Macbook A1990 820-01041-A Dark Display
  • Strolch
    • Nov 2017
    • 237
    • Deutschland
    Hello, I have a MacBook Pro 15 inch 2018. A1990 Board 820-01041-A. The MacBook has water damage. It works but the display stays black. I took a picture of the LVDS connector. there you can see on the thick pin over IPX that there was a short circuit. there is also zero volts. Have any of you had the same problem? Thanks
  • Strolch
    • Nov 2017
    • 237
    • Deutschland
    Re: Macbook A1990 820-01041-A Dark Display
    Hello, I have now made a few more measurements on the board with the power supply connected.
    • Strolch
      • Nov 2017
      • 237
      • Deutschland
      LCD pin top right 0.0072V
      bottom right 3.369V
      top left and bottom left 5.11V
      • Strolch
        • Nov 2017
        • 237
        • Deutschland
        on the second picture I measured 0.004V for the 5 in the row and 0.0035V for picture 3 and 12.55V for the fuse
        • mon2
          • Dec 2019
          • 14240
          Hi. Best to use pin numbers from the BV file for this logic board.
          Can you measure and post your voltage readings of J8500?
          In the meantime, need to collect the 10,000 leaves in the backyard - it is a favorite past time. Want to burn them along with the audio equipment used by the neighbors for their outdoor karoake sessions.
          • Strolch
            • Nov 2017
            • 237
            • Deutschland
            Ok, pin 1to pin 46 or which pins should I measure? greeting
            • mon2
              • Dec 2019
              • 14240
              Start with the voltage to ground check of each of the I2C pins.
              See attached.
              • Strolch
                • Nov 2017
                • 237
                • Deutschland
                i have
                Pin 24=5.108V
                Pin 26=5.104V
                Pin 28=3.36V
                Pin 30=3.36V
                Pin 32=0.0004V
                Pin 34-40 All= 1.7934V
                • mon2
                  • Dec 2019
                  • 14240
                  Voltage on pin #45 ?
                  Voltage on pin #46 ?
                  • Strolch
                    • Nov 2017
                    • 237
                    • Deutschland
                    Pin 45 and Pin 46= 5.110V
                    • Strolch
                      • Nov 2017
                      • 237
                      • Deutschland
                      Maybe U5210?
                      • mon2
                        • Dec 2019
                        • 14240
                        Fault may be that U9850 is damaged (MUX).
                        See 'NO IMAGE' here:
                        https://repair.wiki/w/A1990_2018-201...ar_MacBook_Pro
                        If you suspect U5210 - measure the voltage of the I2C lines on both sides of U5210.
                        That is,
                        I2C_DISP_SCL
                        I2C_DISP_SDA
                        I2C_TCON_SCL
                        I2C_TCON_SDA
                        • Strolch
                          • Nov 2017
                          • 237
                          • Deutschland
                          The link doesn't work.
                          • Strolch
                            • Nov 2017
                            • 237
                            • Deutschland
                            But I have already exchanged the chip on an A1707 and then it was fine again! I will try it. br
                            • Strolch
                              • Nov 2017
                              • 237
                              • Deutschland
                              Hi mon2,
                              I swapped the U9850. The display is getting power now but I don't have a backlight. greeting
                              • Strolch
                                • Nov 2017
                                • 237
                                • Deutschland
                                I will look at the Backlight Flex Cable Connector of the A1989 A1990 A1706
                                • mon2
                                  • Dec 2019
                                  • 14240
                                  Very good - do check the backlight voltage at the logic board to see if it is being created.
                                  • Strolch
                                    • Nov 2017
                                    • 237
                                    • Deutschland
                                    J8500 Pin 43?
                                    • Strolch
                                      • Nov 2017
                                      • 237
                                      • Deutschland
                                      I have from 8470-C8473=. 0,005V
                                      • mon2
                                        • Dec 2019
                                        • 14240
                                        Measure the voltage to ground for the following points of interest:
                                        EDP_BKLT_EN
                                        PPVIN_S0SW_LCDBKLT_R
                                        LCDBKLT_EN_L
                                        PPVIN_S0SW_LCDBKLT
