Lenovo Ideapad 5 15ITL05 without back ligth, Help
  • luzvel64
    • Apr 2017
    • 101
    • Guatemala
    I have a Lenovo Ideapad 5 15ITL05 laptop. It turns on with a video signal on the screen but without lighting. I tried a new screen but it gave the same problem.
    This computer uses the GS55J GS55K NM-D211 REV 1.0 2020-08-14 motherboard but I can't find a schematic, it also uses a r156nwf7 touch screen and I can't find where to test to verify if I'm missing any signal or voltage.
  • mon2
    • Dec 2019
    • 14191
    Re: Lenovo Ideapad 5 15ITL05 without back ligth, Help
    Attached is the boardview file.
    Boardview ---> https://www.badcaps.net/forum/showth...03#post1217003
    Last edited by Vesko356; 07-09-2023, 03:37 AM. Reason: Attached BV removed and replaced with link.
    • Pcgamer
      Pcgamer commented
      Editing a comment
      me podrias regalar el archivo por tambien estoy por retroiluminacion
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3593
    • slovakia
    check pins 1,2,3,9 of edp conector for voltage
    • luzvel64
      • Apr 2017
      • 101
      • Guatemala
      thank you very much, it is very helpful for me
      • luzvel64
        • Apr 2017
        • 101
        • Guatemala
        Thanks for your help, on pins 1, 2, 3 I have 0.4v on pin 9 I have 0v. I think the problem is the pwm signal. I'll keep checking, any advice is welcome.
        • luzvel64
          • Apr 2017
          • 101
          • Guatemala
          Hello, following the pwm signal, it seems to me that it comes from pch. I don't know what else I can do to verify because I don't have pwm
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3593
            • slovakia
            as first u r missing backlight power on pins 1.2.3
            • luzvel64
              • Apr 2017
              • 101
              • Guatemala
              I have replaced the fuse fg3301 now I have 9V on pins 1 2 3 but still no backlight.
              In RG3317 on the side where PCH_EDP_PWM comes I have a short to ground
              • trepachka
                • Oct 2022
                • 424
                Anyone has the schematics for this model? I already got boardview for it. Laptop appears to have liquid damage near the video cable, no backlight. Thanks.
                • mon2
                  • Dec 2019
                  • 14191
                  Do you have NMD211 on the logic board? Appears to be used for this model.
                  • trepachka
                    • Oct 2022
                    • 424
                    Mine says "GS557"
                    • mon2
                      • Dec 2019
                      • 14191
                      Looks like this one?
                      US $325.00 | For Lenovo ideapad 5-15IIL05 laptop motherboard GS557 GS558 NM-C681 motherboard with CPU I5-1035G1 RAM 8G UMA 100% test send
                      https://a.aliexpress.com/_mrKVgJk
                      • trepachka
                        • Oct 2022
                        • 424
                        Yes, exactly like that one.
                        • mon2
                          • Dec 2019
                          • 14191
                          See attached screen grab.
                          • trepachka
                            • Oct 2022
                            • 424
                            Thank you. I really appreciate it.
                            I responded to your original request for voltage measurements on PU601 in another thread for "Lenovo C740-15iml". Can you take a look at those and give me your opinion whether the chip has to be replaced or perhaps I need to take other measurements.
                            Thank you kindly.
                            • jimore
                              • Nov 2020
                              • 177
                              • mexico
                              Originally posted by trepachka
                              thank you. I really appreciate it.
                              I responded to your original request for voltage measurements on pu601 in another thread for "lenovo c740-15iml". Can you take a look at those and give me your opinion whether the chip has to be replaced or perhaps i need to take other measurements.
                              Thank you kindly.
                              bro i have same problem, how to pix
                              • Pcgamer
                                Pcgamer commented
                                Editing a comment
                                tuve ese problema ya lo resolvi cambiando en fusible (fg3301) estaba abierto lo remplece por otro de otra board y me funciono midelo en continuidad y sabras si esta bueno o malo si esta bueno mide el pin 22 del circuito pu300 tiene que darte 8.9v si no cambialo espero te ayude
                            • LUIS0205764
                              • Nov 2022
                              • 4
                              • cd mx
                              help i have the problem that +ledvdd only have 17v and i have no lighting on the screen, the fuse is fine, it is the same model of this laptop
                                Lenovo IdeaPad IdeaPad 5 15ITL05 Notebook 5 Specification for Upgrade or Repair
                                This specification for the Lenovo IdeaPad IdeaPad 5 15ITL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 5 15ITL05 boardview and IdeaPad 5 15ITL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                09-07-2024, 04:10 AM
                                Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook 3 Specification for Upgrade or Repair
                                This specification for the Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 17ITL6 boardview and IdeaPad 3 17ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                09-07-2024, 05:20 AM
                                Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook 3 Specification for Upgrade or Repair
                                This specification for the Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IGL05 boardview and IdeaPad 3 15IGL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook 3 Specification for Upgrade or Repair
                                This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15IHU6 boardview and IdeaPad Gaming 3 15IHU6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
