Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
  • Thomasraud
    • Jun 2022
    • 6
    • Estonia
    i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
    QUOTED
    -It works on charger (without battery connected-only charger)
    -It works on battery (without charger connected-only battery)
    -& it also works when plugged in battery & charger, but it's not charging the battery
    //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
    and..
    QUOTE
    The IC cannot maintain the input current level if the charge current has been already reduced to zero. After the
    system current continues increasing to the 1.66X of input current DAC set point (with 2.5ms blank out time),
    IFAULT is pulled to low and the charge is disabled for 1.3s and will soft start again for charge if ACOC condition
    goes away. If such failure is detected seven times in 90 seconds, charge will be latched off and an adapter
    removal and system shut down (make ACDET < 0.6V to reset IC) is required to start charge again. After 90
    seconds, the failure counter will be reset to zero to prevent latch off.
    Think the IC is dead / shorted...Or some cap around shorted...
    It's a hardcore case without schematics...
    // Measured and only PIN12 and PIN13 (CAP, RES acting like shorted).. measured further.. merged lines under R010 (PR4916)?
    QUOTE
    The question is, which one of those 2 different voltages is right?
    Because 1st indicates that charger is not detected & second that it's on protect mode...
    // Author posted PU4001 (BQ24707A) pinouts in wrong order. It should be 1 to 20, but he posted first one 20 to 1 measurements under reverse pin order.
    As i understand most common schematic is 10245-1 and thats revision A00
    10245-1 - 10260-1 INTEL A00 Charging IC PQ4001 BQ24745 28PIN HPB
    10245-2 - 10260-2 INTEL A01 Charging IC PQ4001 BQ24707A 20PIN (5pin GND in centre) Dell Inspiron 14R 5420 use BQ2407A
    10245-3 - 10260-3 AMD? A00 Charging IC known as QUEEN M12
    etc...
    Dell Vostro 3550
    CN OYORGW 70166
    1AB-OMRN-A01
    10245-2
    48.4IE01.021
    DQ15 Intel MB
    Made in China
    Story untill today:
    Long long time ago.. around 6+years ago, this device got covered coffee and device had "insurance", motherboard got replaced, nobody tested charger... device worked fine untill randomly one day anomalies started...
    Laptop/Notebook (however we call that machine/device) is (actually was) working fine. One day i noticed [Battery 0] start giving Not charging errors. So.. based on math, the battery was 6+years old and mainly device was used as "desktop PC" charger always connected. And the day when i needed device in other places with powered ON, i removed charger and it died immediately (Battery was empty).
    Based on information i assumed, battery is old and need replace, so i did. I ordered [BATTERY 1] Green CELL (pro) J1KND battery (7800mAh/86Wh - BatteryMon measured based on charging, its 9000mAh+ and 100Wh+ and designed data is 9600mAh/106Wh), connected it to device and it start charging.. 40% somthing untill 87.7% (im using BatteryBar v3.6.6 and BatteryMon v2.1 B1010).
    And then chargin stopped - i didnt know that (i checked log file and noticed that later).
    Based on chargin indicator LED i assumed, battery is full and...
    So, to get best knowlege how well that battery is performing i started FULL scale battery test (CPU 100%, GPU 100% and no AC connected).
    3h30minutes later i got "Battery is below 10%, connect AC" message and test stoped. - bit later when battery "calibrate and reconsentrate" it showed 6.2% discharge left!
    I connected charger and ... nothing.. no charging (Message: Battery plugged in, not charging).
    So i did "12+ DIY FIX" first 11 points and then bought another battery [BATTERY 2] and started all over again for testing, why its not charging.
    BATTERY 0. DELL OEM.. yeah its dead, output is 2.85V (same as charging voltage)
    BATTERY 1. GreenCell PRO N4010
    BATTERY 2. DELL "original" im not sure is it OEM.
    12+ "DIY FIX"
    1.Turned off device at night and hoped it start charging.. and in morning. Nothing!
    2. Drained notebook "NO AC - NO Battery, NO RTC1, Powerbutton down 30sec+..
    i did that 10+ times.. after every boot-up ad driver uninstall mix.
    3. https://www.speedguide.net/faq/lapto...ng-windows-380 Uninstalled Battery drivers, rebooted; 1. On battery power - no AC, 2.
