Ok, i didnt know where to post a subject but just the information for everyone in the future...Msi is really strange... There are two versions of the motherboard with designation MS-16jb1 ver 1.0. first one is with i7-6700 cpu and sr2c chipset and second with i7-7700 and sr40 chipet. Beside that the boards look identical...and they both have same designation MS-16jb1 ver 1.0. both are ver 1.0. I know that pins are the same on 6 and 7 gen cpu and chipset but they should be distinguished at least with the ver. of the board. I never seen this before. So info is for all to be careful in the future.
MS-16jb1 ver 1.0
by myth77Mostly i use 90x90 stencils for chip reball, then i remove stencil and apply heat with heatgun...and preheater...and everything is fine. But this SR40 pch chips are very small with lots of balls half milimetar from each other...and i am not happy with results... I get bridges and so on....So i was thinking maybe to reball these SR40 chips with direct heat stencils...but i can not find it in 90x90 size. I tried aliexpress and ebay...but nothing.
Maybe someone knows place to buy? Thx -
by kais2213The laptop stopped working, it doesn't display an image, although it turns on. The service center said the chip was burned out, but they can't find the marking. It's under the designation PU30. Can you provide the schematic or the name of the chip and the model? Thanks!
Laptop is MSI cyborg 15A13VF-
Hi! I just got an MS-6638 from the thrift store, its nearly mint and is running an old BIOS from 2009. I'm looking for the most recent BIOS version to install on it. I can't find any info online. Some have also called it an AE 1900, is this a correct designation? It has an Intel Atom 330, 2 GB of RAM (PC2), and a WD 250 GB HDD. It definitely has not been upgraded. I just don't want to brick it by installing the wrong BIOS.
Thanks,
Sand Enthusiast-
by matushHi,
Does anyone have a photo of the Powermatic 4 Plus cigarette filler?
I need the designation/value of the resistors marked in the photo.2 Photos10-03-2025, 03:04 PM -
by wzamoyskiHello
I received a treadmill controller (probably Zipro Dream) for repair (more like replacing parts). Board designation: PCB-ZYXK9-1111-V1.2.PCB. existing in it were:- mosfet Q9 (originally MDF4N60 was installed) - mounted on P10NK60ZFP;
- resistor R64 (replaced);
- F2 protection.
After turning on the power of AC1 and AC2, the components burned again. The existing elements were desoldered and new ones were soldered. The controller has not been connected yet because I'm afraid they would be destroyed again.
There are no additional restrictions that can be applied,...02-26-2025, 02:29 AM - Loading...
