MSI GT72VR 6RE (MS-1785) - power problem
  • danro
    • Aug 2011
    • 54
    • Serbia
    I have a MSI GT72VR 6RE (MS-1785) laptop.
    Unit work fine on battery only, on AC adapter only and on both together. Also the battery is charging ok.
    The problem is: when laptop is work on battery and connect the AC adapter, the unit go off instant. Sometime, but rarely - 1 of 5 adapter connection, not go off. Not matter if unit is in bios or windows.
    I was already try with new battery, new AC adapter, new DC jack, but the problem persist. Also write original bios with clean ME and new bios. Unit still go off instant when AC adapter is connected.
    Please advise me what else can try or what transient signal must monitorising to find defective component?
    I have MS-1782 schematic only, but seems to be similar at least on power part.
    Thank you
  • mon2
    • 14677
    Re: MSI GT72VR 6RE (MS-1785) - power problem
    What is the history of this unit?
    If a sudden fault then each mosfet linked to the charger IC needs to be reviewed.
    Link or post the schematic here.
    Remove all power. Meter in resistance mode.
    Check the resistance of the first 2 DCin mosfets.
    Source and drain
    Source and gate
    Gate and drain
    Post each measurement and the meter scale used for the measurements.
    Repeat for the next DCin mosfet. Finally, repeat for the battery mosfet that is enabled when using only the battery.
    Someone is leaking.
    • danro
      • Aug 2011
      • 54
      • Serbia
      Source and drain
      Source and gate
      Gate and drain
      Someone is leaking.
      Thanks for answer,
      Here is the schematic that I use:
      https://www.badcaps.net/forum/showthread.php?t=101781
      Reading in diode mode, all measurements look ok. I will read also in resistance mode and will post.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Double check resistance on 1st dc-in mosfet. Its likely shorted .Wiser to test out of circuit.
        • danro
          • Aug 2011
          • 54
          • Serbia
          Source and drain
          Source and gate
          Gate and drain
          Someone is leaking.
          Ok, components arrived few hours ago.
          Change both DCin mosfet and that for battery enable when using battery only, but the same situation
          When connect AC adapter, the laptop power off, then power on itself (something like reset...)
          Unfortunately, I have no idea about the history of this unit. Also is no signs of some before intervention
          Any other ideas, please?
          Thank you
          • mon2
            • 14677
            Does the logic board power cycle on /off / on and repeats when both, the power adapter and battery are connected?
            Are you using the recommended power adapter?
            • danro
              • Aug 2011
              • 54
              • Serbia
              ok, to be more specific:
              -the unit work fine on battery only
              -the unit work fine with AC adapter only
              -the unit work fine with battery and AC adapter conected
              -the battery is charging ok when AC adapter is connected
              if laptop is ON (working on battery only), when connect AC adapter, laptop go OFF, then start again and working fine after that (not power cycle on/off/on...)
              yes, is original AC adapter, but already try with 2 others...
              thank you
              • mon2
                • 14677
                Measure the VCC voltage to the charger IC when it is powered by the battery.
                Then review the same when you plug in the power adapter.
                Does this pin glitch during the power adapter insertion?
                Also watch the ACDRV pin voltage of the DCin mosfets.
                When the external adapter is the active power supply, the battery mosfet should be OFF. Measure the voltage on each pin of the battery mosfet when it is only the battery, then again when you attach the adapter.
                As a quick test, consider to replace the battery mosfet as this is the gateway between the 2 power supply for the logic board.
                On the TI 'BQ' series of charger IC, the REGN is required to have a local cap on this pin. Confirm it.
                • danro
                  • Aug 2011
                  • 54
                  • Serbia
                  OK, sorry for late, but here latest news.
                  Was changed: charger IC BQ24780S, both DC IN mosfets, battery mosfet.
                  Unit work ok from 10 days. Seems that problem solved
                  Thank you all for help and support!
                  • jaaa1976
                    HP EliteDesk 800 G4 Mini PC -There is a problem with the security device on the unit
                    by jaaa1976
                    Hi everybody !
                    I bought this pc from ebay with error - There is a problem with the security device on the unit
                    please fix my bios.
                    Model: HP Elitedesk 800 G4 mini PC (65w)
                    serial no. 8CC93326J4
                    PRODUCT NO. 4KW04ET#ABU
                    32- 16mb bios attached
                    Thank you so much...
                    12-19-2024, 06:48 PM
                    MSI Gaming GT72VR 7RD(Dominator)-439NE Notebook GT Specification for Upgrade or Repair
                    This specification for the MSI Gaming GT72VR 7RD(Dominator)-439NE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GT72VR 7RD(Dominator)-439NE boardview and GT72VR 7RD(Dominator)-439NE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                    09-06-2024, 05:33 AM
                    MSI Gaming GT72VR 7RE(Dominator Pro)-436NE Notebook GT Specification for Upgrade or Repair
                    This specification for the MSI Gaming GT72VR 7RE(Dominator Pro)-436NE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GT72VR 7RE(Dominator Pro)-436NE boardview and GT72VR 7RE(Dominator Pro)-436NE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                    MSI Gaming GT72VR 6RE-067IT Dominator Pro Tobii Notebook GT Specification for Upgrade or Repair
                    This specification for the MSI Gaming GT72VR 6RE-067IT Dominator Pro Tobii Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GT72VR 6RE-067IT Dominator Pro Tobii boardview and GT72VR 6RE-067IT Dominator Pro Tobii schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                    09-06-2024, 05:30 AM
                  • theone111
                    by theone111
                    3. Problem: TV shuts down
                    07-22-2024, 10:36 AM
