MacBook Pro Retina Late 2013 shows light, fan spin but no chime
  • mon2
    • 14806
    Re: MacBook Pro Retina Late 2013 shows light, fan spin but no chime
    Can you help with measuring point for PPVCORE_S0_GFX_REG please?
    Meter in lowest resistance scale. Remove all power / no battery.
    Measure with the meter probe on L9330, pin # 2 or any of the cluster of caps (+ = positive side of the caps).
    What is the resistance to ground ? If possible, take a picture of the meter taking this measurement so we can be sure of the meter scale.
    It is possible that the GPU is damaged from a high voltage surge onto this low voltage rail.
    Also - what is the voltage on the OTHER side of R5350 & R5351 = PP3V3_S0_SMBUS_SMC_0_S0 ?
    • Gigabit2
      • Apr 2022
      • 264
      #62
      L9330 on pin 2 showing 21.0 on 200 mode @mon2.
      Pin 2 of R5350 showing 0.09 on 20V mode.
      Pin 2 of R5351 showing 0.11 on 20V mode.
      • mon2
        • 14806
        Post voltages for U9300; pins 17, 16, 25, 38.
        Adding to your checklist - see attached. Post the voltage of each signal rail.
        • Gigabit2
          • Apr 2022
          • 264
          #64
          Hi mon2.
          U9300
          Pin 16: 5.05V
          Pin 17: 12.54V
          Pin 25: 5.03V
          Pin 38: 3.30V
          SMC_ONOFF_L: 3.37V
          PM_DSW_PWRGD 3.41V
          ALL_SYS_PWRGD: 00.0 on 200m mode
          PM_PCH_SYS_PWROK: 00.0 on 200m mode
          PLT_RESET_L: 01.4 on 200m mode
          LCD_PWR_EN: 00.0 on 200m mode
          LCD_BKLT_EN: 00.0 on 200m mode
          • mon2
            • 14806
            hi.
            Can you confirm that these are VOLTAGE measurements ?
            If yes, then
            ALL_SYS_PWRGD: 00.0
            is not a good status and should be a non-zero voltage. This means that at least one of the power rails that collectively creates the ALL_SYS_PWRGD status pin is pulling down this output. We need to locate which one.
            See attached. The ALL_SYS_PWRGD is built up of a number of power good status pins that are open-drain (each signal can pull the line LOW but there is no HIGH so it will float when the power rail is GOOD). This idea allows for multiple power good lines to be tied together without collision of logic levels.
            Start with removing all power -> check the resistance to ground of the ALL_SYS_PWRGD line. What is the readind and meter scale ?
            Next, if the resistance is not very low, carefully (!), flux and move each resistor in the attached screen grab. Start with only one and keep it on a single pad.
            Then allow for the board to cool down -> power up to see if the ALL_SYS_PWRGD rail is no longer strapped to 0 volts.
            Then proceed to remove the next resistor and so on. At least one of these lines is camping this 'OR'd share line' LOW.
            So in summary, keep removing the resistors that are highlighted till we find out who is pulling this line LOW -> that power rail is NOT with good power.
            • Gigabit2
              • Apr 2022
              • 264
              #66
              Hi mon2,
              Yes these are voltage measurements.
              ALL_SYS_PWRGD resistance: .491 on 2k mode.
              • Gigabit2
                • Apr 2022
                • 264
                #67
                Hi mon2,
                There is no R8162 resistor on my board here!
                • mon2
                  • 14806
                  Was R8162 removed ? I am not sure if it is stuffed by Apple / Foxconn or not but believe it should be there. This is a suspect. Make a note of it.
                  You will need to remove the other resistors as noted above to locate how many of the power good lines are ok or not.
                  What is the voltage on R8167, pin # 1 ?
                  • piernov
                    • Jan 2016
                    • 4439
                    • France
                    #69
                    https://logi.wiki/index.php/ALL_SYS_PWRGD
                    • Gigabit2
                      • Apr 2022
                      • 264
                      #70
                      Hi mon2,
                      I have not touched it.
                      R8167, pin 1: 3.33V.
                      • mon2
                        • 14806
                        Ok. But pin #2 of R8167 is 0 volts ?
                        This means that either R8168 or R8169 or both are pulling this common line LOW.
                        Remove R8168 and check if this common line returns to a HIGH logic level (~3 volts).
                        If it does not, remove R8169 as well. Check again.
                        Once the line is indeed at ~3 volts, solder back one of these resistors. Check again.
                        Any time the line goes back to 0 volts, then that line is pulling down the power good line and that rail is defective.
                        Post your test results. Next confirm that the voltage of that power rail by measuring at the inductor of that rail.
                        • Gigabit2
                          • Apr 2022
                          • 264
                          #72
                          Hi mon2,
                          Pin 2 showing as 3.19V.
                          • Gigabit2
                            • Apr 2022
                            • 264
                            #73
                            So am not sure what happened but is reading 3.19V now. Have not removed any resistors from the board.
                            • mon2
                              • 14806
                              In post # 64,
                              ALL_SYS_PWRGD = 0 volts.
                              It is now ALL_SYS_PWRGD = 3.19V ?
                              • Gigabit2
                                • Apr 2022
                                • 264
                                #75
                                Yes as read on pin 2 of R8167.
                                • Gigabit2
                                  • Apr 2022
                                  • 264
                                  #76
                                  It is worth noting now that neither fan is now spinning up when power is connected.
                                  • mon2
                                    • 14806
                                    What is the voltage on R1949, pin # 2 ?
                                    Confirm the voltage of PPBUS_G3H & PP3V42_G3H_REG.
                                    • Gigabit2
                                      • Apr 2022
                                      • 264
                                      #78
                                      3.40v.
                                      • Gigabit2
                                        • Apr 2022
                                        • 264
                                        #79
                                        Ppbus_g3h:12.62v.
                                        • Gigabit2
                                          • Apr 2022
                                          • 264
                                          #80
                                          Can you tell me a testing point for PP3V42_G3H_REG please?
                                          • Reda123456
                                            MacBook Pro (Retina, 15-inch, Late 2013) A1398 need bios
                                            by Reda123456
                                            MacBook Pro (Retina, 15-inch, Late 2013)A1398
                                            I need bios for this macbook
                                            06-17-2022, 07:11 AM
                                            Acer Spin Spin 511 R753TN Chromebook Specification for Upgrade or Repair
                                            This specification for the Acer Spin Spin 511 R753TN Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 511 R753TN boardview and Spin 511 R753TN schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                            09-07-2024, 02:20 AM
                                            Acer Spin Spin 3 SP313-51N-58JR Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                                            This specification for the Acer Spin Spin 3 SP313-51N-58JR Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 3 SP313-51N-58JR boardview and Spin 3 SP313-51N-58JR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-06-2024, 09:30 PM
                                            Acer Spin Spin 3 SP313-51N-58LR Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                                            This specification for the Acer Spin Spin 3 SP313-51N-58LR Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 3 SP313-51N-58LR boardview and Spin 3 SP313-51N-58LR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            Acer Spin Spin 3 SP314-54N Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                                            This specification for the Acer Spin Spin 3 SP314-54N Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 3 SP314-54N boardview and Spin 3 SP314-54N schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 07:50 PM
