820-00850 dim backlight
  • kingskie
    • Oct 2014
    • 249
    • indonesia
    hi all,
    i'm working on macbook pro A1989 820-00850 that has dim backlight.
    means only when set the brightness from 50%-100% then the macbook has backlight. below 50% is no backlight.
    the board is clean, no sign of water damage.
    already change the lcd but still the same.
    do you guys had this problem before?
  • mon2
    • Dec 2019
    • 14011
    Re: 820-00850 dim backlight
    Remove all power. Measure the resistance to ground of the backlight voltage pin.
    Do try a PRAM reset.
    • kingskie
      • Oct 2014
      • 249
      • indonesia
      PPVOUT_S0_LCDBKLT = 16 Mohms down to 6.6 Kohms down to O.L and circle again
      PPVIN_SW_LCDBKLT_SW = 10 Mohms
      LCDBKLT_FB = 151 Kohms
      PPVIN_S0SW_LCDBKLT = 17 Mohms
      LCDBKLT_EN_L = 77Kohms
      LCDBKLT_FET_DRV_R = 20Kohms
      i will try to PRAM Reset
      • kingskie
        • Oct 2014
        • 249
        • indonesia
        after PRAM RESET the apple logo is birght until login screen. but after input the password and loading suddenly the backlight dim again until dekstop shows up.
        • mon2
          • Dec 2019
          • 14011
          Sounds like a software issue.
          If you remain on the login screen -> display is bright ? (do not enter the login details to test)
          Can you test with a bootable USB media ?
          If the USB media boots normal and maintains the high intensity then it is down to the OS settings for your display.
          • kingskie
            • Oct 2014
            • 249
            • indonesia
            ok @mon2, tommorow i will try to boot with usb. if it is really software problem, is there a way to reset the setting without reinstall the mac os?
            • kingskie
              • Oct 2014
              • 249
              • indonesia
              update
              my bad i checked with different lcd...now try with the same type and the backlight is ok.
              thanks @mon2
              • Comp_Pro
                No Backlight Macbook A1990 820-01041
                by Comp_Pro
                Hello all,
                Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                Tests performed:
                There is no backlight even with a good screen.
                Backlight IC is receiving the correct support voltages.
                Fuse F8400 ok
                Current sense resistor R8400 ok
                Backlight IC is receiving 3.3V on enable pin.
                Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                Backlight IC receiving 5V from PP5V_G3S
                Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                05-06-2024, 10:23 PM
              • Constantinos
                Macbook Pro A2442 820-02098 No image but has backlight
                by Constantinos
                Hi all
                I have a Macbook Pro A2442 with the 820-02098 from a friend which has no picture on the display, however, the backlight works.
                He was streaming a football match on a questionable site, then the site crashed, and the problem emerged.
                Initially, he sent it to apple, who quoted him £1323.95 to replace the display, lid angle sensor and top case.
                Obviously, he decided against this and gave it to me so that I could have a crack at it.
                From initial diagnostics, I connected to an external monitor, I first tried with a HP 22W monitor, and I booted into the boot menu...
                08-24-2024, 09:48 AM
              • francescoranchi
                MacBook Pro A1909 LCD (no backlight)
                by francescoranchi
                Hello Everyone,
                I'm looking at purchasing a used LCD from ebay for my macbook A1990 2018 15inch which LCD I cracked. Since new / used but working displays cost around 500$ , I found a Grade A+ LCD display for A1990 which has a good price of 110$ but has no backlight.
                I would need just to make sure that what I know/my reasoning is correct:
                - No backlight means flexgate issue, therefore changingthe flexcable would be enough (I can microsolder to fix the flexgate problem, done it a few times already)
                - Seller confirmed its a LCD issue, and not an issue with the...
                12-04-2023, 06:46 AM
              • tommy97
                Apple MacBook A2337 - No backlight
                by tommy97
                Hi guys, I've got MacBook Air a2337 with no backlight. Once while testing it displayed with the backlight, however after restart problem come back.
                The laptop was tested with fully working screen.
                PP5v_BKLT_A/B 5V
                PP5v_BKLT_D 5V
                PP5V_S2 5V
                PP5V_SW_LCD 0.4V
                P5VS2_PWR_EN 1.8V
                P5VS2_BST_R 8V
                P5VS2_SW 5V
                PPBUS_5VS2_VIN 5V
                PPVOUT_LCDBKLT - Doesn't short 0V
                FP800 - Both sides 12v
                BKLT_EN_R & BL_PWR_EN - around 1.8v
                LP800 0.014V On both sides (should be 12? / no short)
                UC300 & UP800 Replaced...
                12-02-2024, 08:26 AM
              • Riananyaina
                MacBook A1708 820-00840-A backlight issue
                by Riananyaina
                Hello Everyone ,
                today I'm coming to you regarding my issue which is no Backlight .
                I have image on my screen but no light .
                The macbook was one that I bought few month ago that I used with an external screen . Now I started to do some analysis on the MB which my limited knowledge .
                First thing is that it suffered from liquid damage . The fuse was not ok when I openned it the first time . But I already changed it after testing that there is no short to ground on this line .
                Please find below few informations which can help for the analysis...
                04-24-2023, 05:03 AM
