acer v3-772g bios clock and windows
  • mosfetratus
    Sure Not
    • Feb 2019
    • 174
    • Resistron
    bios clock is not in sync with windows or linux.
    When i remove OS HDD and manually set bios clock, time settings remain. But when i boot windows it keeps reset, other bios settings are not reset.
    Battery is 3V full of life, it is replacement. Before it had a dead battery and the bios posted date like 2033, etc, after every restart.
    Now with a working battery i don't get clock sync with bios and windows.
    Laptop: acer v3-772g, uefi linux or windows - same bios thing.
    Latest bios revision, because it's gtx 850m version MB (last rev.).
  • mon2
    • Dec 2019
    • 13992
    Re: bios clock and windows
    See attached.
    Confirm that the battery voltage is reaching the RTC circuit.
    If the battery is confirmed to be ok - review the RTC crystal @ X2001 = 32.768khz.
    If available, swap from a donor board or source from a reseller. Be sure to source the same footprint / physical size for this crystal.
    • mosfetratus
      Sure Not
      • Feb 2019
      • 174
      • Resistron
      Re: acer v3-772g bios clock and windows
      RTC is 3V
      i'm hobbyist, i don't have equipment to measure freq. of the crystal. :\
      • mosfetratus
        Sure Not
        • Feb 2019
        • 174
        • Resistron
        i set time in bios and shut off computer. Removed battery and power cord. Bios kept time. Every time i boot windows, bios resets time.
        When i shutoff windows, bios timer and windows timer is not synced. If you leave pc off for 20 minutes, windows time will be 20 minutes late to real time and bios time will be reset but 20 minutest past.
        • sikocan
          • Oct 2019
          • 344
          Download net time app free, automatically sets time every few mins and starts automatically with Windows.
          • mosfetratus
            Sure Not
            • Feb 2019
            • 174
            • Resistron
            bios time messes up windows. I get black screen, mouse pointer visible, when i set bios timer.
            • mon2
              • Dec 2019
              • 13992
              I do not think your rtc crystal is working. The crystal is very inexpensive and should be less than $1 usd on the market. You can share pics from your board but will be available on AliExpress.
                • 20643
                Originally posted by mon2
                i do not think your rtc crystal is working. The crystal is very inexpensive and should be less than $1 usd on the market. You can share pics from your board but will be available on aliexpress.
                +1
                • mosfetratus
                  Sure Not
                  • Feb 2019
                  • 174
                  • Resistron
                  Replaced the crystal, and it works like a champ.
                  Thank you guys!
