MacBook Pro Retina Late 2013 shows light, fan spin but no chime
  • mon2
    • Dec 2019
    • 14119
    Re: MacBook Pro Retina Late 2013 shows light, fan spin but no chime
    L7095, pin # 2.
    If that is indeed 3v42, then suggest to check the voltage on each coil on the logic board. Report any low / 0 volt readings.
    • Gigabit2
      • Apr 2022
      • 264
      • United Kingdom
      #82
      PP3V42_G3H_REG tested on L7095 pin 2: 3.42V
      • Gigabit2
        • Apr 2022
        • 264
        • United Kingdom
        #83
        Hi mon2,
        Can you help me make these readings?
        Many thanks.
        • mon2
          • Dec 2019
          • 14119
          Attach a usb mouse. Allow the board to power up and wait a minute or so. Does the usb mouse light up?
          • Gigabit2
            • Apr 2022
            • 264
            • United Kingdom
            #85
            I do not have any wired USB mouse
            I plug in keyboard with USB receiver.
            I can see that keyboard is connecting to USB receiver as connecting light goes out.
            • mon2
              • Dec 2019
              • 14119
              Measure the voltage of PM_BATLOW_L .
              Check it @ Q3000 - pin # 3.
              • Gigabit2
                • Apr 2022
                • 264
                • United Kingdom
                #87
                00.8 on 200m mode.
                • Gigabit2
                  • Apr 2022
                  • 264
                  • United Kingdom
                  #88
                  Sorry is bad reading, I measured at R2140 pin 1 and showing 3.3V
                  • mon2
                    • Dec 2019
                    • 14119
                    Correction: R1240 - good voltage.
                    Confirm the voltage again of PM_SLP_S4_L
                    • Gigabit2
                      • Apr 2022
                      • 264
                      • United Kingdom
                      #90
                      3.3v.
                      • mon2
                        • Dec 2019
                        • 14119
                        Good.
                        See attached. Check each of the signals from this chart to confirm which one is still at '0' logic level.
                        When each is '1' -> the board should boot = S0 power state.
                        • Gigabit2
                          • Apr 2022
                          • 264
                          • United Kingdom
                          #92
                          Hi mon2,
                          Please can you help me understand this chart and what I am testing, please for your help.
                          • mon2
                            • Dec 2019
                            • 14119
                            Search for each of the signal (net) names in the attached chart.
                            Measure their values and post them here. If the voltage is ~3v = '1'; then this is a good reading.
                            If the voltage is low = '0' -> stopping your board from booting up.
                            For the S0 power state, each of the highlighted signals need to be '1'.
                            • Gigabit2
                              • Apr 2022
                              • 264
                              • United Kingdom
                              #94
                              Isolate_cpu mem_l: 3.3v
                              plt reset_l: 3.33v
                              pm_slp_s3_l: 0.00v
                              pm_slp_s4_l: 3.33v
                              cpu_mem_reset_l: 1.35v
                              mem_reset_l: 1.35v
                              memvtt_en: 0.01v
                              cpuvddq_en: 0.00v
                              • Gigabit2
                                • Apr 2022
                                • 264
                                • United Kingdom
                                #95
                                I am not sure what happened but I re-tested all above again and now:
                                Isolate_cpu mem_l: 0.00V
                                plt reset_l: 0.00V
                                pm_slp_s3_l: 0.00V
                                pm_slp_s4_l: 0.00V
                                cpu_mem_reset_l: 0.00V
                                mem_reset_l: 0.00V
                                memvtt_en: 0.00V
                                cpuvddq_en: 0.00V
                                • mon2
                                  • Dec 2019
                                  • 14119
                                  Will have to start from the beginning.
                                  Check PPBUS_G3H.
                                  • Gigabit2
                                    • Apr 2022
                                    • 264
                                    • United Kingdom
                                    #97
                                    Originally posted by mon2
                                    will have to start from the beginning.
                                    Check ppbus_g3h.
                                    12.59v
                                    • Gigabit2
                                      • Apr 2022
                                      • 264
                                      • United Kingdom
                                      #98
                                      Hi mon2,
                                      ALL_SYS_PWRGD is measuring as 3.19V, how can system not boot?
                                      • Gigabit2
                                        • Apr 2022
                                        • 264
                                        • United Kingdom
                                        #99
                                        Now fan started spinning again!
                                        It's spinning like jet engine when power connected but still no boot
                                        • Gigabit2
                                          • Apr 2022
                                          • 264
                                          • United Kingdom
                                          #100
                                          Okay with fan spinning ALL_SYS_PWRGD 3.19V.
                                          But it's intermittent, now fan stopped spinning and ALL_SYS_PWRGD 0.00V!
                                          So it looks like some fault on the board? But even when ALL_SYS_PWRGD is good, still no boot. Seems like stuck in SMC_BYPASS with full fan spin like jet engine?