    On AC power - no battery 3. ON AC and BATTERY power. All 3 times i
    uninstalled battery driver, did restart, connect one or another, checked
    updates, driver got installed, restarted again and moved to next option.
    4. Updated all windows updates.
    5. Tested new installation on windows 7, windows 10, ubuntu etc..
    6. Booted up on USB
    7. Updated BIOS to latest A12 from A11
    8. Replaced Charger (ALL 65W, 130W, 240W is detected in BIOS, im using 240W, even china car charger is detected as 90W).
    9. Opened notebook, made visual check, used multimeter, measured mosfets,
    capacitors, resistors.. 3.3V, 5V and even 19V was present in gate, sourse
    and drain (except some of them, but no short, so i assume those are ok!?)
    10. Replaced CR2032 (RTC1) battery
    11. Replaced BATTERY 1 to BATTERY 2
    12. I cried
    13. I drink
    Seems like im doing something wrong or in wrong order!?
    14. Seek help!
    And now im out of ideas, where to look (btw i dont have dell vostro 3550
    schematic, universal N4010,5100 etc schematic is guide, but does not help much. I dont know what values i have to measure or not. And Also, my dell revision is A01, there is replaced charging IC for more compact one..
    Im not expert, so i have multimeter (3 different) soldering irons (5 total), hotgun, other basic tools (tweezers etc..), but no
    oscilloscope, fancy magnified camera, flir camera.. etc...
    And also, im not good in electronics, i like to learn, but if i dont understand, then its not learning why and how its doing, hatever it should do, but if you only learn to replace parts, then its not learning to fix it, but learning to fix that problem.
    Im out of ideas what and where to look. Point me, if i missed something. For just to throw parts on it, is not viable solution. i really want to understand what it should do and how its working.
    In short:
    Device is working fine! - but its not charging anymore!
    Chargers are detected (all 4)
    Batterys are detected (all 3: BATTERY 0 is 2.85V, BATTERY 1 is 10.5V, BATTERY 2 is 11.54V and if needed, i can charge them to 12V.. direct charging without balancer.)
    Device is running on battery, but not charging it.(not in BIOS, not in device turned OFF, not in OS).
    ALL MEASURED Voltages in 4 Groups:
    XLSX (Excel file), in some reason PDF shows blank page... but if needed, i cand make "screenshot images"
    https://docs.google.com/spreadsheets...f=true&sd=true
    IS ACOK reversed? (so, its should be 0? or 3.33V?)
    Based on BQ24707 diagram it can be both
    Where that ACOK come? From chip?
    I have done so many research, looked so many schematics and i found:
    Acer Aspire V5-531 (v5 571) is based on BQ24707x
    Lenovo B590-LB59A is also BQ24707x
    and the "brotherland" DELL Inspiron 14 N4050 is also BQ24707x
    NOTE: If those schematics are needed, then let me know!
    My plan is to use "dead" motherboard parts.. (soldered CPU and microcracks on those, recycled boards.. etc...) i dont have new or other BQ24707 IC, but i have lots of BQ24735, can i use that? or i should not and use only BQ24707?
    OR IC is alive, but i miss something?
    BEST REGARD, Thomas
  • mon2
    • Dec 2019
    • 14677
    Re: Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
    See attached.
    Is your board layout similar ?
    1) Meter in DC volts mode (20v scale is ok).
    2) Measure the voltage of each pin on the battery connector and post the readings here for a review. Red meter lead on pin #1 of the battery connector; black meter lead to ground. Record the voltage.
    Continue to test pin #2, etc. on the battery connector.
    3) Take close but clear pix of the battery and charger area so we can have a closer look at the design.
    Is component PD3902 a 3 legged part (2 on one side; 1 on other) ? (SOT23)
    This may be the dual ESD diode used to protect the SMBUS / I2C communication lines by the logic board host (bus master) and the BMS (battery management system) controller onboard your battery pack(s).
    Interested to know the voltage on the side with the 2 legs as follows:
    red meter lead on one leg (of the side with the 2 legs) & black meter lead to ground (shield is ok). What is the voltage reading ?
    Repeat but now apply red meter lead on the other leg (of the side with the 2 legs) & black meter lead to ground.
    If correct, this is an ESD protection diode that is camped on the communication lines. Often, this diode will get nuked and causes the communication to fail between the parties and the battery is then not detected. The stats on the battery are extracted using these 2 pins on the battery connector = SDA & SCL lines.
