Hi all, I am working on the Apple MacBook Pro A2159 Logic board # 820-01598-06. I removed the Logic board & it seems to be clean & no sign of liquid spill anywhere or any component. The problem is when I plug in the USB-C power adapter cable, It turns on, Voltage 20v & .42amp (Without the LCD Fex cable attached). And when I attached the LCD flex cable to the LB, I see the backlight for few sec which is very obvious, the amps on the amp meter keeps dropping to ZERO amp (In either case) & then the backlight disappears & restarts all over again. No image at all. But on one instance I saw the battery charge icon on the LCD screen when I did not plug in the USB-C cable. I checked the 3.3V which is perfect witout any errors & stable all over, but 5V is good for a while & the drops to 4.2v & restarts & back to 5V, which then turns on the logic board again, till this fluctuations happens once again. Any help or tips would be really helpful. Thanks in advance.
MacBook Pro A2159 starts for 5 sec & off again
Re: MacBook Pro A2159 starts for 5 sec & off again
Hi. Check the resistance to ground of the 5 volt rail.
Check the current sense loop of the 5 volt rail to be sure no parts are missing. The local regulator for that rail may be incorrectly concluding there is a fault on this power rail due to the current sense circuit.
What are the voltages of the SDA and SCL lines on the battery connector? -
Thanks mon2., There does not seem to be short on the 5V power rail. The resistance is around 287K & keeps on geting low. & in this I see under the MS, no parts are missing.
Voltages of the SDA and SCL lines on the battery connector J6951, both are perfect 3.3 volts... I was checking Louis video on Youtube regarding this same problem, they even could not find teh fault, but I will try to sort it out. Any other tips??? ThanksComment
Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
I'm new to soldering but the only feasible way to fix this issue is to do something myself.
MY QUESTION:
I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)... -
by ledbylightHi all!
This is my first post and also one of my first "deep dives" into electronic repair. I'm used to doing basic tasks with computers, like SSD/CPU replacement, thermal past re-application, etc. So here's the story...
I have a MacBook Air M1 that I bought to repair (I know, I'm weird; though I'm a CompSci major and want to learn more
, and it will not display anything on the internal display. I have verified that there's no backlight, as I booted the laptop and shined a flashlight on it and there's no display; it does completely boot up, and shows fine on an external...
11-04-2024, 06:36 PM -
by thuygsmHello! Please help with a strange disease that I have never encountered before.
At first I got the following status:
MacBook does not turn on. Current consumption is about 0.500-0.600A at 20V from USB-C.
- no signs of rust, or spilled water
- CPU gets hot, fan still spins, no Capslocks light
then I cleaned it and I got the following video:
- Cannot install software, and after a while I get a red screen and the whole thing freezes
Macbook Pro A2159 / Bệnh lạ07-28-2025, 11:35 AM -
by kenzo2I need dump file for nand A2159 512GB with 2 Nand chips >.I upgraded 128gb to 512gb..I use P13 there are only 4Chips...
I need dump file MACBOOK PRO A2159
TSB4232(256)
TSB4229(256)
Thanks -
by defdjamelHi everyone,
I’m trying to remove a component from a 2021 MacBook logic board, but I’m having trouble.
https://www.electronicsdatasheets.co...s/tlv70733pdqn
I’m using hot air at 480 °C with full airflow and good flux, but the solder paste is not melting.
I know there’s a lot of thermal dissipation from the board, and I suspect the copper planes are absorbing most of the heat.
Do you have any tips for this kind of board? Would a preheater help?
Thanks in advance!
- Loading...
