HP ENVY 17 Motherboard Short help please
  • harshana
    • Aug 2022
    • 216
    • Sri Lanka
    Re: HP ENVY 17 Motherboard Short help please
    yes I checked between pin 3 and metal tab.
    can you check the attached photo. the marked part was heating.
    • mon2
      • 14666
      This is the CPU & PCH in a single package. It is the most sensitive and lowest voltage rail device on the board.
      If this part received a hit from the main power rail then this critical part is very likely dead. It is not cost effective to replace this part and requires a complex BGA rework station to remove and replace with another.
      So this review effort may not fix this logic board.
      The readings of the mosfet (4 pin) are too low and are shorting. You can remove this part off the logic board and then check if the short remains or not by checking only the pads on the board. However, very likely the CPU is dead.
      • harshana
        • Aug 2022
        • 216
        • Sri Lanka
        1st thing, You are correct. that mosfet has fried. however I removed it. on the other hand, the pad is still short to ground.
        Actually at the beginning I found a bad cap and I removed it. after that the fan worked. however when I connect the board to display and power on the second time, I shorted 3vpcu to ground.(I wanted to short power sw.it was pin 6 on that connector. but I did it on pin 1)
        After that I saw the short again.
        What do you thing? Is this hopeless???
        • mon2
          • 14666
          Which pad on which part is shorted to ground ?
          What is the exact resistance you are measuring ?
          If you shorted a power supply rail to ground, that may be ok but if the CPU rail saw anything higher than 1v then then the CPU / PCU (single package) is dead.
          • harshana
            • Aug 2022
            • 216
            • Sri Lanka
            see the attachment. It's CN5 which is power on connector.
            I had to short pin 6 to ground to turn on the board. But I shorted pin 1 to ground.
            • mon2
              • 14666
              Hmm. If that is all you have done then I think there may be some hope. We still need to check but..
              With the power on, what is the voltage of the +3VPCU rail on pin #1 of this connector ?
              Also check the points in the attachment.
              • harshana
                • Aug 2022
                • 216
                • Sri Lanka
                #27
                after this new issue, The board doesn't power on. When I check values in my power supply. Its voltage has drop to below than 1v(as I know it should be 19v)
                So how I test this 3v regulator???
                • mon2
                  • 14666
                  My apologies. I think you removed the 2nd mosfet?
                  That mosfet needs to be replaced as it was shorted.
                  Can you confirm?
                  • harshana
                    • Aug 2022
                    • 216
                    • Sri Lanka
                    #29
                    Can you confirm?
                    yes I removed It. so it needs to be replaced. But on the other hand when I check the resistance between ground and the pad on pcb which should connect to the pin3 in 2nd mosfet, Its value is around 0.7ohms. which is very low.
                    So what do you think, Is it still possible to connect it to the power and check voltages of that 3v regulator???
                    • mon2
                      • 14666
                      No. That is a very low resistance. Something downstream is causing this short condition.
                      Can you measure the resistance of the removed mosfet?
                      It may be ok or may be shorted.
                      If you inject 1 volt onto the rail that should have received 19v, who is heating up? Nothing higher as a mosfet later on the board could be leaking and will reach the cpu core and cause damage.
                      • harshana
                        • Aug 2022
                        • 216
                        • Sri Lanka
                        #31
                        When I check removed mosfet, It has very low resistance which means Its shorted.
                        On the other hand when I inject 1v no one is heating up. I tried to inject 1v up to 3A. I see the board take whole 3A. But no one heating up.
                        What should I do?
                        • mon2
                          • 14666
                          Someone is consuming this current. That is, this is 3 watts of power so some one should be warm to hot to the touch.
                          Can you pour some alcohol on the cpu and check if it is evaporating?
                          That is the biggest concern. If it is heating, the cpu is defective. If not, there could be a bad cap or another defective part on the logic board.
                          Here is a video doing the same...worth watching or a quick skim through.
                          https://youtu.be/_i1wRxRuwxs
                          Still recommend to keep the voltage low till we know for sure if the cpu is safe.
                          • harshana
                            • Aug 2022
                            • 216
                            • Sri Lanka
                            #33
                            Which pad should I inject voltage?? 3v Inductor or somewhere else? Can you suggest by seeing schematics please
                            • mon2
                              • 14666
                              See attached. You can inject anywhere you see the VIN label.
                              For example, PU11, inductor PL18, either side is ok.
                              Use 1 volt @ 3A (or higher current is ok). For now, we want the voltage to remain low. Someone should start to heat up.
                              Check if PU11 or the CPU is getting warm / hot while you inject the voltage.
                              • reformatt
                                • Feb 2020
                                • 1500
                                Thermal camera, inject 1V, see what heats up. Likley a dead PCH/CPU, especially if you have dual short on 3.3V and 1.05V rails.
                                Despite what you see on YouTube, we don't usually get money for jam jobs like a shorted cap. Dead CPU's are the most common unfortunately.
                                • harshana
                                  • Aug 2022
                                  • 216
                                  • Sri Lanka
                                  #36
                                  I see very light heat on both pu11 and cpu under 5A which I can inject max from my power unit.
                                  Is that means Its over ???
                                  • harshana
                                    • Aug 2022
                                    • 216
                                    • Sri Lanka
                                    #37
                                    Actually I don't have a thermal camera. I started this stuff as a hobby. however I was able to detect very little heat using petrol test.
                                    • harshana
                                      • Aug 2022
                                      • 216
                                      • Sri Lanka
                                      #38
                                      Any Luck?
                                      • mon2
                                        • 14666
                                        Remove all power.
                                        What is the resistance to ground of the 1.05V rail?
                                        • harshana
                                          • Aug 2022
                                          • 216
                                          • Sri Lanka
                                          #40
                                          Remove all power.
                                          0.7ohms
                                          • kjchatman
                                            820-02020 a2338 motherboard has a ppbus short to ground
                                            by kjchatman
                                            this machine came to me as DOA and immediately found the issue as a 12v short to ground. Is it okay to inject voltage into that rail or does it have a potential path to the cpu or something?
                                            08-21-2025, 12:13 PM
                                          • Archimedes
                                            HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
                                            by Archimedes
                                            Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
                                            Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
                                            Fans are spinning. Blindly could install windows11 and got the device manager...
                                            07-30-2024, 05:14 PM
                                            HP ENVY ENVY Desktop - 750-510 ENVY 750 i5-7400 Specification for Upgrade or Repair
                                            This specification for the HP ENVY ENVY Desktop - 750-510 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ENVY ENVY Desktop - 750-510 boardview and ENVY ENVY Desktop - 750-510 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-12-2024, 03:44 PM
                                            HP ENVY ENVY Desktop - 750-524 ENVY 750 i7-7700 Specification for Upgrade or Repair
                                            This specification for the HP ENVY ENVY Desktop - 750-524 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ENVY ENVY Desktop - 750-524 boardview and ENVY ENVY Desktop - 750-524 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          • playit
                                            450watt power supply 5v, 3.3v short to ground wire,in output rail ,connectors
                                            by playit
                                            hello everyone , working zebronics power suply 450 watts , 5v ,3.3v givin short to ground black wire, also in circuit at output, resistor was charred but shows right values , after removing resistors 39ohms, 51 ohms, there was no short , no continuity beeps with ground , but after replacing new resistors (now i am not switching it on) ,again short still exists . when i put bigger ohm resistor like 100k ohm , no short beeping sound comes , lower ohm resistor gives continuity beeps ,other big ones donest , as its a working psu , i am confused what to remove now or how to go further now .
                                            09-02-2023, 02:43 AM