    • Stevedb
      Stevedb
      • Feb 2018
      • 624
      • Belgium
      And like always check if the first mosfet is not shorted between drain and source.
      • Thomasraud
        • Jun 2022
        • 6
        • Estonia
        Originally posted by mon2
        See attached.
        BATT1 Connector (CPU, RAM side up as on attachment)
        Readigs left to right:
        1. 2.76V
        2. 2.77V
        3. 3.35V
        4. 3.35V
        5. 3.32V
        6. 0V
        7. 0V
        8. 0V
        9. 0V
        DELL VOSTRO 3550 Measurements.xlsx (18.9 KB)
        On my board, its not populated, and it is 2 LEGGE part: but readings is: 2.76V ^ 0V
        Black on GND - Red on PD3902 (left side): 2.77V
        Black on GND - Red on PD3902 (right side): 0.00V
        If this is true, then device cant read battery voltage and report it?
        • Thomasraud
          • Jun 2022
          • 6
          • Estonia
          AC first mosfet? WITH AC CONNECTED
          PU3801 on my measure unit it is shorted in both ways (CRT BOARD)
          PU4002 on my measure unit it is shorted in both ways (Motherboard)
          If i remove charger, no short on any mosfet (PU series)
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Resistance is always measured without any power connected.
            • Thomasraud
              • Jun 2022
              • 6
              • Estonia
              Hello again, long month attacked and i had to build new house attachment... PU4001 aka BQ24707 is replaced.. condition changed. Device indicate with LED as it charging, device is turning on with battery and keeps running without it, but for extra i lost SDA SCL data, now its not showing any info how many mah is in battery, only percentage left..
              The time i was writing that, i lost charging again, led turned off and now device is not turning on without battery.. it worked fine first minute or five, there is odd problem... I think i lost BQ24707 again, and maby something extra.
              Unbelievable device.. i waited soo long that bq707.. i have 1 for spare, but if its burning, then im doomed
              • mon2
                • Dec 2019
                • 14677
                PD3902-With flux and low air pressure, remove this part.
                Do not lose the part so we can place it back after testing.
                Power up without this part.
                Post your results.
                This may be the ESD protection dual diode for the smbus communication lines used for the battery pack. For this reason, both lines should ~3v to ground else this part is damaged and can halt proper communication with the battery.
                • Thomasraud
                  • Jun 2022
                  • 6
                  • Estonia
                  Post your results.
                  This board does not have PD3902
                  • mon2
                    • Dec 2019
                    • 14677
                    Remove all power. Meter in resistance mode.
                    One meter probe on the same test pad with the missing PD3902 dual esd diode. Other meter probe to ground.
                    What is the resistance?
                    Next, repeat the same test with the other pad on PD3902 site and the ground on the logic board. Finally, the last pad of PD3902 will be the ground pin so resistance should be ~0 ohms to ground. Confirm this as well.
                    • mon2
                      • Dec 2019
                      • 14677
                      Is PD3902 the part near the battery connector and is with only 2 pads??
                      That is not the esd diode part if the same as the 2nd posted pic above.
                      Can you link the schematics for this logic board?
                      Update..is it the Queen schematic from post #1?
                      Then have it now.
                      Do you have the following parts on your logic board?
                      D3901
                      D3903
                      If yes, post their pic so we can confirm.
                      • mon2
                        • Dec 2019
                        • 14677
                        See attached.
                        D3901 = SCL ESD diode. Remove it and test again.
                        D3903 = SDA ESD diode. Remove this also, if required to restore SMBUS / I2C voltages on the battery connector.
                        • flat-earther
                          how to prevent a connected charger from draining battery when not charging?
                          by flat-earther
                          I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                          So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                          but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                          So the battery is backfeeding the charger and being drained.
                          How can I prevent...
                          08-07-2025, 01:04 PM
                        • Bowline
                          by Bowline
                          06-11-2025, 10:13 AM
                          NVDC charger configuration...
                          11-05-2024, 03:28 PM
                          Bauer tool battery pack charging with a HERCULES charger modification
                          by sam_sam_sam
                          The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
                          Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
                          05-06-2023, 12:17 PM
                        • serious_electron
                          Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                          by serious_electron
                          Hello Everyone!
                          I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                          06-28-2025, 02:57 PM
