Dell G3 3590 run without display attached?
  • user11113
    • Oct 2022
    • 6
    im having a Dell G3 15 3590 (P89F001, servicetag JFJ5MT2) here without a Display assembly / LCD panel.
    but when turning it on it blinks 2,7 - display failure.
    after buying a 40pin edp cable, i attached a display from my HP laptop but it still wont do anything.
    still 2,7 blinks, display stays off. even with the PowerON + D display test.
    my plan was to use it without a built in display for a project that has a external one.
    it wont boot with a hdmi display or usb-c displayport dock attached too.
    i also couldnt find a edid dump of a dell approved display so i could hook up a eDP to DVI/HDMI adaptor with a dummy plug containing the EDID. (which i probably have to build my own)
    i tried flashing several bios files from threads i found here but none of them changed its behaviour.
    i dumped the bios and used AMIBCP to edit to maybe turn off ePSA or whatever is doing the preboot checking, but flashing it only caused the 3,6 blink code (bios invalid), probably wrong hash. no idea how to do it properly.
    i also tried removing Resistor R615 (CFG4, eDP enable/disable) indicated by the Dell G3 3590 Wistron Selek CFL-H 18225-1 schematic to turn off the eDP port entirely. didnt work aswell.
    Does anyone know a solution i could try?
  • Sephir0th
    • Oct 2020
    • 1289
    Re: Dell G3 3590 run without display attached?
    Did you check any circuit on the motherboard (voltages, resistances, etc.) before randomly modifying it?
    FairRepair on YouTube
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      BTW, are you sure its posting?? Numlock light glows on usb keyboard??
      • TheQuentincc
        Dell XPS 9300 (LA-H811P) internal display only shows Dell logo then nothing (everything else works)
        by TheQuentincc
        I have a Dell XPS 9300 that's working perfectly fine with an external display plugged, from windows the internal display isn't detected. At boot I can see the Dell logo then when it should display the boot/bios or whatever the screen goes black (no backlight, no image using a flashlight). I tried unplugging everything on the motherboard except the eDP cable but it didn't helped (so it's not the lid sensor). LCDVDD/backlight power are powered down when this happen, PANEL_BKEN_EC and ENVDD_PCH are also down to 0v. It's weird, it almost feels like the motherboard is shutting down the display...
        06-26-2025, 01:44 PM
        DELL G3 3590 Notebook Specification for Upgrade or Repair
        This specification for the DELL G3 3590 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3590 boardview and 3590 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL G3 3590 Notebook is...
        09-06-2024, 09:12 AM
