HP Pavilion Flashing Power Light loop
  • DiamondTech61
    • Aug 2021
    • 61
    • united kingdom
    Hi Guys, I have a HP Pavilion laptop 15-dk1007na that wont stay on, when power on the power light flashes on for about 5 seconds then off for about 3 and it keeps looping. The screen does go darker when on while it is powered. I have tested with new RAM in each slot. I also disconnected the battery and the laptop took longer to POST but did show a CMOW reset error and the light stayed on till I pressed enter to reset then it went back to the same problem. I have also booted with an HP Recovery firmware on a USB stick but that didnt seem to load. Board number is GPC52 LA-J641P REV 1.0
  • mon2
    • 14390
    Re: HP Pavilion Flashing Power Light loop
    CMOW reset error
    CMOS reset error.
    Are you using the original power adapter recommended for this laptop ?
    Start with checking the voltage @ the DCin connector. Is this voltage present at all times ?
    Near this connector should be the usual DCin x 2 mosfets that act like solid state switches. These mosfets are driven by a local battery charging IC and is often from TI (former BenchmarQ) with a marking of 'BQ' something.
    Locate these parts and post their top side markings. From the IC markings, we can guesstimate what you have in front of you.
    Often the mosfets are to blame but your case may be different - perhaps a failed capacitor which acts like a short -> causes the current loop circuit to see a higher draw -> will force the local power rail to shut off.
    Will be good to also review each (grey?) coil on your circuit board -> remove all power -> meter in resistance mode.
    One meter probe to one side of the coil; other probe to ground. Record the resistance reading.
    Each coil is linked to a local power supply rail. You are checking the resistance to ground to ideally locate a power rail that may have a shorted capacitor.
    • sasser
      • Dec 2012
      • 364
      • Malaysia
      im also got the same issue. maybe bios need to reflash.i can enter the bios menu after disconnect battery. but return problem after a few minute
      • hpboy
        • Jan 2021
        • 53
        Hi guys.. did you ever resolve this problem?
        • hpboy
          • Jan 2021
          • 53
          For anyone having this issue, here is the resolution. The issue relates to a corrupt BIOS which needs restoring.
          Download the latest BIOS update from HP, create USB stick (using the HP utility in the BIOS download from HP)
          Connect the USB stick to the laptop.
          Power on the laptop and if you have this issue it will power on (led on power button) then as we know, the laptop constantly reboots.
          After a reboot, as the power led switches off, press and hold Windows + B keys, keep holding them down and let the laptop power cycle
          This time, it will boot into BIOS recovery mode, and install the BIOS from USB
            09-06-2024, 05:59 AM
            HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
            This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
            09-12-2024, 02:15 PM
            HP Pavilion Power 580-071na Pavilion Power i5-7400 Specification for Upgrade or Repair
            This specification for the HP Pavilion Power 580-071na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-071na boardview and Pavilion Power 580-071na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
            09-12-2024, 02:00 PM
            HP Pavilion Power 15-cb094tx Notebook 15 Specification for Upgrade or Repair
            This specification for the HP Pavilion Power 15-cb094tx Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Power 15-cb094tx boardview and Power 15-cb094tx schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
            09-06-2024, 05:54 AM
          • PantherDave
            by PantherDave
            Hi all!
            05-29-2024, 02:01 PM
