM
          Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
          This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
          09-06-2024, 08:47 AM
        • RdeveLabs
          MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
          by RdeveLabs
          To all the members here...
          Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
          So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
          05-05-2025, 04:59 AM
          Microsoft Surface Laptop Surface Laptop 4 Notebook 4 Specification for Upgrade or Repair
          This specification for the Microsoft Surface Laptop Surface Laptop 4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 4 boardview and Surface Laptop 4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
          09-07-2024, 06:11 AM
