Lenovo V17-IIL replacement fuse
  • Jenzo
    • Jul 2019
    • 135
    • Belgium
    Hey,
    Got a laptop in with a blown backlight fuse, I'm just not sure what replacement fuse I can use since I don't get much Lenovo laptops, so no idea what voltage/amp ratings these are supposed to have.
    Included a picture in case it could help, component FG3301. Thanx in advance!
    picture: https://imgur.com/a/RBAvFKx
  • mon2
    • 14659
    Re: Lenovo V17-IIL replacement fuse
    Can you measure the fuse size? Post the dimensions.
    Looks to be 0805 smd size.
    2A-3A at 50v or higher voltage should be ok.
    • Jenzo
      • Jul 2019
      • 135
      • Belgium
      The size I can figure out, its the voltage/amperage rating I wanted to verify. Thank you for the help, again!
      • Fixpc
        LENOVO IDEAPAD 5 15ITL05, fuse FG3301
        by Fixpc
        Hello dears, On a laptop LENOVO IDEAPAD 5 15ITL05 there was a mistake,
        the screen flex came out without removing the battery first, resulting in the screen brightness being lost. Usually a fuse is off.
        the fuse FG3301 is off, does anyone care how many amperes it is, thank you very much
        07-29-2024, 07:01 AM
      • coasterghost
        Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
        by coasterghost
        For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
        Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
        Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
        System Hardware:
        Processor: AMD Ryzen 7 PRO 5850U
        Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
        09-08-2025, 10:46 PM
      • andrhouseolly
        Lenovo X240 - motherboard replacement for X250, no image.
        by andrhouseolly
        Friends. I beg you to help me in this situation.
        Lenovo X240 with a video problem. Native Intel drivers are not installed,
        after installation, a black screen. It works with the standard Microsoft driver.
        Understanding that there are problems with the video core,
        I ordered a motherboard from Lenovo X250.
        The laptop turns on, starts up, there is no image on the internal display.
        The image is output to the external monitor.
        I ordered another motherboard from Lenovo X250.
        07-12-2024, 03:02 PM
      • Grafnus
        Lenovo ThinkPad P15 Gen2 Battery Mosfet Replacement
        by Grafnus
        Hey there,
        first time posting here. I have been lurking a bit trying to find a solution but with little to no avail.
        So I have a Lenovo ThinkPad P15 Gen2. When I got it (for free) it was turning on but not charging because the battery was unplugged. When I plug the battery in, the Laptop won't boot at all.
        Specs:
        • Type: Lenovo ThinkPad P15 Gen2 20YQ-001KGE
        • CPU, GPU, RAM work fine (not involved in the Problem)
        So the first thought was to toss the battery and get a new one, as clearly the BMS is throwing errors or something.
        Now I noticed...
        08-06-2025, 11:54 AM
      • Attila Jamilov
        Which fuse is responsible for backlight on Lenovo Thinkpad T14 Gen 3
        by Attila Jamilov
        I upgraded display from HD to UHD recently, and I think I did everything right, battery was disabled in BIOS, and removed, yet the screen has no backlight. Both the old and new display behave the same way. I checked the motherboard and I see the fv1 fuse, and a fv2 spot for a fuse, but it's missing. Does anyone have any information on whether fv2 is responsible for backlight, or why it's missing? There's a schematic posted somewhere on this forum, but I can't view it as I don't have the hardware right now, since the laptop screen is broken and I run Linux.
        Also from further search...
        04-20-2025, 10:02 PM
