MacBook Pro Retina Late 2013 shows light, fan spin but no chime
  • Gigabit2
    • Apr 2022
    • 264
    • United Kingdom
    Re: MacBook Pro Retina Late 2013 shows light, fan spin but no chime
    Hi mon2,
    Here is chip you said for reflow. Do I remove this rubber stuff or I can just go straight with hot air?
    • mon2
      • Dec 2019
      • 14746
      Yes - with hot air - this stuff becomes brittle and you can gently scrape it away. That is what we have found. It is much like a glue and also will give out a bit of an odor so have a ventilation fan running to avoid the fumes.
      Just do not scrape away any PCB parts.
      Reference (same fault - different board - same part):
      https://www.youtube.com/watch?v=BYLuJBNLHSU
      • mon2
        • Dec 2019
        • 14746
        WAIT !! Why do you have underfill and is a BGA device ?
        What are the markings on your IC ?
        • Gigabit2
          • Apr 2022
          • 264
          • United Kingdom
          Oh I did it now anyway
          • mon2
            • Dec 2019
            • 14746
            Ok - no worries if you have made it dance with flux - no harm but what are the markings on the IC ?
            Let me check my schematic again.
            • mon2
              • Dec 2019
              • 14746
              On logic board # 820-3787-A; U9300 = QFN package like Louis is showing in his video but he is fixing a different A1398 logic board with the same fault.
              Your U9300 = BGA ??
              never mind - false alarm - the picture is blurry from my side - it is a QFN but still with underfill. interesting.
              Proceed - this single device is a root cause and is mentioned on numerous forum chats.
              without this buck regulator; the GPU is no longer powered !
              • Gigabit2
                • Apr 2022
                • 264
                • United Kingdom
                #27
                I did it, laptop now stays on and fan spins full speed like jet engine. But no chime or screen.
                • Gigabit2
                  • Apr 2022
                  • 264
                  • United Kingdom
                  #28
                  No was false alarm, system still turning off
                  • Gigabit2
                    • Apr 2022
                    • 264
                    • United Kingdom
                    #29
                    No was another false alarm sorry. System IS staying on and fan spinning at max speed but no chime or screen
                    • mon2
                      • Dec 2019
                      • 14746
                      Interesting. Can you confirm the GPU voltage rail created by this IC ? What is the voltage?
                      • Gigabit2
                        • Apr 2022
                        • 264
                        • United Kingdom
                        #31
                        Can you tell me what to check precisely?
                        • mon2
                          • Dec 2019
                          • 14746
                          Voltage @ L9330, pin # 2 = PPVCORE_S0_GFX_REG
                          • Gigabit2
                            • Apr 2022
                            • 264
                            • United Kingdom
                            #33
                            00.0 on 200m mode
                            • mon2
                              • Dec 2019
                              • 14746
                              Locate and reflow the following 'thermal sensors' for the GPU.
                              Flux and reflow each. Test again.
                              Need to make a Costco run..will check back later.
                              reference:
                              https://www.youtube.com/watch?v=o94idr9SW-w
                              • mon2
                                • Dec 2019
                                • 14746
                                00.0 on 200m mode
                                hmm.. not like Louis' video. Check the thermal sensor post above.
                                • mon2
                                  • Dec 2019
                                  • 14746
                                  Each of the GPU mosfets must be inspected for shorts using RESISTANCE mode checks.
                                  Note that some of these mosfets are 2 inside a single package. Remove all power -> check the mosfet resistance readings.
                                  Will review later..
                                  PS: Watch the video from Louis - he references these mosfets and they also die often but may also kill the GPU..TBD.
                                  • Gigabit2
                                    • Apr 2022
                                    • 264
                                    • United Kingdom
                                    #37
                                    GPUVCORE_PGOOD showing as .027 on 2V mode, ok reading?
                                    • Gigabit2
                                      • Apr 2022
                                      • 264
                                      • United Kingdom
                                      #38
                                      FYI here is the area around U9300 under the microscope:
                                      • mon2
                                        • Dec 2019
                                        • 14746
                                        Hi. See attached.
                                        See many parts surrounding the GPU buck convertor that have been displaced.
                                        It is vital to review the boardview files -> locate this IC -> locate each and every part around the perimeter of this component and carefully correct their placements. Without the correction, the board does not stand a chance to function properly.
                                        Have highlighted what I believe are parts that must have been moved by the reflow process. There may be others. This is just a cursory review.
                                        Ok to use high heat but lower the air pressure so that the parts do not fly away.
                                        • Gigabit2
                                          • Apr 2022
                                          • 264
                                          • United Kingdom
                                          #40
                                          Hi mon2,
                                          Yes I will correct it. How does IC look to you? With reflow it came off so I put it back on.
                                          What heat are you advising, was using up to 450 to get IC off with Quick station
                                          • Reda123456
                                            MacBook Pro (Retina, 15-inch, Late 2013) A1398 need bios
                                            by Reda123456
                                            MacBook Pro (Retina, 15-inch, Late 2013)A1398
                                            I need bios for this macbook
                                            06-17-2022, 07:11 AM
                                            Acer Spin Spin 511 R753TN Chromebook Specification for Upgrade or Repair
                                            This specification for the Acer Spin Spin 511 R753TN Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 511 R753TN boardview and Spin 511 R753TN schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                            09-07-2024, 02:20 AM
                                            Acer Spin Spin 3 SP313-51N-58JR Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                                            This specification for the Acer Spin Spin 3 SP313-51N-58JR Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 3 SP313-51N-58JR boardview and Spin 3 SP313-51N-58JR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-06-2024, 09:30 PM
                                            Acer Spin Spin 3 SP313-51N-58LR Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                                            This specification for the Acer Spin Spin 3 SP313-51N-58LR Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 3 SP313-51N-58LR boardview and Spin 3 SP313-51N-58LR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            Acer Spin Spin 3 SP314-54N Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                                            This specification for the Acer Spin Spin 3 SP314-54N Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 3 SP314-54N boardview and Spin 3 SP314-54N schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 07:50 PM
