Lenovo Thinkpad E570 - BIOS ACPI ?
  • Acnologia
    • 429
    • Poland
    Hello to all ,
    In a similar thread, that i posted i thought it was the problem from BIOS. So maybe it's not the BIOS?
    Laptop that is working just fine, even 6 hours diagnostic tool with RAM test (tried different RAM, tried different HDD/ SSD, swapped BIOS Battery CMOS ,tried brand new install of Windows 7 / 8 / 10 / 11 , but every time the same error once it tried to boot from USB ,it said "ACPI BIOS ERROR".
    I tried and installed just fine Linux Ubuntu , and the laptop worked like a charm.
    So my question is ,where should i keep in my mind, what to do next ?
    (Already tried the reset default settings,disable UEFI with Legacy support etc).
  • todenkopf
    • Oct 2014
    • 49
    • UA
    Re: Lenovo Thinkpad E570 - BIOS ACPI ?
    Hellow, check if your UEFI and EC fw versions match. Update or rollback BIOS.
    • anshad
      • Nov 2010
      • 249
      For ThinkPad, Lenovo usually provides BIOS update in ISO format. You can make bootable USB out of it and update BIOS independent of the OS. Usually both main and EC will be updated. Try that first.
      • Acnologia
        • 429
        • Poland
        Already tried it.
        It asks for battery which is dead / non recoverable.
        • todenkopf
          • Oct 2014
          • 49
          • UA
          Originally posted by AccountSaver
          Already tried it.
          Argument:
          -sp ... Skip power status check
          • Acnologia
            • 429
            • Poland
            Argument:
            -sp ? you mean , to burn the .iso and boot from USB ,and then to put the end argument -sp ?
            Similar thing was in the Dell , if i remember correctly with /forceit ?
            • todenkopf
              • Oct 2014
              • 49
              • UA
              right
              • Acnologia
                • 429
                • Poland
                right
                Doesn't allow me to do any kind of argument change.
                Here are the files for the laptop
                https://support.lenovo.com/us/en/dow...kpad-e470-e570
                But there is no "DOS Support" for the .exe files, to create a bootable not even with rufus etc.
                • todenkopf
                  • Oct 2014
                  • 49
                  • UA
                  Seem that they changed something, i own one of that machines, so i'll try to find a way tonight.
                  • todenkopf
                    • Oct 2014
                    • 49
                    • UA
                    So, I'd figured that out. Download windows package, install it. Navigate to folder that contains "winuptp.exe", run powershell console from that folder and type in:
                    .\winuptp.exe -sp
                    Now agree with whatever it will ask and proceed.
                    • Acnologia
                      • 429
                      • Poland
                      .\winuptp.exe -sp
                      thanks for that man.
                      But in order to do that, and run powershell i should have windows installed.But the laptop doesn't boot into windows.
                      I can only boot to freedos (rufus) or linux.
                      Nothing else
                      • Acnologia
                        • 429
                        • Poland
                        is there any other way to install BIOS Update, for this particular laptop ?
                        P.S : Windows 10 , cannot be installed.
                        Only Linux.
                        • mon2
                          • 14684
                          https://pcsupport.lenovo.com/ca/en/p...loads/ds119160
                          Select the bootable ISO image -> apply this onto a USB media stick using Rufus or similar.
                          • Acnologia
                            • 429
                            • Poland
                            There is no battery installed/exist on the laptop as i have written.
                            So the bios update cannot happen.
                            • Acnologia
                              • 429
                              • Poland
                              New behaviour.
                              It cuts off .
                              Now as soon as you try to boot from USB windows 10 , it shuts off like power cut.
                              Any ideas;
                              • to5it0
                                by to5it0
                                10-24-2025, 01:35 AM
                              • lucaszmn
                                by lucaszmn
                                Problem:
                                Initial Findings:
                                • I concluded that the
                                08-12-2025, 03:01 PM
                              • MaxonDomkrat
                                Lenovo Thinkpad X1 carbon 11th Gen BIOS problem
                                by MaxonDomkrat
                                Hi everyone.
                                I have an engineering sample of a Lenovo ThinkPad X1 Carbon 11th Gen (TYPE 21HM-2FVT05, S/N PF-40G7CD) with an Intel Core i7 1360P (ES – Intel 0000). Since this is an engineering sample, the BIOS had a massive number of various settings. One day, I was experimenting with the BIOS settings and, after saving them, the laptop stopped booting and played a melody after pressing the power button, signaling error code 0002 (Internal bus error), just like in this post: https://www.badcaps.net/forum/troubl...shooting-lapto...
                                07-30-2025, 01:27 PM
                                Lenovo ThinkPad E570 Notebook E Specification for Upgrade or Repair
                                This specification for the Lenovo ThinkPad E570 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E570 boardview and E570 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                                09-06-2024, 08:05 AM
