IC Marking Codes and Datasheets #2
 Richtek marking information is short and therefore repeats itself, will depend on usage and Package.
 I found it:
 G2= > RT3612EGGQW_WQFN-32 4x4 (IMVP9 CPU Core)
 G2= > RT9715CGQW_ WDFN 3x3-8 (N-MOSFET)
 G2= > RT9166-12GVL_ SOT-23-3 (LDO Regulator)
 G2= > RT3652EBGQW (only in badcaps.net)
 Source:
 https://shopee.ph/Rt3612egqw-RT3612E...75.19374180055
 https://www.recomb-omsk.ru/published...rking_Code.pdf
 SY8008BAAC
 Datasheet hereAttached FilesComment
 TY! It's an 8 bits RISC MCU. I don't think that can be burned.Comment
 thankyou sir
 HYCON Tech ,HY4145 .Datasheet --> https://u.dianyuan.com/upload/space/...598-904754.pdfComment
			by SMDFleaThread started and edited by piernov and SMDFlea. All members are welcome to contribute to the thread, if you have any
 pictures, suggestions, spot any mistakes or want new content adding send me a PM or just make a post. Thanks
 EDIT: See "IC Marking Codes and Datasheets #2" for more posts. All members please post comments in thread #2.
 __________________________________________________ __________________________________________________ ________
 Click on the name next to the post # to view the single post...
			by SMDFleaRicoh Power Management IC`s Marking Codes
 The attached pdf titled "Ricoh PMIC`s Marking Codes,pdf" was made by me from the main pdf Ricoh_MARKINGS.
 ....06-06-2021, 12:29 PM
			by mitsu2kHello folks, I seem to have a lot of trouble when it comes to distinguishing markings on SMD components especially when it comes to the question of whether it is a 1 or an I. for example, I see components marked NI. It looks just like that. However, I cannot tell if that "I" might be a number one instead. Is there a rule of thumb that manufacturers use when using these characters? Attached is an example. This is just one example out of many I come across but it's a good illustration of my point. I appreciate any input....
			by dqtechim working on HP Probook 450 g5 with no power issue and found out coil beside this ic is short to ground...i remove the ic and short gone....ic code AQP,...looking on this ic marking code but not found https://www.badcaps.net/forum/troubl...and-datasheets...
			by abajorHad someone drop off a laptop in which they were upgrading the ram but forgot to unplug the battery.
 Looks like the ram RFI shield shorted a rail going to or coming from a Silergy IC which blasted a component off the board. I'm going to assume it was a cap but really have no way to know for sure since this board schematic doesn't appear to be in the wild yet.
 I'm trying to identify the IC model now but it doesn't appear to match any of the Silergy codes from https://www.badcaps.net/forum/troubl...-tablets-and-m...
- Loading...
