HP ENVY 17 Motherboard Short help please
  • harshana
    • Aug 2022
    • 216
    • Sri Lanka
    Motherboard Model: DAY31AMB6C0 REV C
    I was able to find out the boardview and the schematics from the forum. I see there is a short but I can't find out where it is. all the 3v 5v 19.5 are short to ground. when I remove 3v step down regulator, 19v rail is okay but still 3v & 5v inductors short to ground but only LDO signal from 5v chip okay.
    I injected 1v to 3v rail and I was able to see that CPU is heating.
    Can you guys help me to fix this. I really want to fix this motherboard.
    Special: I shorted power switch pin 1 to ground by mistake. Thats the cause to happen this. When I see schematic pin 1 is 3vpcu.
    Anyone can help please???
  • harshana
    • Aug 2022
    • 216
    • Sri Lanka
    Re: HP ENVY 17 Motherboard Short help please
    Anyone please ��
      • 21914
      Originally posted by harshana
      Anyone please ��
      Do you have a DC power supplt to inject voltage with
      • harshana
        • Aug 2022
        • 216
        • Sri Lanka
        Yes I injected 1v with 3A
        • harshana
          • Aug 2022
          • 216
          • Sri Lanka
          Here are the schematics and boardview
          [MOD EDIT] Link to schematic -> https://www.badcaps.net/forum/troubl...b6c0-schematic
          19v short solved when I remove PU11 chip. but still other power rails short to ground.
          when I inject power to 3v rail, PU6 got heated. So I removed it and checked. So I removed that one as well. Then PU8 got heated. So I moved PU5,PU6,PU8.
          Then I see that the CPU is heating.
          • harshana
            • Aug 2022
            • 216
            • Sri Lanka
            • mon2
              • Dec 2019
              • 14670
              Can you post the full details of how you are finding the above to be shorted ?
              Remove all power -> meter in lowest resistance scale -> meter probe on the 3v rail; other meter probe to ground.
              What is the exact reading to ground ? Post the measurement and also the scale used on your meter for this measurement. If possible, share a pic of the meter.
              • harshana
                • Aug 2022
                • 216
                • Sri Lanka
                When I power DC jack using power supply, It takes more than 2A. Thats how I detect the 19v rail short. will upload meter readings soon
                • harshana
                  • Aug 2022
                  • 216
                  • Sri Lanka
                  Probe resistance: 0.4ohm
                  Scale: 200ohm (Digital Multi meter UT33B+)
                  PQ33(First Mosfet) Pin 1,2,3 -----> 0.7ohm
                  PQ20(2nd Mosfet) Pin 1 -----> 1.7ohm & Pin 3 ---->0.4ohm
                  PL21 (3v Rail Inductor) -----> 0.4ohm
                  PL20 (5v Rail Inductor) -----> 1.8ohm
                  PL16 (1.05 Rail Inductor) -----> 0.7ohm
                  PL12 & PL13 (+VGACORE according to schematics) -----> 10ohm
                  • mon2
                    • Dec 2019
                    • 14670
                    Ok. This helps.
                    Pins 1-2-3 are expected to be shorted together since each is the SOURCE cluster of pins. The readings are ok.
                    Pin # 4 = GATE.
                    Then pins 5-6-7-8 will be grouped together = DRAIN cluster of pins.
                    To check if your mosfet is shorted, check the following:
                    source (1-2-3) ; pick any of these pins with one meter probe
                    drain (5-6-7-8) ; pick any of these pins
                    note the reading and post it here. If you see '1' or 'OL' -> then select a higher meter setting till you have an actual value.
                    The '1' / 'OL' means the meter scale is too low and your resistance is higher than say 200 ohms, etc.
                    A low resistance reading = defective mosfet.
                    Next,
                    source (1-2-3) & gate (4) ; post the reading
                    gate (4) & drain (5-6-7-8) ; post the reading
                    Repeat for the 2nd mosfet as well.
                    • harshana
                      • Aug 2022
                      • 216
                      • Sri Lanka
                      Ok. This helps.
                      Pin # 4 = GATE.
