lenovo ideapad s145-15ast / power off
  • danykhn
    • Jul 2022
    • Argentina
    Hello guys! I brought a lenovo ideapad s145-15ast laptop to my workshop with ignition problems, the client told me that he left it charging for more than 48 hours, he proceeded to uncover it to make a diagnosis when I connected it to its power supply smoke began to come out of one of the chip of the motherboard the "PU3501" a complete deterioration of that area is also observed, the components PJ3506 and PJ3507 have also been blown.
    My question is what function these components have since I don't see the possibility of making a repair.
    Thank you!
  • mon2
    • Dec 2019
    • 14118
    Re: lenovo ideapad s145-15ast / power off
    Apply flux and hot air + use patience to remove this burnt IC. Do not rush it as the bottom belly may have a metal pad that demands to be desoldered and is used for a heatsink.
    Low air pressure so the surrounding parts do not go flying across the street.
    Then clean up the solder pads to make a review about whether it can be repaired or not.
    I think there may be some hope.
    Read off the markings on top of this burnt IC if possible. Have not searched for the schematic yet.
    • JaroTech
      • Mar 2015
      • 351
      Hi, PU3501 is an LV5083AGQUF.
      • mon2
        • Dec 2019
        • 14118
        Thanks.
        Not a cheap IC but available:
        https://www.aliexpress.com/w/wholesa...CatId=0&page=1
        • piernov
          • Jan 2016
          • 4435
          • France
          No, these are solder bridges. Someone worked on this board already. Can also be seen by some traces of leftover flux and the solder blob on PL3501.
          • Dr.d
            Help please..Lenovo ideapad 5 14itl05 power and charging problem
            by Dr.d
            I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
            Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
            04-05-2024, 11:48 AM
          • rabsonnjala
            LENOVO IDEAPAD 100 works only on bench power supply
            by rabsonnjala
            Hie I have a Lenovo laptop
            Lenovo Ideapad 100-14IBY AIVP1-AIVP2 LA-C771P rev 1.0
            it's working only on the bench power supply when I put the battery it doesn't power on. when I also use the original charger it doesn't power. the batter Is fully charged, I used another laptop to charge the battery. but when I use a bench power supply it works perfectly
            below are my readings
            with the original charger only
            JBATT1
            PIN1 0.22V
            PIN2 0.22V
            PIN3 0.45V
            PIN4 0.45V
            PIN5 O.43V
            PIN6 0V
            PIN7 GND
            PIN8...
            11-20-2021, 08:32 AM
          • acata
            Lenovo Ideapad slim 3 not power on
            by acata
            Lenovo Ideapad slim 3 not power on after consumer problems is can not on after sleep mode.
            And the consumer asked for reinstalling OS.
            I reinstalled windows 10 and working fine. After i leave it for updating windows and goes to sleep mode. Now it cant draw any input from power supply.
            Motherboard number is GS450&GS550&GS750 MM-C821 REV: 1.0
            Check the main power rail for 20v input ok
            No amper input from Power supply 0.013a
            Mosfet PQ201 20v and 26v ok.
            3.3v exist
            1,8v exist
            5v exist
            12v from baterai exist....
            09-30-2024, 09:42 PM
          • PantherDave
            by PantherDave
            Hi all!
            05-29-2024, 02:01 PM
