Re: HP ENVY 17 Motherboard Short help please
See attached.
with care, lift up one leg (not yours) of PL16. This is to isolate the power supply and the consumer side (CPU / PCH).
After you have done this, meter in resistance mode -> check the resistance to ground of this PL16 but at the PCB PADS.
Which side of the PCB PADS has the short ?
Is it the producer (PU10) side ?
Is it the consumer (CPU/PCH) side ?Comment
See attached.
PU10 side is ok.
CPU side shorted.
also still 3v rail short to groundComment
please don't laugh. It just a thought.
according to schematics Inductor connects to SW pin. not to the vOut pin. So when we lift inductor leg up, is that enough
I thought we should release vOut pin. May be Im wrong. please correct.Comment
We are only trying to isolate the blocks on the logic board. Yes, lifting the single coil is ok.
Suspecting that the IC @ PU11 is defective. Not sure about the CPU but it may be ok or defective. As noted in other threads, we thought we had a dead CPU with 0.9 to 1.0 ohms but the unit was working fine. Just a FYI.
Not sure about your case.Comment
but last time, when I removed that chip, I tested the pins on that chip. as I remember, they were not shorted. may Be I can remove it and check if you want.Comment
I know that we may get flamed for trying but if you shorted the +3VPCU to ground then you shunted this power rail down, not spiked it to a higher potential. That is my understanding of what transpired on your desk. That is, this regulator would possibly get hurt. So perhaps some hope. If the 1.05 volt rail got hit by something higher, then it is game over for this CPU/PCH.
If you are comfortable with it, consider to flux and remove this regulator. Believe it is a QFN (quad flat pack package) which are not that bad to rework.Comment
2nd Mosfet gate to ground (19v rail) ———> no short now
3v inductor ——-> 0.1ohm
1.05v inductor pad (cpu side) ——> 0.1ohm
3vpcu (LDO) ——-> 1.3ohms (it was very low before)Last edited by harshana; 08-19-2022, 11:22 PM.Comment
For sure, replace PU11.
The cpu resistance looks too low for it to be ok but proceed to replace PU11 to test again at your discretion.
AliExpress should have these. You may want to order spare mosfets to replace the dcin mosfets. The same store should be able to source them as well.
Find a store with a high score to purchase the above.Comment
Is it worth wasting time on this project as SOC is definitely dead at 0.1 Ohms.Comment
I also thought the same but still I try because the issue made by me. and also The thing I did is short 3v to ground which cant hurt the cpu as I knew. May be I was wrong.Comment
It was already said many times that the PCH, among a bunch of other components, is dead.OpenBoardView — https://github.com/OpenBoardView/OpenBoardViewComment
by kjchatmanthis machine came to me as DOA and immediately found the issue as a 12v short to ground. Is it okay to inject voltage into that rail or does it have a potential path to the cpu or something?
by ArchimedesSubject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
Fans are spinning. Blindly could install windows11 and got the device manager... -
This specification for the HP ENVY ENVY Desktop - 750-524 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ENVY ENVY Desktop - 750-524 boardview and ENVY ENVY Desktop - 750-524 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-12-2024, 03:44 PM
This specification for the HP ENVY ENVY Desktop - 750-510 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ENVY ENVY Desktop - 750-510 boardview and ENVY ENVY Desktop - 750-510 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-12-2024, 03:44 PM
by playithello everyone , working zebronics power suply 450 watts , 5v ,3.3v givin short to ground black wire, also in circuit at output, resistor was charred but shows right values , after removing resistors 39ohms, 51 ohms, there was no short , no continuity beeps with ground , but after replacing new resistors (now i am not switching it on) ,again short still exists . when i put bigger ohm resistor like 100k ohm , no short beeping sound comes , lower ohm resistor gives continuity beeps ,other big ones donest , as its a working psu , i am confused what to remove now or how to go further now .
... - Loading...
