La-c701p
  • ahmarzo
    • Mar 2015
    • 173
    • india
    La-c701p
    Laptop motherboard keyboard working wierdly when i press1 it types 13 when pressed q it types qwe. Have checked ec pins flashed main and ec bios but same problem
  • mielta
    • Apr 2015
    • 368
    Re: La-c701p
    change Keyboard
    • ahmarzo
      • Mar 2015
      • 173
      • india
      Re: La-c701p
      Have tried new keyboard same problem
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Re: La-c701p
        Check SIO pins carefully under microscope or magnifying glass. Two adjacent pins may be connected by a solder blob. Kbd connector is fine.Traces reach EC??
        • ahmedtou
          HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
          by ahmedtou
          help me please
          I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
          When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
          I will share all the details with you, including the disc information.
          Code:
          HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
          Current Profile: BD-R
          Disc Information:
          Status: Empty
          State of Last Session: Empty
          Erasable: No
          Free Sectors: 12,219,392
          Free Space: 25,025,314,816 bytes
          Free Time: 2715:27:17 (MM:SS:FF)
          Next
          08-27-2025, 08:49 AM
        • mkdj
          What should I do after having flashed a BIOS?
          by mkdj
          Dear all,
          I did my first laptop repair related to a BIOS issue. Laptop is a Lenovo ThinkPad T480, and was not booting. With my brand new programmer, I did a back-up of the current not working BIOS, erased the BIOS chip, and flashed this dump: https://www.badcaps.net/forum/troubl...83#post3686683
          Now the laptop works fine, I can access BIOS and boot on a USB drive. But I read stuff about DMI, and...
          09-09-2025, 09:45 AM
        • Loli Popu
          DELL 5590 LAPTOP DEAD AFTER BIOS WRONG FLASHED
          by Loli Popu
          Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
          12-13-2024, 03:28 AM
        • Andreasbest
          Dell Latitude 7410 dead and amber light as long power button is pressed.
          by Andreasbest
          Hello.
          I received a bios locked 7410 with 25Q256JVEQ ,i dump the bios, unlocked it and flash it back, since then the laptop has no life signs at all except amber led on for as long the power button is pressed, nothing else.
          Fact #1 i was unaware that 25Q256JVEQ is 3.3v and i used a 5v CH341A to program it, not sure if the chip got damaged but since then i can read it and write it normally, doesn't seem dead.
          Fact #2 i modded the CH341A to 3.3v, same results with programming though, nothing changed.
          Fact #3 i tried hard reset with cmos/main battery disconnected and power...
          12-21-2024, 02:02 PM
        • TimeRabbit07
          Asus FX517ZC charges but power button does nothing
          by TimeRabbit07
          Hi all!
          I've got an Asus FX517ZC on the bench at the moment and I just can't figure out what's going on with it.
          Here are its various numbers and identifiers:
          Model short: FX517Z
          Model long: FX517ZC-HN114W
          SN: NANRCX01S57842E
          CN: 3SDB 12M
          MFD: 2022-10
          Motherboard model: DA0NJLMBAE0 REV E
          Symptoms:
          The laptop's charge light comes on, but when the power on button is pressed nothing happens. No fan spin, no caps lock, no screen or keyboard backlight, nothing.
          History so far:
          The...
          09-04-2024, 05:48 PM