                      Next,
                      1st Mosfet = Source to Drain -----> 8.8kohm
                      2nd Mosfet (it only has 4 pins) = Source to Drain -------> 1.5ohm
                      see the attached photo also please
                      • mon2
                        • Dec 2019
                        • 14670
                        I am not familiar with this logic board but for sure the 2nd part is not the mosfet for the DCin connection.
                        Can you zoom / look around the DC in power jack on your logic board ?
                        The ~19v will enter there -> then look for parts like the '#1' in your post = that is a mosfet and the 2nd mosfet will be similar.
                        We are interested to inspect the first 2 x DCin mosfets for this review.
                        Post pics so we can be sure.
                        • harshana
                          • Aug 2022
                          • 216
                          • Sri Lanka
                          My mistake.
                          2nd Mosfet (it only has 4 pins) = Source to Drain -------> 0.5ohm
                          not 1.5
                          • harshana
                            • Aug 2022
                            • 216
                            • Sri Lanka
                            According the schematics. thats the 2nd mosfet. Actually I'm new to this. Am I wrong?
                            • mon2
                              • Dec 2019
                              • 14670
                              Ok. Just re-read this thread - found the schematic..hold for a few.
                              My bad...you are on the right track and are indexing the correct mosfets.
                              See attached for the pinout & datasheet for the 2nd mosfet.
                              Can you confirm that you are using the TAB and the right pin for the SOURCE & DRAIN resistance checks ?
                              This is reading @ 0.5 ohms ?? (you are on the lowest 200 ohm scale on your meter ?)
                              • harshana
                                • Aug 2022
                                • 216
                                • Sri Lanka
                                Here is the board with DC jack
                                • piernov
                                  • Jan 2016
                                  • 4439
                                  • France
                                  Why waste time on a dead PCH? (and many other things)
                                  • mon2
                                    • Dec 2019
                                    • 14670
                                    The CPU is very likely fried.
                                    • harshana
                                      • Aug 2022
                                      • 216
                                      • Sri Lanka
                                      Yes I can guarantee that I checked resistance between pin 4 and pin 3. I entered it as 1.5 by mistake. actual reading was 0.5ohms.
                                      and also my scale is 200ohm
                                      What did you mean by TAB?? I didn't get it.
                                      • mon2
                                        • Dec 2019
                                        • 14670
                                        TAB is the middle of the 3 pins.
                                        So there is the LEFT, MIDDLE pin (broken) but is the metal TAB that is soldered and large in size, RIGHT pin.
                                        • kjchatman
                                          820-02020 a2338 motherboard has a ppbus short to ground
                                          by kjchatman
                                          this machine came to me as DOA and immediately found the issue as a 12v short to ground. Is it okay to inject voltage into that rail or does it have a potential path to the cpu or something?
                                          08-21-2025, 12:13 PM
                                        • Archimedes
                                          HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
                                          by Archimedes
                                          Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
                                          Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
                                          Fans are spinning. Blindly could install windows11 and got the device manager...
                                          07-30-2024, 05:14 PM
                                          HP ENVY ENVY Desktop - 750-524 ENVY 750 i7-7700 Specification for Upgrade or Repair
                                          This specification for the HP ENVY ENVY Desktop - 750-524 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ENVY ENVY Desktop - 750-524 boardview and ENVY ENVY Desktop - 750-524 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-12-2024, 03:44 PM
                                          HP ENVY ENVY Desktop - 750-510 ENVY 750 i5-7400 Specification for Upgrade or Repair
                                          This specification for the HP ENVY ENVY Desktop - 750-510 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ENVY ENVY Desktop - 750-510 boardview and ENVY ENVY Desktop - 750-510 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                        • playit
                                          450watt power supply 5v, 3.3v short to ground wire,in output rail ,connectors
                                          by playit
                                          hello everyone , working zebronics power suply 450 watts , 5v ,3.3v givin short to ground black wire, also in circuit at output, resistor was charred but shows right values , after removing resistors 39ohms, 51 ohms, there was no short , no continuity beeps with ground , but after replacing new resistors (now i am not switching it on) ,again short still exists . when i put bigger ohm resistor like 100k ohm , no short beeping sound comes , lower ohm resistor gives continuity beeps ,other big ones donest , as its a working psu , i am confused what to remove now or how to go further now .
                                          09-02-2023, 02:43 AM
